Diffraction of incoherent beam
  • Context: Graduate
  • Thread starter Thread starter sperelat
    Beam Diffraction
The discussion revolves around the diffraction of incoherent beams, particularly focusing on the implications of coherence on diffraction patterns in far-field scenarios using lenses. Participants explore theoretical aspects, practical examples, and calculations related to the coherence area and its effects on diffraction.
  • One participant argues that a completely incoherent beam will not produce diffraction patterns resembling sinc or Bessel functions, suggesting that the width of the diffraction pattern is influenced by the coherence area.
  • Others counter this by citing experiences with sunlight and fluorescent tube light, asserting that focusing such incoherent light does not exhibit the effects described.
  • A quantitative calculation presented indicates that the coherence area of sunlight is too large to observe the argued effects when using a lens with a focal length of about 10 cm.
  • Another participant explains the difference between fully coherent and fully incoherent beams, noting that the diffraction pattern for incoherent illumination is the square of the Fourier Transform of the pupil function.
  • Discussion includes the Van Cittert-Zernike theorem, with participants debating its relevance to the coherence and diffraction patterns of incoherent light.
  • Some participants propose that while an aperture illuminated by incoherent light will still produce a diffraction pattern, the nature of the pattern differs from that produced by coherent light.
  • One participant introduces the idea that spatial coherence can be increased by using an aperture, which creates a new light source with smaller angular size.
  • Another participant suggests a more precise expression for the intensity in the context of far-field diffraction, discussing the implications of incoherent sources on intensity calculations.
Participants express differing views on the effects of coherence on diffraction patterns, with no consensus reached on the implications of incoherent light and the validity of the arguments presented. The discussion remains unresolved regarding the relationship between coherence and diffraction patterns.
Participants acknowledge the complexity of partially coherent light and its diffraction patterns, indicating that the discussion involves nuanced technical arguments and unresolved mathematical steps.
sperelat
Yesterday,our lab members discussed about the diffraction of incoherent beam.
I argued that if the beam is completely incoherent, it will not make diffraction patterns that
follows sinc or bessel-like function.
My argument is that the width of diffraction pattern is determined by light's coherence area.
If coherence area is small, the diffraction pattern will have width wider than that of
perfect coherent light.
(We were talking about far-field diffraction using lens)
If coherence area->0 ,
it will be spreaded all across the focal plane of the lens.
I think such an effect is consistent with van Cittert-Zernike theorem.
However, other lab members did not agree with me.
They say that such a conclustion is different from our experience.
Their examples are sunlight and fluorescent tube light.
If we focus such incoherent light, we will not see the effect I argued above.
I calculated the effect quantitatively today.
It seems that coherence area of sunlight(~0.02 mm )
is too large to see the effect I described above,if we use a lens with focal length
10 cm or so.
It means that even if intensity distribution at focal plane(of such a lens) seem to be focused,it is consistent with my argument.
Anyway,I'm not sure if my method to calculate the effect is correct.
I modeled partially coherent light as many independent wave packets that has
small coherence area.
I thought that the coherence area is like the slit width.
Diffraction pattern width will be deteremined by the coherence area.
I don't exactly know how to calculate the pattern width for partially coherent light.
I'm reading Born and Wolf for this subject, but still confused..
Is there any compact explanation about this kind of effect?
Science news on Phys.org
There are two conceptual limits to any real beam: a fully coherent beam and a fully incoherent beam, and the diffraction pattern for these are fairly simple. The diffraction pattern of a partially coherent beam is significantly more complicated.
For an aperture (or exit pupil) illuminated by a fully coherent beam (i.e. one with a measurable phase everywhere, at all times), the far-field diffraction is the Fourier Transform of the aperture- circular apertures have an Airy function pattern, square ones have sinc functions, etc.
An aperture/exit pupil illuminated by a fully incoherent beam will have as the far-field diffraction pattern the square of the Fourier Transform of the pupil. A subtle thing to remember is that the Fourier transform is complex, and so it's the modulus squared.
Similarly, for coherent illumination, the MTF is the pupil function, while for incoherent illumination, it's the autocorrelation of the pupil function.
Goodman's book "Fourier Optics" has an excellent section on the difference between coherent and incoherent illumination, and why one is not really 'better' than another. Incoherent illumination has a higher cutoff frequency, for example.
Now, the Van Cittert-Zernike theorem states that the mutual coherence function in the observation plane is the Fourier transform of the intensity distribution in the source plane- which can be used to measure the size of objects. Having two adjustable pinholes in the observation plane allows one to measure the mutual coherence function (by measuring the subsequent fringe visibility), which can then be used to infer the size of the original object (i.e. a star). I don't really see how it relates to your problem, tho.
does this help?
Yes, It helps.
Thanks.^^
However,I'm still a little bit confused.
Van Cittert-Zernike Theorem is mainly about propagation of coherence.
Let's define f(x,x') as this coherence function. x and x' are postions on same plane.
If we consider the case x=x', f(x,x) becomes Intensity at x.
And according to Van-Cittert Zernike theorem, the intensity does not depend on
the postion x because f(x,x') depends only on x-x'.
If we think about intensity of far-field diffraction pattern, an aperture illuminated by
fully incoherent light must not make any significant pattern?
Does my argument make sense?
Hmmm... ok, so we have the mutual coherence function f(x,x') which can also give the intensity (f(x,x) = I(x) and f(x',x') = I(x').
The vC-Z theorem states "The degree of mutual coherence between a point x and a variable point x' is equal to the (intensity, far-field) diffraction pattern of the source (replaced by a hole of the same size and shape), centered on point x' and measured at point x."
That's different that wondering if the far-field diffraction pattern exists. Again, an aperture illuminated by incoherent light will still have a diffraction pattern- the only difference is that for coherent imaging, we have:
E(image) = h * E(source)
Where E is the field amplitude, 'h' is the point spread function, and '*' is convolution. For incoherent imaging, we have:
I(image) = |h|^2 * I(source)
Where we have to work with the intensity, since the field is not measurable.
Just to add to what Andy Resnick said using a different approach:
There is no (completely) spatially incoherent light after you send it through an aperture.
Compare this to the case of temporally incoherent light. The temporal autocorrelation is basically the Fourier transform of the power spectrum. Therefore a spectrally broad source will give temporally incoherent light and vice versa. A high spread in the light frequencies will lead to incoherent light. If you use a spectral filter on broadband white light, its coherence time will increase.
Loosely speaking the description is similar for spatial coherence. A high spread in the k-vectors (corresponding to a high angular size of the light source) leads to low spatial coherence. If you put an aperture inside the beam, you cut off some of the light and thereby create a new "light source" with the size of the aperture. Therefore you now have a light source with smaller angular size and a smaller spread in k-vectors. As a consequence you have in fact increased spatial coherence.
This is why you use a single slit in front of the double slit when you use incoherent light for the double slit and this is also why light from distant stars is spatially very coherent (for example the original HBT-experiment relied on this).
you wrote..
I think..below may be more exact expression.
"I(x1)=Integral h*(x1,x')h(x1,x) f(x'x)dx dx' "
If source is incoherent f(x'x) can easily be repaced to I(x)
(f(x'x) may have form I(x)delta(x-x'))
Now, what is h(x1,x) for the far field diffraction?
For the far field diffraction, it may have forms proportional to exp[-i*b*x*x1]
if we let b some coefficient to link x and x1.
If we do the integration,h*(x1,x')h(x1,x) will cancel each other and we will get mere
a constant..
(because of the delta function term..
If we replace f(x,x') to I(x)..the result is the same)
So
I(x1) is proportional to "Integral I(x) dx"
since terms related to x1 elliminated, I(x1) does not depend on x1.
It is same everywhere!
Another approach is the incoherent sum.
If we detect light at overlapping position of light from two incoherent sources,
intenisity is proportional to I(s1)+I(s2).
(if source-detector distance is same for the two sources)
We don't need to care interference effect.
(I don't know how to include a picture in the post)
Same effect applies to far field diffraction.
There will be no destructive inteference in the far-field because point sources on
the source plane are incoherent.
Of course, this not physically realizable.
(It is the reason why I believe that completely incoherent source can not exist)
However, as source becomes more incoherent,the diffraction pattern will be more
like mere a constant distribution.
(Anyway,how can I include formulas written with MathType into my post?)
sperelat said:
<snip>
Not to me... and you can use MathType via the 'advanced' call button -> MathType symbol that appears abouve the post.
For your post, I think you erred in writing down the point spread function- when f(x,x') [tex]\propto \delta (x-x')[/tex] then
I(x1) =[tex]\int h^{*}(x1,x')h(x1,x)f(x',x)dx dx'[/tex] goes to [tex]I(x1) \propto \int h^{*}(x1,x')h(x1,x) \delta (x-x')dx dx' \propto \int |h(x1,x)|^{2}dx[/tex]
Also remember that even though the coherent case Ui = h * Uo, we measure the intensity U*U, and so there are interference terms which are not present in Ii = |h|^2 * Io Thus, although the intensity from two partially coherent sources is a simple sum, the field may not be- there can be constructive, destructive, or partial intereference- the Rayleigh criteria for two partially coherent sources is different than from two mutually coherent sources.
Are we getting anywhere, or going around in circles?
  • · Replies 17 ·
  • · Replies 17 ·
