| Thread Closed |
Offshore oil drilling is safe? |
Share Thread | Thread Tools |
| May21-10, 02:56 PM | #511 |
| May22-10, 11:52 AM | #512 |
Recognitions:
Currently only a rumor (http://adropofrain.net/2010/05/rumor...efore-blowout/)
But I have been on sites in the US where I have refused to go underground and I know people who work for Schlumberger and their company would definitely walk off a contract if there was any safety violation. |
| May22-10, 12:05 PM | #513 |
| May22-10, 12:16 PM | #514 |
In my experience, Halliburton does not share that quality. I've been on pulp mill/paper mill shutdowns with them and was NOT impressed. Quick and dirty. |
| May23-10, 07:20 AM | #515 |
Yes Indeed. I agree that these will be a bad effect!
| May23-10, 04:40 PM | #516 |
The sickening videos and photos of heavy oil saturating critical marshes, wetlands, and beaches, are beginning to emerge.
http://www.vancouversun.com/news/soa...732/story.html This is a video taken during a flyover of the spill. We can only hope the narrator is being overly pessimistic. |
| May23-10, 07:50 PM | #517 |
| May23-10, 07:51 PM | #518 |
Isn't that what is going to happen with this oil spill come storm season?
| May23-10, 07:52 PM | #519 |
| May23-10, 08:17 PM | #520 |
Oil from algae is just vegetable oil. It is non-toxic. You can drink it. And it degrades readily. Also, without a significant source of nitrogen and the proper temps, the algae won't survive in open water - that is, it wouldn't exist as a giant plume that kills everything else. If you have these conditions, you would already have an algae bloom, in most cases.
You would certainly have a lot of fish food! Also, you wouldn't have millions and millions of gallons of oil leaking endlessly. You could only spill the oil that has been processed. The rest is still trapped in the algae. Please continue the algae discussion here http://www.physicsforums.com/showthread.php?t=211274 |
| May23-10, 08:31 PM | #521 |
IIRC, when we see an ocean temp of 82 degrees F up through the Carribean, that's when the hurricane engine turns on. I'm not 100% sure of the number [maybe 81 degrees F], but it is surprisingly well defined. |
| May23-10, 09:07 PM | #522 |
Well, you have still not provided any information (even poorly-reviewed) about how oil from deep-sea wells magically rises to the surface, and how the production rates of existing wells can be used to limit the theoretical maximum outflow of a damaged well-head. I don't want to characterize another forum member as cheerleading for multinational corporations, but you seem to have moved beyond that to baton-twirling. Please link some peer-reviewed studies that show that the potential blow-out rate of a drilling-rig such as this can be characterized or constrained by the production rates of wells in nearby environs.
If the Deepwater Horizon spill can reasonably be constrained (in volumetrics) by the production rates of other wells in the same area, please show some evidence. |
| May24-10, 12:07 PM | #523 |
A link that will provide a simple and basic bit of info on oil and gas.
http://www.geomore.com/index.html http://www.geomore.com/Oil%20and%20G...20Pressure.htm http://www.geomore.com/Oil%20and%20Gas%20Traps.htm It seems logical that the gas expands and pulls the oil upward on it's rise to the surface, also the oil is in it's own rights, a floating material. |
| May24-10, 12:31 PM | #524 |
Thanks, RonL. You have made my point quite well. Drill a hole into a pressurized deposit of oil and gas and fail to check it, and the flow rates can be quite spectacular. It is disingenuous in the extreme to cite the production rates of wells that have been in production for some time, and claim that their production rates set upper limits on the possible magnitude of this spill. They do not.
| May24-10, 02:29 PM | #525 |
So has anyone figured out how big the field is yet? Is it still putting out oil like it was when they first showed video of it?
| May24-10, 03:26 PM | #526 |
| May24-10, 03:40 PM | #527 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Offshore oil drilling is safe?
| Thread | Forum | Replies | ||
| Offshore Platforms and Mechanical Engineering | Career Guidance | 3 | ||
| Offshore Geothermal Drilling | General Engineering | 2 | ||
| Study supports controversial offshore numbers | Computing & Technology | 0 | ||
