New Reply
Flow rate/ Bernoulli's equation
Share Thread Thread Tools
Nov22-10, 08:10 PM   #1
ap physics student, on this for the first time
The flow rate of water through a garden hose is 60 cm3/s, and the hose and nozzle have cross sectional areas of 5.1 cm2 and 1.6 cm2 respectively.
(a) If the nozzle is held 11 cm above the spigot, what are the flow speeds through the spigot and the nozzle?
spigot
cm/s
nozzle
cm/s
(b) What is the pressure difference between these points? (Consider the water to be an ideal fluid.)
Pa
I think that it is bernoulli's but I could be wrong
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov23-10, 06:30 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi creamypies! welcome to pf!
(try using the X2 icon just above the Reply box )
Quote by creamypies View Post
Yup, (a) is geometry, and (b) is Bernoulli's equation (for which you need the speeds from (a)) …
what do you get?
New Reply
Thread Tools
Similar Threads for: Flow rate/ Bernoulli's equation
Thread Forum Replies
fluid mechanics - flow through a pipe (bernoulli equation) Engineering, Comp Sci, & Technology Homework 0
Deriving equation for ideal fluid flow problem (~bernoulli equation) Introductory Physics Homework 0
Bernoulli and darcy equation in split flow system Mechanical Engineering 14
Flow rate+Bernoulli Advanced Physics Homework 1
Gas flow rate, Bernoulli Classical Physics 8
