| New Reply |
Inexpensive alpha emitter? |
Share Thread | Thread Tools |
| Nov17-10, 08:27 PM | #1 |
I would like to pursue an idea that involves transmutation of elements using an alpha emitter. I figure that the production rate I would like to achieve would require about 5 Ci of radioactivity. What would be a good candidate, i.e. least expensive and reliable supply with a half life of > 60 days and an energy of at least 1.5 MeV? I've looked at Po-210 but according to wiki, the annual global production is about 100 grams per year and although I haven't worked it out the price per curie is probably prohibitively expensive.
Essentially looking for the biggest alpha-bang per buck! Thanks |
| Nov17-10, 09:21 PM | #2 |
How about this:
http://en.wikipedia.org/wiki/Americium#Applications |
| Nov18-10, 08:24 AM | #3 |
Thanks. After posting I thought about Americium because it's common in smoke detectors. It is a bit expensive at $160 per milligram but I think I can produce small amounts of product and scale it up.
1 gram of Americium would generate 3.5 Ci. I'm guessing that amount would cost far less than $160,000. The cool thing is with a 400+ year half life for Am-241, it would not need to be replenished often. Strat-O |
| Nov18-10, 09:28 AM | #4 |
Price is outstanding. Looks like you can get a gram of Am-241 oxide for $1,600.
| Nov20-10, 06:08 AM | #5 |
Admin
| Nov21-10, 04:58 PM | #6 |
I do believe there are a certain set of guidelines you should follow before you attempt this.
| Nov21-10, 06:37 PM | #7 |
That makes sense.
| New Reply |
| Thread Tools | |
Similar Threads for: Inexpensive alpha emitter?
| Thread | Forum | Replies | ||
| Prove alpha=sup(S) is equivalent to alpha belongs to S closure | Calculus & Beyond Homework | 4 | ||
| Common emitter amp and BJT base-emitter resistance question | Electrical Engineering | 4 | ||
| BJT common emitter collector to emitter reverse bias confusion | Electrical Engineering | 2 | ||
| Common emitter ampl. with emitter resistor degen. | Electrical Engineering | 0 | ||
| New inexpensive incendiary device | General Discussion | 14 | ||
