Behavior of particles in water
The discussion revolves around the sedimentation behavior of particles with varying densities in an aqueous environment, particularly in the context of biological experiments involving yeast growth under high artificial gravity. Participants explore the principles of buoyancy, sedimentation rates, and the implications of gravity on biological processes.
  • Experimental/applied
  • One participant inquires about the sedimentation differences of particles with different densities and how to calculate their sedimentation speeds in relation to gravity.
  • Another participant suggests consulting Wikipedia for information on buoyancy and sedimentation coefficients, indicating that predictions may be limited to simple particles.
  • A biologist shares an experimental observation where yeast grew normally at high artificial gravity (up to 2000g), challenging expectations about growth limits under such conditions.
  • Discussion includes the potential implications of ribosome density and behavior under high gravity, with one participant hypothesizing about the mechanical interactions between ribosomes and mitochondrial membranes.
  • There is mention of the standard protocols for ribosome purification and the challenges of studying ribosome behavior at lower gravitational forces compared to typical centrifugation methods.
  • Participants express interest in the mechanical properties of mitochondrial membranes and propose calculations for the forces exerted by ribosomes under high gravity conditions.
Participants express a range of views on the effects of gravity on biological systems, with some agreeing on the need for further exploration of ribosome behavior while others highlight the limitations of existing studies. The discussion remains unresolved regarding the specific impacts of high gravity on yeast growth and ribosome mechanics.
Limitations include the dependence on specific experimental conditions, the complexity of biological systems under varying gravitational forces, and the unresolved nature of mechanical properties of mitochondrial membranes.
Researchers and students interested in biophysics, gravity-related physiology, sedimentation processes, and experimental biology may find this discussion relevant.
schmittm
I am looking for help on how to determine sedimentation differences of particles of different densities in a aqueous environment. Will particles of different densities sediment at different speeds, and how can that be calculated. Anotherwords something with a denisty of less that one will clearly float up, while higher densities objects will sink until they hit the bottom. Is there way to determine their speed of movement and how it would change with changes in relative gravity. I suppose at 0 gravity a life preserver will not float and rock will not sink. Thanks in advance for your help.
Thank you for your links I appreciate it and they were helpful. Let me back up a bit and explain why I am asking. I am a biologist, so this physics stuff is killing me. I had a undergrad working in my lab and she wanted to do a different experiment. She decided she was going to test the growth limits of yeast, S. cerevisiae at high artificial gravity. It took sometime, but she was able to use a swinging bucket centrifuge to maintain petri plates at constant speed. After 2 days of spinning she would check the yeast for growth. I expected them to stop growing at 50-100 g, but that was not the case. Indeed they formed colonies on agar and grew at normal rates all the way up to 2000g. We would have gone higher, but we were limited by the speed of our centrifuge, cracking plates and media that failed to hold together. Either way it was impressive. To follow that up we ran our set of 4800 yeast mutants that are all each deleted for one gene, to identify genes that might confer sensitivity when knocked out. She pulled out 24 genes like this and 13 were part of the mitochondrial large subunit ribosome, which is a 50S particle and part of the whole 74S mitochondrial ribosome. Statistically, the p-value of her pulling these out at random is improbable. Turns out the mt-ribosome has a high density 1.64g/ml and high s-value. Most proteins are in the 1.2 g/ml range. Our best hypothesis is that the mutants lead to uncoupling of the subunits. Free subunits could be acting like projectiles or maybe battering rams would be a better analogy.
Any one have any comments or ideas?
I'm interested in the topic of gravity-related physiology, but don't work in it directly. Try these groups-although I didn't see yeast specifically, I'm sure it's used as a model system:
http://www.nasa.gov/mission_pages/station/research/experiments/Genara-A.html
http://gateway.nlm.nih.gov/MeetingAbstracts/ma?f=102234727.html
http://www.aeroi.org/iss_epp/files/Hammon.pdf
http://www.biomedsearch.com/nih/Hippocampal-gene-expression-modulated-by/14984417.html
48 h @ 2000x g is impressive! Is there a reason you can't grow them directly on/in agar-filled tubes? I think you can determine the differential "force" between the two subunits based on the (equivalent) masses 50S/75S and the acceleration (2000xg), but according to my "magic book" (Wilson & Walker's "Principles& Techniques of Biochemistry and Molecular Biology", it appears that ribosomes don't separate out until 100,000 x g and higher.
Yeast has not been much used as a model system for gravity related physiology. There has been some studies looking at resistants to very high g forces for short periods of time, but never anything to look at the limits of actual growth and division. We don't use tubes, since it would limit us to one strain per tube. We actually use rectangular microtiter dishes that have 1 well. These allow us to plate using robotics 384 different strains on a single plate. We are able to screen the entire collection of yeast deletion strains with only 20 plates.
The standard protocol for ribosome purification is through differential centrifugation and involves pelleting ribosomes at 100,000Xg for 4 hrs or 160,000Xg for 90 minutes. My guess is that in our situation (at 2000Xg) many of the ribosomes will be pressed against the mitochondrial inner membrane. I would like to be able to calculate the force these ribosomes are pushing on that membrane to see if it would be enough to punch a hole in it. This would theoretically kill the cells.
Thanks again for your advice.
I know the mechanical properties of lipid bilayers has been measured to death, but I don't think anyone has measured the mechanical properties of the mitochondrial (double) wall.
In any case, the force would be [itex]\Delta\rho V a[/itex], where [itex]\Delta\rho[/itex] is the difference in density between ribosome and the surrounding fluid, V is the volume of the ribosome and 'a' would be the acceleration: 2000x g.
  • · Replies 29 ·
  • · Replies 131 ·
9K
  • · Replies 20 ·
