Inhomogeneous diff EQ, undetermined coefficients
The discussion focuses on solving the inhomogeneous differential equation y" + 3y' = 72sin(3t) + 36cos(3t) with initial conditions y(0) = 6 and y'(0) = 9. The user initially finds the homogeneous solution, yielding y = 9 - 3e^(-3t) - 2sin(3t) - 6cos(3t). However, the solution does not satisfy the initial conditions, prompting clarification on when to apply these conditions in the solution process. The correct approach is to determine the constants after finding the particular solution.
  • Understanding of second-order linear differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of initial value problems
  • Basic calculus, particularly differentiation and integration
  • Study the method of undetermined coefficients in depth
  • Learn about initial value problems and their solutions
  • Explore homogeneous vs. inhomogeneous differential equations
  • Practice solving second-order linear differential equations with various initial conditions
Students and professionals in mathematics, engineering, and physics who are working with differential equations, particularly those interested in solving initial value problems and applying the method of undetermined coefficients.
offbeatjumi
Find the solution of:
where y(0) = 6 and y'(0) = 9
I first found the solution to the homogeneous eq:
the roots (R^2 + 3R = 0) are R = 0, -3
which gives the family of solutions:
y = a(1) + be^(-3t)
and y' = -3be^(-3t)
using the initial conditions (maybe I am not supposed to use them here?)
I find a = 9, b = -3
For the inhomogeneous eq:
I try (guess)
y = Asin(3t) + Bsin(3t)
y' = 3Acos(3t) - 3Bsin(3t)
y" = -9Asin(3t) - 9Bcos(3t)
substitute those values into the original equation (left hand side) I find
sin3t(-9A-9B) + cos3t(-9B-9A) = 72sin3t + 36cos3t
therefore
-9A - 9B = 72
-9B - 9A = 36
giving B = -6, A = -2
Therefore I get the solution:
y = 9 - 3e^(-3t) - 2sin3t - 6cos3t
What did I do wrong (this answer is incorrect)
Thanks
Hi offbeatjumi! :smile:
offbeatjumi said:
… where y(0) = 6 and y'(0) = 9
But y(0) ≠ 6, is it?
So you did need to wait until the end before finding the constants. :wink:
thank you! i wasn't sure about where to apply initial conditions
