Thread Closed
Throwing a ball upward
Share Thread Thread Tools
Jan18-10, 08:37 PM   #1
Hello everyone. I'm sorry for asking such basic questions without offering much in a solution attempt, but the problem is - I have no idea how to answer them! I'm obviously a non-scientist and my math skills aren't so great either. But I would like if someone could simply show me HOW to answer these questions, so I could find the answers myself:
1. The problem statement, all variables and given/known data
"A ball is thrown straight upward at a velocity of 50 m/s:
(1) How long will it take for the ball to stop rising?
(2) How far up has the ball traveled in this time?
(3) What is the ball's acceleration during this time?"
2. Relevant equations
d = 1/2gt2
3. The attempt at a solution
I know how to answer #2 if the ball is in freefall, but I don't know what to do if the ball starts at an upward velocity. Ditto for #1 and #3...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan18-10, 08:58 PM   #2
Recognitions:
Homework Helper Homework Help
Your initial vertical velocity is 50m/s
Jan18-10, 09:09 PM   #3
Quote by rock.freak667 View Post
Right, that is given in the question. I'm not sure what to do with that...
Jan18-10, 09:32 PM   #4
Recognitions:
Quote by Player7900 View Post
In your kinematic equations you have
v=u+at
v2=u2+2ad
d=ut+1/2at2
u= initial velocity.
At the highest point, what is the final vertical velocity equal to?
Jan18-10, 09:53 PM   #5
v=u+at
v2=u2+2ad
d=ut+1/2at2
0 m/s --- So what would I do with that number? (If I should know by now, again I must apologize as I haven't used anything but basic math in years)
Jan18-10, 10:19 PM   #6
The only two equations you need are
1/2mv^2 kinetic
and
mgh gravitational
if the ball has reached it's max height then there is no kinetic so if you make these equations equal to each other, the masses will cancel out, you no your speed v, you no gravity g, all you need to account for is height h, which is simple rearranging
Jan18-10, 10:46 PM   #7
Quote by Edgar92 View Post
1/2mv^2 kinetic
and
mgh gravitational
I don't think mass needs to be accounted for, for this question. The question assumes there is no air resistance, and I guess the only relevant factors in figuring out the answers are initial velocity and gravity.
For the first formula I get: 1/2(50)^2 = 1250 J
So, what can I do with that number? Should it help me figure out the height?
Jan18-10, 10:51 PM   #8
Set that formula equal to the gravatational potential equation which is mgh but it's like I said, m is irrelevant and u do no g, all you need is h
Jan18-10, 10:52 PM   #9
1/2mv^2=mgh
work from there
Jan18-10, 10:57 PM   #10
1/2mv^2=mgh
work from there
1250=gh
1250=(9.8)(h)
1250/9.8=h
h=127.5m
Is that correct? If so, how then would I get the time to reach maximum height?
Jan18-10, 11:06 PM   #11
I don't have a calculator but the equation is right
height is equal to distance
use the equation d=v*t since you know 2 of the 3 variables
t=d/v try it and you should be done
Jan18-10, 11:12 PM   #12
Be sure to post when your done so I know when to stop lol
Jan18-10, 11:18 PM   #13
127.5/50=t
t=2.55
The last question is "What is the ball's acceleration during this time?" - What should I do to figure that out?
Also, is there a way to figure out (t) before figuring out (d)? I ask because that question that asks for (t) comes first...
Jan18-10, 11:21 PM   #14
a=v/t
now that you have t and have v aswell, just sub in the appropriate values and you are done. I'm done for the day but that should be enough to finish the rest of this question
Jan18-10, 11:38 PM   #15
If anyone else could offer one last bit of advice:
Is there a formula that I can use to find (t) before finding (h), if all that is known is the initial velocity?
Jan19-10, 12:43 PM   #16
Recognitions:
The kinematic equations
v=u+at
v2=u2+2ad
d=ut+1/2at2
v=final velocity
At the highest point, the final vertical velocity is zero.
Thread Closed
Tags
distance, gravity, kinematics, time, velocity
Thread Tools
Similar Threads for: Throwing a ball upward
Thread Forum Replies
Throwing a ball upward on top of a building, find height of building Introductory Physics Homework 1
Ball thrown upward General Physics 10
Throwing a ball Introductory Physics Homework 8
ball thrown upward Introductory Physics Homework 26
throwing a ball Introductory Physics Homework 3
