| New Reply |
thrust in propeller engines |
Share Thread | Thread Tools |
| Dec8-10, 08:44 AM | #1 |
Can anyone help me?
I'm doing a question on aircraft propulsion technology and i'm stuck. The question is: 'If the mass of air through a propeller is 1000 Kg/s, the aircraft's velocity is 100 m/s and the slipstream velocity is 120 m/s, calculate the thrust? Attempt at answer: Surely if F = ma then the equation should be F = 1000 * 100 = 10000 Kg/s But I don't think this is the right answer as I have not taken the slipstream velocity in to consideration. The only other equation I can find is F = (m dot * V)e - (m dot * V)0 + (pe - p0) * Ae But I don't have pe or p0 or Ae neither do I understand what they are. Can someone please steer me in the right direction? Thanks |
| Dec8-10, 01:01 PM | #2 |
Hi, with the given conditions, thrust can be calculated by using the formula:
Thrust = Mass airflow X (slipstream velocity-aircraft velocity). Below website has good information may be it helps you. http://www.flightlearnings.com/basic...-part-two/384/ |
| Dec8-10, 01:36 PM | #3 |
Thanks very much.
It seems so simple now, just couldn't see it. Thanks again |
| New Reply |
| Thread Tools | |
Similar Threads for: thrust in propeller engines
| Thread | Forum | Replies | ||
| Propeller thrust | Aerospace Engineering | 3 | ||
| Pulse Jet Propeller Thrust Calculation | General Physics | 0 | ||
| Propeller Thrust | Mechanical Engineering | 5 | ||
| Propeller Thrust Equation | Mechanical Engineering | 0 | ||
| Propeller and thrust | Mechanical Engineering | 8 | ||
