Thread Closed
block and spring on ramp
Share Thread Thread Tools
Oct19-09, 04:28 PM   #1
1. The problem statement, all variables and given/known data
A 5 kg block is placed near the top of a frictionless ramp, which makes an angle of 30o degrees to the horizontal. A distance d = 1.3 m away from the block is an unstretched spring with k = 3000 N/m. The block slides down the ramp and compresses the spring. Find the magnitude of the maximum compression of the spring.
2. Relevant equations
Gravitational Potential Energy = mgh
now i throught i figured out gravitational force was the massXacceleration of g but i took
5X9.8 and got 49 or -49 and both were not correct so i couldnt then move on to figure out the Gravitational Potential Energy so i was stuck there.. and i have to figure that out in order to figure out the entire problem and im stuck.
3. The attempt at a solution
stated up above...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct19-09, 06:02 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by bricker9236 View Post
Why do you think that this is not correct? This is correct (in MKS).
Give us something more to go on, so that we can help you effectively. What is your plan to solve this problem? What physical principles will you use?
Oct19-09, 06:07 PM   #3
When the particle moves from the top to the spring, it loses potential energy. However, when it loses this energy, the energy must go somewhere. In this problem, they want to know the point of highest compression in the spring. What is the change kinetic energy of the mass at this point? What is the change in potential energy in the spring? Same for gravity? and how would you relate all these together to get an answer?
(there is no friction so you do not need to worry of energy loss through heat)
hint: [tex]\Delta E_i = \Delta E_f[/tex]
Thread Closed
Tags
block, compressed spring, ramp
Thread Tools
Similar Threads for: block and spring on ramp
Thread Forum Replies
Block, Ramp, Friction, and Spring Introductory Physics Homework 5
Block, Ramp, Friction, and Spring Introductory Physics Homework 4
Block, Ramp, Friction, and Spring Introductory Physics Homework 7
Block, Ramp, Friction, and Spring Due Tomorrow!! Introductory Physics Homework 1
Block down ramp colliding with spring Introductory Physics Homework 5
