Does Placing a Floating Ball in Water Affect Scale Balance?
  • Context: Undergrad
  • Thread starter Thread starter shyboyswin
    Force Scale
The discussion centers on the effect of placing a floating ball into a glass of water on a balance scale. Participants conclude that the scale remains balanced because the buoyant force acting on the ball compensates for its weight. The forces on both sides of the scale are analyzed using the equations of motion, confirming that the weight of the displaced water equals the weight of the floating ball. Thus, the scale does not become unbalanced when the ball is placed in the water.
  • Understanding of buoyancy and Archimedes' principle
  • Basic knowledge of forces and equilibrium in physics
  • Familiarity with balance scales and their operation
  • Ability to interpret and manipulate equations of motion
  • Study Archimedes' principle in detail
  • Explore the concept of buoyant force and its calculations
  • Learn about equilibrium and forces in static systems
  • Investigate the effects of different shapes and densities in buoyancy
Students of physics, educators explaining buoyancy concepts, and anyone interested in understanding the principles of balance and forces in fluid mechanics.
shyboyswin
This is not homework, but the question is really bugging me. http://answers.yahoo.com/question/i...gmMkfTsy6IX;_ylv=3?qid=20090713211453AAIVYtd"
Here is the problem:
On a scale, you place a glass of water and a ball on each side of the scale. The scale is balanced at this point. If you take the ball on side B of the scale, and place it into the glass of water on side B and the ball floats, will the scale become unbalanced?
Although the posters on Yahoo Answers think that the scale will remain balanced, I think not. The scale only detects the forces acted on each side. Because the ball floats, there is a buoyant force from the displaced water that is preventing the ball to sink to the bottom, thus the ball's force of gravity is not acting on the scale.
For side A:
[tex]\Sigma F_A = F_{G}_{water} + F_{G}_{ball}[/tex]
For side B:
[tex]\Sigma F_B = F_{G}_{water} + (F_{G}_{ball} - F_{buoy}) = F_{G}_{water}[/tex]
Can someone please confirm/correct.
Hi shyboy. I'm sorry but the Yahoo guy has it right. Just to make sure there's a clear understanding of the question, I'll copy it here:
Both pans of a balance scale have on them identical cups of water, and identical ping-pong balls. Each ball lies on the pan next to the cup. If one of the balls is placed into the cup of water that is on the same pan with it, so that the ball floats, will the scale become unbalanced? If so, which side will rise up?
When you put something into a container of water like this, there is water displaced. That volume of water must go somewhere, so it rises up. The height of the water in the cylinder then, increases because of what is placed into the water. That increase in the water's height will also increase the pressure on the bottom of the cylinder by an amount equal to the weight of the floating object divided by the area of the bottom of the cylinder.
In other words, the force downwards is due to water pressure integrated over an area, and that pressure increases by an amount that is equal to the weight of the floating ball divided by the cylinder's area.
Note that the volume of water displaced by the object has a weight which is equal to the weight of the object. So this volume of water must rise up in the cylinder exactly the same amount that it would rise if water of this volume were added. We could drop either a ping pong ball in of weight W or add water of weight W to the cylinder, and both of these would cause the water to rise inside the cylinder an equal amount.
It can get very complicated if we talk about a non-cylindrical water container, like an old fashion Coke bottle, but the conclusion is the same. The weight of the object in the water increases the downward force on the scale when the ball is put in by an amount equal to the weight of the ball. Therefore, the scale remains ballanced.
  • · Replies 26 ·
