Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #2,971
PietKuip said:
That blog entry is correct. See also http://nucleardata.nuclear.lu.se/nucleardata/toi/nuclide.asp?iZA=520429 for data on Te-129m
The incredible thing is that Tepco do not understand their own measurements. See also http://www.nytimes.com/2011/04/06/world/asia/06tepco.html
Such a company should never have been allowed to operate a nuclear reactor.
So they messed up with Co-56 vs I-134, Cl-38, and Te-129/129m. And TEPCO is not sure about the Te-129 :rolleyes:
That certainly does raise concern. :rolleyes:
I've seen site and utility management replaced over much lesser problems.
  • #2,972
@Tcups;
From your post #2936:
https://www.physicsforums.com/showpost.php?p=3230713&postcount=2936
"The reactor vessel is now mostly dry, really, really (red?) hot, and making hydrogen and oxygen."
and
"Gas in the primary containment ignites"
How does hot fuel make Oxygen? And where does the Oxygen needed to ignite Hydrogen in primary containment come from?
Please look again at my Mar25-11, 02:31 PM post #1227 on page 77 of this thread:
https://www.physicsforums.com/showpost.php?p=3209718&postcount=1227
For your theory to be justified, we need to resolve the question of how Oxygen becomes available within primary contaiment in sufficient volume to satisfy Hydrogen's UEL (considering the presence of steam). This issue has STILL hot been addressed.
Tyroman
PS: In that post, where I say;
"When Hydrogen burns (explodes), there is one molecule of Oxygen for each molecule of Hydrogen;"
I obviously meant -
"When Hydrogen burns (explodes), there is one molecule of Oxygen for two molecules of Hydrogen;"
BTW, when I was in Armor, we referred to an armadillo as "A rat with a tanker's MOS."
  • #2,973
Ian:
I've got over twice as many posts as you. Ha
"Having watched the video of reactor 3 explosion, it is evident that a lot of material blasted upwards came down in the vicinity of reactor 3. We already have the hypothesis that the FMH went ballistic and arced back to the north end of unit 3. May I suggest that other heavy "stuff" is visibly returning too and it is this that caused the perforations to the roof of turbine buildings 3 and 4."
I agree. That heavy roof came down somewhere and it might have been on the turbine roof.
In some of the photos there appears to be a directionality of debris from the east side of the reactor building. Look that over and see where the smaller puncture hole to the NE looks to be offset from that debris flow.
Looking over the superstructure of Reactor 3 there was a fair bit of steel that left the building. Wonder where that came down?
Maybe someone with double my posts will respond.
  • #2,974
As to panel trajectories from Unit 3...
Sketches I made some time ago but didn't post are attached. These were intended as a reply to a much earlier question about the origin of an almost intact panel leaning against the building just East of the turbine building.
The specific panel in question probably was a Southmost-East facing panel from either the top or second row of panels of Unit 3.
BTW - perspective does make it difficult to judge the source...
  • #2,975
This just in from TEPCO (May be a duplication)
At 5:38 am on April 6th, we observed the stoppage of the water spilling
from the crack on the concrete lateral of the pit. Details of the
situation will be announced after checking the blockage of the water
flows.
We will continue the countermeasure in order to prevent further outflow
of high level radioactive materials to the ocean.
From http://www.tepco.co.jp/en/press/corp-com/release/
Bob S
  • #2,976
There is no shortage of oxygen in the containment is there, it is air after all? Steam is factored when determining the hydrogen deflagration/detonation ranges of H2 in air. The presense of steam limits the ranges for explosion, but does not eliminate it.
  • #2,977
I hope it's a matter of translation problems and/or exhaustion of the tech workers, and not a matter of incompetence. Finding high levels of very short-lived isotopes (indicative of on-going fission) should have set off some mental alarms in the engineering/technical staff, prompting a lot of double-checking.
With talk of entombment in some circles, this raises a concern in my mind. The process of setting/curing concrete is exothermic. Could entombment result in insufficient cooling of fuels, leading to unanticipated problems? Coming at this from a civil/mechanical mind-set with NO experience in nuclear leaves a lot of questions.
  • #2,978
I just took a look at the satellite photos from post-tsunami, but pre-explosion. I'm not positive, but I think that that horizontal structure you are indicating was actually already there pre-explosion: I don't think that that is a panel from the reactor building. Check the attached image and see what you think. It looks to me like a drive-under weather shelter, perhaps, like a carport.
I'm looking to see if I can find a better image- but I think that that structure predates the blast, rather than somehow having survived it intact and come to rest there. What do you think?
On edit- added two more that also look tantalizingly as if that structure was already there. The last image, fuku3_6a.jpg, is a photo from prior to the earthquake and tsunami.
Having said that, I can see where my initial idea about trajectories posted above was flawed. Thanks, all, for the education...
Original images: http://www.digitalglobe.com/digitalglobe2/downloads/featured_images/japan_earthquaketsu_fukushima_daiichi_march12_2011_dg.jpg
https://lh6.googleusercontent.com/-...00/japan_fukushima_daiichi_after_03_14_11.jpg
  • #2,979
@Homer Simpson
The issue to be resolved is two-fold... What is "Hydrogen's UEL (considering the presence of steam)."? And what is the source of the Oxygen (as I remember, the primary containment is filled with N2)?
What we do not know is the relative (by volume) composition of the three gases (H2, O2 and H2O) in containment and whether that composition would support combustion.
Within your experience, how would we go about answering these issues?
  • #2,980
Emreth said:
I seriously doubt that the FHM can go ballistic like that. It's a slim and heavy structure that can not provide enough resistance to the expanding gases which would would just flow around it. It's like putting something inside a cannon which does not fit snugly, not enough momentum will be transferred to the object. I think with the first explosion, which is somewhat directed sideways, the FHM might be hurled against the north destroying that side, depending on the blast location, i assume would be close to SFP. In the top views of reactor 3, i also saw some green areas in the SFP, maybe those are pieces of the FHM as well. The first explosion looks kind of dirty compared to a hydrogen explosion, the fireball is very red/yellow, maybe the mixture was poor in oxygen. The implosion from that seems to trigger the secondary explosion. It might be a steam blast when a low gas density/vacuum formed in there. The explosion seems the pulverize a lot of the concrete stuff, hence the dirty dusty look. I think parts of the ceiling trusses are what are coming down afterward.
You are probably correct. After all, how could a blast like the large column rising in the center of this photo lift and toss aside something as massive as a fuel handling machine. BTW, what is the approximate size of that, uh, kind of green looking . . . "what are you-call-it" or "thingamabob" falling there to the right of the massive vertical column of the blast at unit 3?
http://i306.photobucket.com/albums/nn270/tcups/Falling-FHM.jpg
BTW, did you catch the earlier extensive photo analysis back there a few days ago where several of us spent hours lining up the towers, the sun, and the buildings to figure out where that long, green looking thing came down? That may have been wrong too, I suppose.
  • #2,981
@tyroman,
Hi, my experience is nothing really, only that candu's have h2 igniters for this reason, mind you there is certainly no N2 cover gas for containment in candu's ...check the below link incase you haven't come across a chart such as this one... page 7/42
http://canteach.candu.org/library/20044507.pdf
  • #2,982
Hell, maybe I am wrong about the blast coming out of the primary containment. Now that M. Bachmeier has pointed us toward the consideration of littoral explosions (you know, like the one that blew a few cubic miles of Earth out of the side of Mt. St. Helens a few years back?)
http://www.worldtravelattractions.com/wp-content/uploads/2010/10/Mount-St.-Helens-eruption-1980-300x200.jpg
Would you describe the eruption from the SFP at Unit 3 as "Vesuvial"? Most likely not.
http://toxipedia.org/download/thumbnails/442/Vesuvius1822scrope.jpg
And after all, there was no dirt and rocks in Building 3, well -- only other stuff (concrete, asbestos, odds and ends and such). And hot fuel rods and hot magma don't have anything much in common, except, what? . . . Heat?
Sorry for being so sarcastic -- just tired this evening. But somehow my gut tells me that there was hydrogen below, hydrogen above, superheated water in the SFP and a blow-out of the fuel transfer gate touched the whole shebang off like a John Lee Hooker blues tune.
  • #2,983
Ya, let's calculate how much power could be in the blast?
Maybe "(60bar, 400C)= 3177.2 kJ/kg" or per liter. How many liters in primary containment at time of explosion? What was the pressure at the time of explosion? Either way it seems like enough power to put a small object in orbit...
See: http://me.queensu.ca/courses/MECH230/notes/documents/lect14-15.doc
  • #2,984
post 3000. Holy cow.
Chinese, Japanese,Dirty Knees, Look at these... posts
  • #2,985
flows.
Bob S
I'm glad they spotted the dye before it ended up in their coffee.
Laborer #1 & 2 will now be tasked to remove the 'injected' concrete (job security).
  • #2,986
For those wondering where the oxygen can come from. Water can also be split into hydrogen and oxygen by temperature alone. It occurs above 2500 C and can be catalyzed by metal oxides which lower the temperature required. When the rods in the core are not covered with water, they can reach these temperatures and produce both hydrogen and oxygen even if the zirconium cladding is already burned.
see http://en.wikipedia.org/wiki/Water_splitting
edit added better link
  • #2,987
Among other problems, the document raises new questions about whether pouring water on nuclear fuel in the absence of functioning cooling systems can be sustained indefinitely. Experts have said the Japanese need to continue to keep the fuel cool for many months until the plant can be stabilized, but there is growing awareness that the risks of pumping water on the fuel present a whole new category of challenges that the nuclear industry is only beginning to comprehend.
The document also suggests that fragments or particles of nuclear fuel from spent fuel pools above the reactors were blown “up to one mile from the units,” and that pieces of highly radioactive material fell between two units and had to be “bulldozed over,” presumably to protect workers at the site. The ejection of nuclear material, which may have occurred during one of the earlier hydrogen explosions, may indicate more extensive damage to the extremely radioactive pools than previously disclosed. ..."
http://www.nytimes.com/2011/04/06/world/asia/06nuclear.html?_r=1&hp"
  • #2,988
http://www.latimes.com/news/nationworld/world/la-fg-japan-nuclear-20110406,0,2697428.story"
Fishing of sand lances has been suspended. Local fishermen called on Tepco to halt the release of radioactive water into the sea and demanded that the company compensate them for their losses.
  • #2,989
flows.
Bob S
Now Tepco managed to dam the underground flow,
I wonder how long it will be for the next spring to appear.
  • #2,990
TCups said:
And we never saw that wench again after the explosion.
There are some large orange-painted metal parts on the ground, between reactors #3 and #4, that could be pieces of the fuel handling machine. Additional pieces may have been covered by roof debris.
  • #2,991
I_P said:
From the same article
The assessment provides graphic new detail on the conditions of the damaged cores in reactors 1, 2 and 3. Because slumping fuel and salt from seawater that had been used as a coolant is probably blocking circulation pathways, the water flow in No. 1 “is severely restricted and likely blocked.” Inside the core itself, “there is likely no water level,” the assessment says, adding that as a result, “it is difficult to determine how much cooling is getting to the fuel.” Similar problems exist in No. 2 and No. 3, although the blockage is probably less severe, the assessment says.
It's worth reading the whole article. Combined with the thermal production of hydrogen and oxygen from steam, this explains why they wanted to add N2 gas into the reactors.
  • #2,992
I have asked this on twitter and got no answer, perhaps here: Does TEPCO have any nuclear engineers on its payroll? Or do they sub-(and subsub-)contract the entire operation of their nuclear plants?
  • #2,993
robinson said:
Is there any doubt at this point, that the pools are full of debris? And damage to the spent fuel rods is certain?
In the TEPCO helicopter flight over the Units the Helicopter spends the least amount of time over Unit 1 . My guess is radiation readings where so high he got out of there quick . But on the #1 video by TEPCO at 30 seconds the helicopter films what looks like left side of Unit 1 where the spent fuel pool should be and it is full of debris or covered with debris . At this 30 second mark you can see a bright red glow coming from a small point in this location . It looks like something is super heated on or under the debris at this point . If you go frame by frame in the video you can see it good . It stands out from everything else .
  • #2,994
@Homer Simpson
Excellent reference you posted!
First question;
Most references I have seen give UEL at STP which would not apply within a hot - pressurized containment vessel... so, in Figure from R. Heck et al showing "Ignition tests performed with Siemens igniters." what were the temp/pressures for the tests? Can this be infered from the Steam Vol. % ?
Second question;
On the attached Heck diagram, how would you read the three Vol. % values for the point circled in red (just beyond the transition area)?
  • #2,995
Now you have the mechanism for the initial fireball at the southeast corner, a ballistic FHM, damage to the equipment pool, blown out upper building, and blown out lower building including the access tunnel, all without a gross breech of the RPV (ie, melted fuel melting through the steel of the RPV).
Debunk that.
  • #2,996
I know it's innappropriate but why do I keep hearing the William Tell Overture ? "BOOM!"
  • #2,997
Such a company should never have been allowed to operate a nuclear reactor.[/QUOTE
But that does not explain the blue glows above the reactor building.
  • #2,998
What is the long building in the background middle left ? It has no damage after tsunami . Now it looks like the end has been blown open .
  • #2,999
I've been following this thread since the beginning. I've seen all the analysis. The thing looks greenish but it might just be because it's in the shadow. I think it falls somewhere farther than the building anyway. The mushroom cloud is as wide as the building at this point and the object goes beyond.The remains of the FHM looks like scattered little pieces at the north end on the top view image.
There is probably enough force in the blast to launch an object that size but can that force be efficiently converted into momentum? I don't think so. The expanding gas when imparting the required acceleration to go that high would probably cause very high inertial forces that would rip it into small pieces, if the shock wave didn't already do it . It's like putting a dynamite next to it. Smaller pieces like the truss parts might survive it because they are lighter.
But maybe I'm wrong, FHM might be a very light structure welded out of bunch of metal sheets.
  • #3,000
tyroman said:
@Homer Simpson
Daams paper is interesting, seems a bit shortsighted in light of current events. Not design but possible outcomes. Saltwater and sand I didn't see addressed and (heated) brine is the worst when it comes to plumbing.
I only apply my extremely limited general knowledge towards it.
Suggests grating (air flow/venting) the floors instead of using solids (like concrete), now he tells us.
Suggest nitrogen gas will not cool as well as steam. That could be a problem if pressures are at the margins.
Only touched on dispersal concerning air temps and inversions. He did say, higher reaching plume the better. (I'm think'in stratosphere)
If they do inject nitrogen, I think they are trying to prevent more than just another hydrogen explosion...what could possibly go wrong?
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
469K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
16K
12K
