Thread Closed
Integral Question
Share Thread
Jun12-09, 06:55 PM   #1
Integral Question
1. The problem statement, all variables and given/known data
Integrate[Cos[(2x+3)^(1/3)]
2. Relevant equations
3. The attempt at a solution
Would I use simple substitution?
Would it just simply be 1/2*Sin((2x+3)^(1/3))??
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jun12-09, 07:00 PM   #2
Recognitions:
Homework Helper Homework Help
You will have to use a substitution yes. No your answer is wrong. When you're integrating always differentiate your final answer to see if it gives the correct result.
That said do you have any ideas about the kind of substitution you want to use?
Jun12-09, 07:06 PM   #3
Your proposed solution completely disregards the 1/3 power.
I would suggest integration by parts.
Jun12-09, 07:16 PM   #4
Integral Question
Indeed.
U=(2x+3)^1/3
Du= ((2x+3)^(-2/3))/(2/3)
dv=Cos(X)
V= Sin(x)
then use U*du=d*v-integral[du*v] ???
Jun12-09, 07:22 PM   #5
Recognitions:
The substitution is correct, but your du is not. The expression should be multiplied by 2/3, not divided.
So we have the following:
[tex]
du=\frac{2}{3} \left(\frac{1}{(2x+3)^{\frac{1}{3}}}\right)^2 dx
[/tex]
Now write the bracket expression in terms of u.
Thread Closed
Tags
cos, integration, sin
Similar Threads for: Integral Question
Thread Forum Replies
integral question Calculus & Beyond Homework 0
Sine integral (sinc integral) question Calculus & Beyond Homework 3
an integral question Calculus & Beyond Homework 1
Integral question Calculus & Beyond Homework 2
Integral Question Calculus & Beyond Homework 2
