New Reply
Finding basis of spaces and dimension
Share Thread
Feb28-11, 08:50 PM   #1
1. The problem statement, all variables and given/known data
Find a basis for each of the spaces and determine its dimension:
The space of all matrices A=[a b, c d] (2x2 matrix) in R^(2x2) such that a+d=0
2. Relevant equations
3. The attempt at a solution
So I jumped at this question without knowing too much about spaces and dimensions, but:
I think a possible combination of basis can be: [1 0, 0 0]. [0 1, 0 0]. [0 0, 1 0] (not sure if [0 0, 0 -1] would be considered since d would be negative in this case) Also from that I assume the dimension is 3?
Truthfully even if I got it right, I do not even know what happened. Can someone conceptually tell me what I am doing exactly?
Thanks in advance.
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Feb28-11, 08:54 PM   #2
Recognitions:
Homework Helper Homework Help
you need to come up with a basis, that has elements, such that any 2x2 matrix with a=d can be written as a linear sum of the basis elements.
clearly the basis elements will need to satisfy being a 2x2 matrix with d=a, you first element does not
Feb28-11, 08:55 PM   #3
Recognitions:
note this is entirely equivalent to considering 4 component vectors in R^4, with x_1 = x_4
often the vector form is easier to conceptualise
Feb28-11, 09:04 PM   #4
Quote by lanedance View Post
Can you explain to me how d=a, since a+d=0?
Also since I am actually having a hard time learning this on my own, can you tell me what you mean by "elements" and "linear sum"?
Mar1-11, 01:52 AM   #5
Recognitions:
Quote by maximade View Post
good pickup, should be a = -d
if you're not familair with those terms, you may need to do a bit of reading.. though i have been a little loose with terminiology
in post #4 i actually meant component and have changed accordingly
a basis, is a set of vectors that spans a vector space
an element is a member of a set, for example a vector in the basis set
a linear combination (or sum) is a vector addition with scalar multiplication
eg. if u,v are vectors, and a,b are scalars, then
w = au + bv is a linear combination
a set, S, of vectors spans a space if any vector in the space can be written as a linear combination of vectors in S
Mar1-11, 07:03 AM   #6
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
From a+ d= 0 you get d=-a as you say. You can then write
[tex]\begin{bmatrix}a & b \\ c & d\end{bmatrix}= \begin{bmatrix}a & b \\ c & -a\end{bmatrix}[/tex]
[tex]= \begin{bmatrix}a & 0 \\ 0 & -a\end{bmatrix}+ \begin{bmatrix}0 & b \\ 0 & 0\end{bmatrix}+ \begin{bmatrix}0 & 0 \\ c & 0\end{bmatrix}[/tex]
and the dimension and a basis should be clear.
New Reply
Tags
basis, matrices, space
Similar discussions for: Finding basis of spaces and dimension
Thread Forum Replies
Topological spaces and basis Differential Geometry 4
Basis and dimension: Need help finding my mistakes Calculus & Beyond Homework 8
finding a basis and dimension of a subspace Calculus & Beyond Homework 5
dimension of vector spaces Linear & Abstract Algebra 3
Finding a basis for vector spaces Precalculus Mathematics Homework 2
