What is the physical meaning of voltage variation in ac
Voltage variation in AC reflects the alternating polarity of the supply, causing electrons to flow in opposite directions during each half-cycle of the sine wave. This results in a voltmeter reading positive voltage for one half and negative voltage for the other. The actual movement of electrons is slow, but the current effect propagates quickly, near the speed of light. When polarity is reversed, electrons shift direction, always flowing from the negative to the positive side. The statement that "voltage is more related to energy and current is related to the number of electrons" is correct.
maheshwaran
hey, i am trying to find what is the process going on in the conductor while conducting ac.
what is happening to electrons? what is the physical meaning of negative voltage in sin curve?
Suppose you put a battery across a resistor. Whichever way you connect it, mark the resistor + and - according to the voltage polarity marked on the battery.
Now reverse the battery. The terminal marked + is now negative relative to the other terminal.
This is all that is happening with an AC voltage, but it happens in a smooth sinewave manner. If the AC input was slow enough, you could watch a voltmeter measuring it reverse polarity. It would read positive voltage for half the cycle and negative voltage for the other half of the cycle.
The electrons actually flow very slowly, so that the electrons that flow out of the resistor are not the ones that flowed into it, but the current effect happens very quickly, at speeds near the speed of light.
When you reverse the polarity of the supply, either with a battery or with an AC supply, the electrons flow in the opposite way to the way they were flowing before. They always flow from the more negative side of the supply to the more positive side.
thank you so much and please say whether the following statement is correct or not.
"voltage is more related to energy and current is related to number of electrons"
Yes.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
