New Reply
A couple linear algebra questions (basis and linear transformation
Share Thread
Oct31-10, 12:35 AM   #1
Hi guys, I have two practice problems with no solutions that i was not able to figure out. If anyone could help I'd appreciate it.
Question 1
1. The problem statement, all variables and given/known data
Find the basis of {(x,y,z) | x + y + 2z = 0}
2. Relevant equations
None?
3. The attempt at a solution
I can find the basis of a matrix but I'm not sure how to go about finding the matrix of a homogeneous equation. Can I just turn it into a 1x3 matrix, give it the coefficients (1,1,2) and call that my basis?
Question 2
Let T(y) = y'' + y. Find ker(T)
ker(T) = nullspace(matrix(T))
solution to y + y'' = 0 is asin(x) + bcos(x) (Relevant?)
I'm not even sure how to begin this. I know what the kernel of a linear transformation is but I am not sure how to turn y + y'' into a matrix. Could I do as follows?
y y' y''
1 0 1
[1, 0, 1 | 0] = REF [1, 0, 1 | 0]
y = -y''
Would that be the solution?
Finally, I have a quick question that doesn't really warrant the entire template. I'm to calculate an eigenvector and after plugging one of the eigenvalues I found into the matrix, I got
0 2 0
0 1 3
0 0 -1
Row reduction gives
0 1 3
0 0 1
0 0 0
Setting the matrix equal to 0:
x3 = 0
x2 = -3(x3) = 0
x1 = t?
In this case, is my eigenvector (t,0, 0)?
Sorry for all the questions; the exam is on Monday and the prof didn't give out any answers to his study materials. I just got around to these questions so I would really like to figure them out before the exam. Thanks for any help or advice.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Oct31-10, 01:09 AM   #2
For question 1 with the condition x + y + 2z = 0, try to express one of the variables in other two variables. For example, x = -y - 2z. Then, replace x with -y - 2z in {(x,y,z)|x,y,z are real}. Lastly, try to "factor" or decompose the vector into several vectors to get the basis.
Oct31-10, 01:53 AM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
For the second question, you should really go back to the definitions of vector spaces and linear transformations. It is often helpful, but by no means necessary to use a matrix to represent a linear transformation.
In question 2, the vector space in question is the set [tex]V = \{f| f:\mathbb{R}\rightarrow\mathbb{R}\}[/tex] of differentiable functions f from the reals to the reals. This space is infinite dimensional, but we still know how to add functions and multiply them by scalars. However we can't really write them down in a list [tex](f_1, f_2,\ldots)[/tex] unless we impose further constraints that would let us define a basis.
Furthermore, the linear operator T is a differential operator, and since we don't have a basis yet for the space on which it acts, we can't write a matrix down for it. However [tex]\text{ker}(T) \subset V[/tex] is still defined by the real definition of kernel:
[tex]\text{ker}(T) = \{ v\in V | T(v) =0\}.[/tex]
In fact, as you showed, it is spanned by only two functions, so we can write the basis down for it. However, as you saw, you didn't need to refer to any matrix or nullspace to compute it.
For your last question, I'm baffled by what you mean by "plugging one of the eigenvalues I found into the matrix." The eigenvector equation is M v = a v. You should take the most general parametrization of v = (x,y,z) and solve the set of equations that result. If the matrix you wrote down is M -a I, then you probably have the right value.
Oct31-10, 10:38 AM   #4
Quote by lkh1986 View Post
Alright, I'll give it a shot.
x = -y -2z
{(y,z) | -y-2z, y, z}
{(y,z) | y(-1, 1, 0) + z(-2, 0, 1)}
Basis: {(-1, 1, 0), (-2, 0, 1)}
Is that correct?
Oct31-10, 12:04 PM   #5
Quote by Roo2 View Post
x = -y -2z
Is that correct?
={(x,y,z) | x = -y -2z}
={(-y -2z,y,z) | y,z are real}
={y(1,1,0) + z(-2,0,1) | y, z are real}
=L{(-1, 1, 0), (-2, 0, 1)}
Yup, same answer obtained. :)
Or, if you have chosen to express y in terms of x and z, you will get:
={(x,y,z) | y =-x-2z}
={(x,-x-2z,z) | x,z are real}
={x(1,-1,0) + z(0,-2,1) | x, z are real}
=L{(1, -1, 0), (0, -2, 1)}
Basis: {(1, -1, 0), (0, -2, 1)}
[I think this answer is also acceptable]
Nov2-10, 09:05 AM   #6
Recognitions:
Retired Staff Staff Emeritus
Question 1
None?
Wouldn't you think x+ y+ 2z= 0 is relevant?
Interesting. In all the years I have been working with linear algebra, I have never even heard of the "basis" of a matrix! The only basis I know ,defined for linear algebra, is the basis of a vector space or subspace which is what is asked for here.
From x+y+ 2z= 0, x= -y- 2z. In particular, (x, y, z)= (-y- 2z, y, z)= (-y, y, 0)+ (-2z, 0, z)= y(-1, 1, 0)+ z(-2, 0, 1). Now what do you think a basis would be?
Notice that we could as easily have said y= -x- 2z so that (x, y, z)= (x, -x- 2z, z)= (x, -x, 0)+ (0, -2z, z)= x(1, -1, 0)+ z(0, -2, 1) giving another answer to the same question.
Or, z= -x/2- y/2 so that (x, y, z)= (x, y, -x/2- y/2)= (x, 0, -x/2)+ (0, y, -y/2)= x(1, 0, -1/2)+ y(1, 0, -1/2) giving a third basis.
Of course, there exist an infinite number of "bases" for any vector space.
Question 2
Only in the sense that the solution is relevant!
y y' y''
1 0 1
y = -y''
Would that be the solution?[quote]
Why do you keep talking about matrices? Linear transformations are more general, more fundamental, and more important than matrices. The kernel of a linear transformation is the set of all vectors that it maps to 0. Here, since T involves differentiation, the vector space is the space of all infinitely differentiable functions with function addition as vector addition. T(y)= y+ y"= 0 is satisified, as you say, by asin(x)+ bcos(x). The kernel of T is exactly the set of all functions of the form f(x)= a sin(x)+ b cos(x). It is the subspace spanned by sin(x) and cos(x).
0 2 0
0 1 3
0 0 -1
Row reduction gives
0 1 3
0 0 1
0 0 0
x3 = 0
x2 = -3(x3) = 0
x1 = t?
If [itex]\lambda[/itex] is an eigenvalue of linear transformation T, then there exist non-zero vectors, v, such that [itex]Tv= \lambda v[/itex]. That means, in particular, that [itex]T(v- \lambda v)= (T- \lambda I)v= 0[/itex] so the space of all eigenvalues of T, corresponding to eigenvalue [itex]\lambda[/itex] is the kernel of the linear transformation [itex]T- \lambda I[/itex]. By subtracting [itex]\lambda[/itex] from each of the diagonal values, you have given the matrix for [itex]T- \lambda I[/itex]. Yes, you are looking for the kernal of that matrix. You must have [itex]x_2= x_3= 0[/itex] but have no condition on [itex]x_1[/itex] so it can be anything. Yes, (t, 0, 0), where t can be any number, is an eigenvector.
New Reply
Similar discussions for: A couple linear algebra questions (basis and linear transformation
Thread Forum Replies
Another linear algebra problem, basis and linear transformations. Calculus & Beyond Homework 7
linear algebra - basis multiple choice questions Calculus & Beyond Homework 4
Linear Algebra - Linear Transformations, Change of Basis Calculus & Beyond Homework 3
Couple of Linear Algebra Questions Linear & Abstract Algebra 7
Linear Algebra: Linear Transformation and Linear Independence Calculus & Beyond Homework 8
