Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Electrical Engineering
Reply
image Math for why voltage is stepped-up in power lines? Share It Thread Tools Search this Thread image
Old Nov22-09, 05:04 PM                  #1
HydroGuy
HydroGuy is Offline:
I've long understood that voltage is stepped-up in power t-lines to decrease losses, however, I've never really understood the math reasoning behind it.
Isn't P = V^2/R the same as P = I^2*R? If so, it seems that either increasing V or increasing I would invoke the same losses... Could someone explain?
Thanks
Old Nov22-09, 05:07 PM                  #2
Snoogans
Snoogans is Offline:
Re: Math for why voltage is stepped-up in power lines?
When you are talking about the power lost over the transmission line, it's the voltage difference between the start and the end of the line, not between operating voltage and earth. This voltage is dependent on current and impedance of the line only.
Old Nov22-09, 05:19 PM                  #3
HydroGuy
OK, thanks but that isn't really answering my question. Why does increasing the voltage decrease the power loss in the line?
Old Nov22-09, 05:20 PM                  #4
mgb_phys
Engineer 2009
mgb_phys is Offline:
Recognitions:
Homework Helper Homework Helper
Good answer - this is the thing most students misunderstand when first seeing this
Old Nov22-09, 05:33 PM                  #5
dlgoff
dlgoff's Avatar
dlgoff is Offline:
Recognitions:
PF Contributor PF Contributor
Another good reason for stepping up the voltage is that you need less current to get the same amount of energy transfer. Hence you can use a smaller gauge wire to carry the load saving wire cost.
Old Nov22-09, 05:35 PM                  #6
mgb_phys
Engineer 2009
Recognitions:
Yes that's the point - but it confuses people who think of power = V^2/r and v as the powerline voltage rather than the voltage drop.
Old Nov22-09, 05:48 PM                  #7
dlgoff
dlgoff's Avatar
dlgoff is Offline:
Recognitions:
There are losses due to corona discharge also when the line to ground voltage gets very high. Not trying to confuse the issue; just noting.
Old Nov22-09, 06:06 PM                  #8
jambaugh
jambaugh's Avatar
jambaugh is Offline:
Recognitions:
It helps if you draw a circuit with a load and consider that you have two voltages, the voltage at the generator and a lowered voltage at the load due to line resistance.
Generator:============Load
(= is wire pair across which we measure voltage).
You have V at the power source and V' at the load with voltage drop: V-V' = RI.
Where R is the line resistance (...for both legs. You can put the load anywhere in the current loop and get the same numbers.)
The load power is V'I and of course current is constant.
(We're doing this in DC for simplicity but you can see the reasoning will apply to AC as well.)
Efficiency is power received at load over power leaving the source:
P at source = VI
P at load = V'I
Efficiency is V'I/VI =V'/V= (V-RI)/V = 1-RI/V. So the less current and more voltage, the close to 100% efficiency.
image image
Reply
Thread Tools
Similar Threads for: Math for why voltage is stepped-up in power lines?
Thread Thread Starter Forum Replies Last Post
High voltage power lines bricevan Classical Physics 8 Sep7-09 01:51 AM
Health Risks Associated with Living Near High-Voltage Power Lines Ian_Brooks Medical Sciences 70 Jun30-09 08:18 PM
Voltage Drop Across Transmission Lines jiten827 Introductory Physics 2 Oct27-07 01:58 AM
Electricity from high voltage lines rtwohey Electrical Engineering 2 Dec8-04 08:29 PM
High voltage lines salsero Electrical Engineering 6 Jan11-04 05:41 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
