Addressing Intermittent Over Current Faults in Dual UPS System
  • Thread starter Thread starter jtweedie@atdesk.com
    Static Switches
The discussion centers on addressing intermittent over current faults in a dual UPS system involving UPSA and UPSB, each handling approximately 15KW loads. When STSA transfers from source1 on UPSA to source2 on UPSB, the inverter of UPSB faults due to over current. This indicates that UPSB is not adequately sized to handle the combined loads of both UPS systems. The conclusion is that both UPS systems must be rated to supply the total load of A and B to prevent these faults.
  • Understanding of UPS systems and their configurations
  • Knowledge of static transfer switches (STS) and their operation
  • Familiarity with load balancing in electrical systems
  • Basic concepts of electrical fault analysis
  • Research sizing requirements for UPS systems to handle combined loads
  • Learn about static transfer switch configurations and their impact on UPS performance
  • Investigate methods for load balancing across multiple UPS units
  • Explore fault analysis techniques specific to inverter systems
Electrical engineers, UPS system designers, and technicians involved in power management and redundancy solutions will benefit from this discussion.
jtweedie@atdesk.com
I have two UPSs, UPSA & UPSB, and two static transfer switches, STSA & STSB. UPSA feeds Source1 on STSA (preferred) and Source1 on STSB. UPSB feeds Source2 on STSA and Source2 on STSB (preferred). Each UPS has approxiamately a balanced 15KW load. Each UPS has 4 downstream transformers.
Question: IF i fail source1 on UPSA, STSA will will transfer from source1 to source2. BUT UPSB's inverter will fault on over current. The same thing will happen if i fail the preferred source of UPSB. This problem is also intermittent on both UPSs
There is more info but i would like to see what questions are generated so i will hold off. This is the core problem.
Any ideas
This seems to make no sense. If B will trip on over current, then B is not adequately sized to carry both loads. No switching arrangement will cure that. You must have two UPS systems, each rated to supply A+B loads.
  • · Replies 33 ·
