Originally Posted by Phrak
In any case, the answer is yes. A stream of air directed over a surface generates low pressure on the surface.
This only works on a cambered airfoil due to coanada like effect or what I call void effect, where following the cambered surface corresponds to reduced pressure and downwards acceleration. If the "wing" was a flat board with no angle of attack, then the higher pressure of the prop wash above the "wing" and the ambient pressure below the "wing" would result in a downwards force on the "wing".
Wiki explains I call void effect in the article on wing:
In that case a low pressure region is generated on the upper surface of the wing which draws the air above the wing downwards towards what would otherwise be a void after the wing had passed.
http://en.wikipedia.org/wiki/Wing#Science_of_wings
My point here is that it's the pressure differential that produces the lift, not the speed differential. A flow created via mechanical interaction can increase or decrease both the pressure and speed of that flow by peforming work during the interaction. For example the exhaust from a jet engine is both high pressure and high speed.
A wing is a poor example of Bernoulli effect. A venturi tube is a much better example. Direct the output of the fan through a tapered tube with decreasing diameter, and the
friction of the walls, viscosity, and Bernoulli principle will result in a higher speed, lower pressure, smaller diameter air flow.
Getting back to the OP, in order to create lift, you need to accelerate air downwards in an open environment (normal flight), or create a pressure differential if in a closed environment (piston in a cylinder), or a combination if in a partially closed environment (like a wing in ground effect).
