Simple Combinatorics: What are odds of picking same number?
  • Context: High School
  • Thread starter Thread starter hamjam9
    Combinatorics
The discussion revolves around the probability of correctly guessing a letter from the alphabet when given multiple guesses. Participants explore different scenarios, including simultaneous guesses and the implications of guessing different letters.
  • One participant suggests that the probability of guessing the correct letter with two guesses is greater than 2/26, proposing a calculation based on the probability of not picking the letter.
  • Another participant clarifies that the probability of getting the right letter at least once with two guesses can be expressed as the sum of probabilities for each guess, leading to a calculation of 2/26.
  • A later reply emphasizes that if guesses are made simultaneously without feedback, the calculation remains 2/26, as both letters are distinct.
  • Further contributions reinforce that the order of guessing does not affect the probability, as long as different letters are chosen.
  • One participant introduces a scenario involving duplicates, suggesting a modified probability calculation in that context.
Participants generally agree on the calculation leading to a probability of 2/26 for distinct guesses. However, there is some contention regarding the implications of simultaneous guessing and the treatment of duplicates, indicating that multiple views remain on these aspects.
Some assumptions about the nature of the guesses (e.g., distinct letters, simultaneous vs. sequential guessing) are not fully resolved, which may affect the interpretations of the probabilities discussed.
hamjam9
This isn't a hwk question, it's just something I've been trying to show my dad. I'm probably wrong. Okay my question is, suppose you pick ONE letter out of the alphabet.
The odds of me picking your letter are 1/26, if I only have one guess. However, if I have two guesses, aren't the odds a LITTLE bit more than 2/26? The reason why I think so is if you do the calculation this way:
Find out what the prob. is that you DONT pick the letter. Then it is (25/26)*(24/26). Since there are 25 ways to pick the wrong first letter, and then 24 ways to pick the wrong letter a second time. Now you just do 1 minus the above to get the probability it is that you pick the CORRECT letter. Is my reasoning right?
Also, obviously, if this is true, you can then extend it to three guesses, and four, etc. by:
25*24*23*22*.../26^(n) where 'n' is how many tries you took. Thanks!
Well, 1-(25/26)*(24/26) represent the chance of picking the right letter AT LEAST once!
But, obviously, if you pick the right letter the first time, then you do NOT, in the described situation, make yet another guess; thus, for your situation, it would be incorrect to retain the probability of getting two correct guesses!
To do this properly, we can decompose our P(getting the right letter on max two guesses) as follows:
P(getting the right letter on max two guesses) =P(getting it right the first time)+P(chance of getting it right the second time, having failed the first)
This equals:
[tex]\frac{1}{26}+\frac{25}{26}*\frac{1}{25}=\frac{1}{26}+\frac{1}{26}=\frac{2}{26}[/tex]
Thanks arild! Um.. There's just one thing. I'm guessing the letters simelaneously. So there's no feedback on wether my first guess was right. I write down my two guess , and then put it on a table, and he reads it. What are the odds he tells me one of my letters are right. That's the question..
Does this change the 2/26 ?
Well, but you DO know that you choose two DIFFERENT letters, don't you?
To put this in another way:
Thus, you can pick one combination out of 26*25 different combinations.
Label the two letters picked as "A" and "B". Now, the number of combinations in which
"A" is the right letter (but not B) is evidently 25. Equally, there are 25 possiblities that "B" is right and "A" not. Thus, you have 2*25 favourable combinations to pick between.
Thus, the probability is (2*25)/(26*25)=2/26.
It doesn't matter if you guess at the same time or one after
the other, so long as you pick different letters.
Probability of getting it right on the first one:
1/26. Easy.
Probability of missing it on the first, then getting it
right on the second:
(25/26)*(1/25) = 1/26. Not too bad.
Since these two events are mutually exclusive, we have
that P(A AND B) = 0. And since
P(A OR B) = P(A) + P(B) - P(A OR B)
P(A OR B) = 1/26 + 1/26 = 2/26.
Looks like 2/26 to me.
Right. And if you can't control duplicates -- say, you're rolling a 26-sided die labeled with the letters, and C might come up twice -- the chance of guessing it is 2/26 - 1/26^2 = 51/676.
  • · Replies 22 ·
30K
