Dale
Mentor
- 36,878
- 15,840
It is more likely that I am arguing against your misunderstanding of an entire scientific discipline. But if you are correctly understanding the discipline then the discipline is in error. It will not be the first time.selftaught said:You'd be arguing against an entire scientific discipline.
Exactly, which is why you should try something else.selftaught said:The reference to 'exposure' proves problematic, as you can see, when explored.
A falling body's energy is maximum at the top of the fall, energy has been transferred to it by the elevator. During the fall there is little or no energy transfer at all. Assuming a rigid surface almost no energy is transferred to the ground and the injury is maximum. Assuming a very soft surface a large amount of energy will be transferred to the ground and the injury will be a minimum. In either case the ground does not transfer energy to nor do work on the body, the body transfers energy to and does work on the ground, resulting in a reduction of injury. The energy transfer theory is not very successful here.selftaught said:And in this one paragraph you've uncovered my dilemma. 'Transferred' - explain that in terms of energy and landing from a fall. Force is involved in impact, and KE is pre-impact.
And you are having difficulty in that reconciliation because the definition is fundamentally bad.selftaught said:Given the definition of injury in terms of energy exposure, exchange, or transfer, I'm then attempting to reconcile any impact explanation with the initional pre-impact injury causeing energy.
