Thread Closed
how do I find the moment of inertia for a curve?
Share Thread Thread Tools
Mar27-09, 09:53 PM   #1
Recognitions:
Homework Helper Homework Help
1. The problem statement, all variables and given/known data
Say I am given some curve f(x,y) (revolved around some axis), how do I find the moment of inertia about an axis?
I know how to find the moment of inertia of things like a uniform rod, ring and sphere using
[tex]I=\int r^2 dm[/tex]
I believe I am supposed to to pick an elemental piece such that the revolved element is through the axis I want. But if I use I=[itex]\int[/itex]r2 dm, I don't get anywhere.
I've various places that I am to use a double integral or even a triple integral. But I don't know how to set these up to compute the moment of inertia.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Mar27-09, 09:58 PM   #2
Have you met up with the Theorems of Pappus yet?
Mar27-09, 09:59 PM   #3
Recognitions:
Quote by Dr.D View Post
Nope. All they did in class was how to get the moment of inertia of some figure (it escapes me what shape it was). But it was a triple integral, and they just put in the limits and some integrand (how they got it, I know not) and then just put the answer.
Mar27-09, 10:44 PM   #4
All right, then you will have to do something similar. Think in cylindrical coordinates, with the axis of revolution as the polar axis of the cylindrical coordinates. Let's suppose that your given curve is y = f(x). We want to use y as the maximum radius, and x as the z value in the cylindrical coordinate system, so the volume element is
dv = r dr dth dz
where
r is the radius to a point inside the volume, 0<=r<=f(z)
th is the angle theta that measures angle around the z axis, 0<=th<=2*pi
z is the original x value range
Then make your triple integration with all the proper limits and this should give you the volume.
Mar27-09, 10:48 PM   #5
Recognitions:
dv = r dr dth dz
where
then I must still use the formula I=S r2 p dv (p=rho, S=integral)
what if I need to find the moment of inertia of a plane figure such as a triangle or rectangle?
Mar27-09, 10:50 PM   #6
That is a different problem, solved in a different way. Get through this one for now.
Mar27-09, 11:02 PM   #7
Recognitions:
I need to find the moment of inertia about the y axis and in is really cm
So my integrals would be like this:
[tex]I_y= \pho \int_0 ^{0.03} \int_0 ^{2 \pi} \int_0 ^{0.03} r^3 dr d\theta dz[/tex]
Mar28-09, 08:26 AM   #8
In this problem, x is the radius, so solve the curve for x = f(y). Then use that as the upper limit of integration on r.
Mar28-09, 01:43 PM   #9
Recognitions:
Then it should be:
[tex]
I_y= \pho \int_0 ^{0.03} \int_0 ^{2 \pi} \int_0 ^{\frac{y^3}{9}} r^3 dr d\theta dz
[/tex]
But I do not understand how x is the radius here if the curve shows that the x distance is not constant.Also why then would they give the distances 3cm and 3cm (vertically)?
Thread Closed
Thread Tools
Similar Threads for: how do I find the moment of inertia for a curve?
Thread Forum Replies
How do you find the moment of inertia of a polygon? General Math 4
I need to to find the moment of inertia for the system Introductory Physics Homework 1
find the moment of inertia Precalculus Mathematics Homework 5
Find Moment of Inertia and Frictional Torque Introductory Physics Homework 10
Find axis to minimize moment of inertia Introductory Physics Homework 6
