Thread Closed
Isn't the circle connected?
Share Thread Thread Tools
Jul30-09, 10:13 AM   #1
We shall prove (c) using just one special property of the projection p :R -> S1 ,
namely:
There is an open cover {U_alpha} of S1 such that for each alpha, p^(-1) („U …_alpha) can be
decomposed as a disjoint union of open sets each of which is mapped homeomorphically
onto U _alpha by p.
For example, we could take the cover {U_alpha} to consist of any two open arcs in S1
whose union is S1 .
This is from Hatcher's Algebraic Topology, page 30.
I thought that the circle, S1 is path connected. How then can it be decomposed into the disjoint union of open sets? Furthermore, how can two disjoint open arcs in S1 be the have S1 as their union? What happened to the boundary of the two open sets?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jul30-09, 11:24 AM   #2
Quote by PhysicalAnomaly View Post
It is. Therefore, it's connected.
It can't. Reread the snippet carefully. You take a cover of S1, then run it backwards through p. The result is two disjoint open sets in R (not S1!).
You might think "well, p is continuous and connectedness is a topological property?" But that doesn't matter because p^-1 is not continuous.
Jul30-09, 11:43 AM   #3
Mentor
Also note that a disjoint union of open sets A and B does not, in general, require that A and B be disjoint, although, as Tac-Tics has noted, in this case the inverse image of an open arc in S1 is the union of disjoint open subsets of R.
Jul31-09, 06:07 AM   #4
But p was defined to be p(s)=(cos 2*pi*s, sin 2*pi*s). Doesn't that mean that the preimage of a cover in S1 must cover an interval in R? Also, it says that each p-1(U_alpha) was mapped homeomorphically to U_alpha by p. Doesn't that mean that connectedness must be preserved by the inverse function?
<quote>Also note that a disjoint union of open sets A and B does not, in general, require that A and B be disjoint</quote>
That makes sense! So that means that the use of disjoint here is redundant since when you take a union, you never choose the same element twice. Am I right?
Jul31-09, 08:22 AM   #5
Mentor
No, it doesn't say this.
Jul31-09, 08:37 AM   #6
I'm probably interpreting this wrongly but doesn't it say:
onto U _alpha by p.
Thanks for being so patient.
Jul31-09, 08:49 AM   #7
Mentor
"each of which" refers to the individual sets whose union is being taken.
If
[tex]p^{-1} \left[ U_\alpha \right] = A_1 \cup A_2 \cup ...,[/tex]
then each [itex]A_i[/itex] is mapped homeomorphically onto [itex]U_\alpha[/itex].
Jul31-09, 08:53 AM   #8
You're right! That makes so much more sense now! The disjoint open sets would then just be the periodic repeats of the arcs. I need to read more carefully. Thank you so much - you've made my day! :)
Thread Closed
Thread Tools
Similar Threads for: Isn't the circle connected?
Thread Forum Replies
Capacitors Connected, Disconnected, and Connected Again Introductory Physics Homework 1
An open connected set is path(polygon) connected Calculus 1
Path connected and connected. Differential Geometry 10
Is every subspace of a connected space connected? General Math 12
(connected and locally path-connected) ==> (path-connected) Calculus & Beyond Homework 1
