Thread Closed
Design a sprocket system
Share Thread Thread Tools
Sep22-10, 09:22 PM   #1
1. The problem statement, all variables and given/known data
You would like to build a little scooter using an engine. The rear drive wheel/tire that you have is 16 inches in total diameter. You also have a 16 tooth sprocket gear (approx. 2.5 inches in diameter) that will fit on the engine crankshaft. Design a chain and sproeckt system that will allow your scooter to travel at 25mph at rated engine speed.
engine horsepower: 5
engine speed: 3600rpm
note: there must be an intermediate gear and sprocket between the engine(and sprocket) and the back tire, also my professor confirmed that the sprocket on the back tire does not have 109 teeth.
2. Relevant equations
3. The attempt at a solution
back tire speed: 525 rpm
engine speed: 26.77 mph
I can seem to find no matter what equation I use to find any details about the middle sprocket.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Tags
chain, engine, gears, rpm, sprocket
Thread Tools
Similar Threads for: Design a sprocket system
Thread Forum Replies
design a humidifier system Engineering Systems & Design 3
Sprocket and Chain loading Mechanical Engineering 1
Angular Speed of a Sprocket Introductory Physics Homework 1
The best engineering system design Engineering Systems & Design 1
How To Choose A Sprocket Chain Engineering Systems & Design 2
