Calculating Distance and Equation for a Hyperbola Using LORAN Stations
The discussion focuses on calculating the distance and equation for a hyperbola using LORAN stations A and B, which are 520 miles apart. The ship at point P receives signals from station A 2,640 microseconds before receiving signals from station B, with radio signals traveling at 960 feet per millisecond. The solution involves determining the absolute difference in distances |d(P, A) - d(P, B)| and formulating the hyperbola's equation based on the given parameters. The user attempted Part A but requires clarification on the correct approach to derive the hyperbola's equation.
  • Understanding of hyperbolas and their properties
  • Knowledge of signal propagation speed calculations
  • Familiarity with coordinate geometry
  • Basic algebra for solving equations
  • Study the properties of hyperbolas and their equations in coordinate geometry
  • Learn how to calculate time delays in signal processing
  • Explore the concept of loci in geometry
  • Review distance formulas in a Cartesian coordinate system
Students studying mathematics, particularly in geometry and algebra, as well as professionals involved in signal processing and navigation systems using LORAN technology.
uselessjack
( URL of image in case it doesn't display : http://imgur.com/wrzYH.png )
The axes x and y are measured in miles.
In the figure, the LORAN stations at A and B are 520 mi apart, and the ship at P receives station A's signal 2,640 microseconds (ms) before it receives the signal from B.
A) Assuming that radio signals travel at 960 ft/ms, find | d(P, A) - d(P, B)|
B) Find an equation for the branch of the hyperbola indicated in red in the figure, using miles as the unit of distance.
C) If A is due north of B, and if P is due east of A, how far is P from A?
My attempt at a solution
The only thing I was able to somewhat figure out was Part A, but I'm not sure if my logic was correct. I multiplied 960 by 2640 to get 2,534,400 and put that was my answer.
I would start by calling A = (0,a) and B = (0,-a) and P = (x,y). Then remember that a hyperbola is the locus of a point moving such that the differences of its distances from two points is a constant d. The two points are the foci. First figure out the equation with those variables. Put the numbers in last.
  • · Replies 27 ·
