Does the presence of torsion require a non-symmetric metric?
  • Context: Graduate
  • Thread starter Thread starter pellman
    Metric Torsion
The discussion centers on the relationship between torsion and the symmetry of the metric in the context of differential geometry and general relativity. Participants explore whether the presence of torsion necessitates a non-symmetric metric, examining implications for geometry, parallel transport, and the physical interpretation of connection coefficients.
  • Some participants argue that if torsion is defined as the anti-symmetric part of the connection coefficients, then the metric must contain an antisymmetric component due to the nature of the connection coefficients.
  • Others propose that the connection with torsion can be expressed as a sum of the Levi-Civita connection and an additional term that accounts for torsion, raising questions about the physical significance of this additional term.
  • A participant suggests that torsion leads to a new kind of geometry that differs from Riemannian geometry, causing vectors to rotate under parallel transport, which does not occur in torsion-free geometries.
  • Some contributions mention the coupling of gravity to fermions as a mechanism that can generate non-zero torsion, indicating a relationship between torsion and intrinsic spin in matter.
  • There are discussions about the non-metricity tensor and its implications for parallel transport and the preservation of lengths and angles, with some participants noting that non-zero non-metricity would prevent local Minkowskian structure.
  • One participant highlights that while the Levi-Civita connection is torsion-free, more general manifolds can exhibit torsion, suggesting that the connection's behavior is not solely determined by the metric.
Participants express differing views on the necessity of a non-symmetric metric in the presence of torsion, with no consensus reached on the implications of torsion for the geometry or the physical interpretation of connection coefficients.
Some participants note that the discussion involves complex mathematical relationships and assumptions about the nature of connections and metrics, which may not be fully resolved within the thread.
pellman
If torsion = anti-symmetric part of the connection coefficients, and
[tex]\Gamma_{\alpha\beta\gamma}=\frac{1}{2}(g_{\alpha\beta,\gamma}+g_{\alpha\gamma,\beta}-g_{\beta\gamma,\alpha})[/tex]
then doesn't the metric have to have an antisymmetric component? The first two terms on RHS are together necessarily symmetric in beta and gamma. The only asymmetry in the beta and gamma indeces can come from the third term.
You can probably find old references that refer to antisymmetric components of the metric (Einstein was one that used that language). Today, we'd distinguish a connection with torsion from the Levi-Civita connection (which is the unique torsion-free Riemannian connection) above by writing
[tex] \Gamma_{\alpha\beta\gamma}=\frac{1}{2}(g_{\alpha\b eta,\gamma}+g_{\alpha\gamma,\beta}-g_{\beta\gamma,\alpha}) + \gamma_{\alpha\beta\gamma},[/tex]
where [tex]\gamma_{\alpha\beta\gamma}[/tex] contains the torsion.
Thank you, fzero. Can you justify that some from a GR point of view. Mathematically it's cool because we can do anything we want, but in GR everything is contained in the metric. Do you know what the physical interpretation of an extra term added to the connection coefficient would be?
Torsion implies a new kind of geometry different from riemann's. And it causes vectors to rotate in specific circumstances which does not happen in corresponding non-torsional geometry(riemannian) in same circumstance. Take connection coefficient to be [tex]\Gamma_{ijk}= a_{ijk}+b_{ijk}[/tex]. I have changed some notations...a is riemann connection coefficient made out of symmetric metric, and b is the one with torsion. Now define a transport of a vector [tex]n_{i}[/tex]along a vector [tex]m_{i}[/tex] to be defined in terms of [tex]\Gamma[/tex] as-
[tex]n_{i}(t+dt)= n_{i}(t) + m^{j}\nabla_{j}n_{i} dt[/tex]
where [tex]\delta_{i}[/tex] is covariant derivative with respect to torsional connection. Here 't' parametrizes the curve along which [tex]m_{i}[/tex] tangent.
It is easy to see the effect of torsion now. If [tex]a_{ijk}[/tex] were zero, that is metric were constant, above transport could be written as-
[tex]n_{i}(t+dt)= n_{i}(t) + b_{ijk}m^{j}n^{k} dt[/tex]
Thus we are now in 'minkowski' space-time with a torsion. Its just to demonstrate the effect of torsion, so things be better simple.
Now choose [tex]m^{j}= (1,0,0,0)[/tex] or vector pointing in 'time'(no absolute notion of time intended), and let [tex]n^{i}(t)[/tex] be [tex](0,x(t),y(t),0)[/tex]. Note that I don't care about covariant and contravariant components since metric is constant, and can be assumed to be [tex](-1,1,1,1)[/tex].
So write everything as-
[tex]x(t+dt) = x + b_{101}x dt + b_{102}y dt[/tex]
[tex]y(t+dt) = y + b_{201}x dt + b_{202}y dt[/tex]
[tex]z(t+dt) = b_{301}x dt + b_{302}y dt[/tex]
z is the last component of vector n. Since b is antisymmetric in indices i,k, being the antisymmetric component of connection, choose it in following way(as an example) - [tex]b_{101}=b_{202}=A, b_{102}=-b_{201}=B[/tex], Rest other terms zero.
Thus equations are-
[tex]x(t+dt) = x(t)*[1+Adt] + y(t)Bdt[/tex]
[tex]y(t+dt)= -x(t)*Bdt + y(t)[1 + Adt][/tex]
[tex]z(t+dt)=0[/tex]
Thus rotation is clear here, along with possible change in length of vector. Thus torsion causes rotation even in minkowski space-time, when transported along a vector, which does not happen in torsion-free minkowski space-time. Generalization to general space-time is easy. Choose locally flat metric.
In physical sense, I am not sure, but I guess people tried to incorporate spin using torsion. It is easy to see why. We have [tex]G_{uv}=T_{uv}[/tex] . If 'intrinsic spin' is present, then we need stress tensor to have an antisymmetric part. This means [tex]G_{uv}[/tex] must have antisymmetric part, which is provided by torsion.
It is known that coupling gravity to fermions can generate a nonzero torsion. This is discussed for example in Ramond's QFT book. The basic idea is that fermions couple to the spin connection, rather than the Levi-Civita connection. One can also couple gravity to an antisymmetric 2-form (what Einstein and others saw as the antisymmetric part of the metric) which also generates torsion under certain conditions.
fzero...
It seems really interesting. Could you give more details. Particularly gravity to antisymmetric 2-form coupling by Einstein and all.
It is not clear to me if this has already been answered: what is [tex]\gamma_{\alpha\beta\gamma}[/tex] and what is its physical significance?
And is the connection coefficient above still consistent with [tex]\nabla_\mu g=0[/tex]?
I think its consistent becos-
[tex]\nabla_{i}g_{jk}= \partial_{i}g_{jk} + \Gamma_{ijx}g^{x}_{k} + \Gamma_{ikx}g^{x}_{j} + \gamma_{ijx}g^{x}_{k} + \gamma_{ikx}g^{x}_{j}[/tex]
Contract with metric, and last two terms vanish out of antisymmety. SO its the same condition on metric as in non torsional case.
I think physical interpretation of torsion relates to rotating vector when transported along another vector (my previous post). I would be happy to know if there is a deeper interpretation of it.
This thread might be a tad old, but I'm just adding my two cents for anyone that is still interested.
Generically speaking, there are 2 independent notions that can be defined on a (Riemann-Cartan) manifold:
1) The metric, for determining infinitesimal lengths
2) The connection, for determining parallel transport. (Note that parallel transport is determined in its entirety. This includes the possible effects of there being rotation of a vector when parallel transported)
While we're at it, we can also determine the covariant derivative of the metric,
[itex]Q_{\mu\nu\rho} = \Delta_\mu g_{\nu\rho}[/itex]
This is the non-metricity tensor. One can work with manifolds where this tensor is non-zero.
If, however, [itex]Q =0[/itex] then that means that under parallel transport, infinitesimal lengths and angles are preserved under parallel displacement. Also, this is the condition for local Minkowskian/ Euclidean structure to be valid. If the nonmetricity tensor were not zero, one could not presume that the manifold were locally Minkowskian/ Euclidean.
The Levi-Civita connection, on the other hand, is the special case of the (locally Minkowskian) manifold which has 0 torsion. This need not be so at all in more general manifolds. In fact, in a torsion-free locally Minkowskian space, one can go to the non-coordinate basis (or the tetrad) locally, not by a coordinate transformation, but by postulating that we have such a basis and that we can express it in terms of the coordinates at the point being considered (as every vector in a linear space can). Hence, the tetrad field is nothing but the coefficients of these linear combinations.
Notice how, when the metric is reduced (locally, i.e. at a point, not in an open set about the point) to the Minkowskian form, we can also make it such that its derivatives = 0. So, if we were to do this in "standard" GR, where we work only with locally Minkowskian, torsion-free manifolds, we'd get the connection to be 0 (because the connection, which is the Levi-Civita connection in this case, is determined entirely by the metric and its derivatives). That such a transformation is indeed possible (making metric trivial and derivatives =0) is a non-trivial proposition, and a good (sketchy) proof is given in the book by Carroll. (on pgs 73-74)
While it is possible to get rid of the connection in this manner in standard GR, we do not get rid of the curvature because we do not have enough "degrees of freedom" to remove the second derivatives of the metric as well.
Now we return to more general spaces. While in standard GR, the connection = 0 locally, in spaces with torsion, it is not possible to get rid of the connection. This is because the connection also depends on the torsion tensor (the dependence is denoted by [itex]\gamma_{\alpha\beta\gamma} [\itex] in one of the posts above). For non-zero torsion, the local connection does not vanish, even though the metric is locally Minkowskian. This is the origin of the spin connection.<br /> <br /> It is possible to connect spinors to GR (and potentially describe rotating black holes with spin and mass) which is not possible to do easily with the usual coordinate basis. For those interested, there is an excellent article in Rev. Mod. Phys. by Hehl et al. The link is here:<br /> <a href="http://rmp.aps.org/abstract/RMP/v48/i3/p393_1" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://rmp.aps.org/abstract/RMP/v48/i3/p393_1</a><br /> <br /> A very good exposition in my opinion and definitely worth reading even if you are mildly interested.<br /> <br /> We now return to the tetrads and can attempt a sort of conceptual understanding of things. In spaces with torsion, we clearly have more degrees of freedom. If we parallel transport a vector on the manifold, and it rotates, then this degree of rotation yields these additional degrees of freedom. The so-called integrability conditions are then a measure of "non-commutativity" of the tetrad basis - what happens when we transport one way and then the other? So, in answer to one of the earlier questions - there are now additional degrees of freedom - in addition to the specification of the metric, we'd also need to specify the torsion (or the spin connection)<br /> <br /> It is of historical interest to note that what the Cosserat brothers (and henceforth adapted to GR by Cartan) did was to assume that any elastic medium had not just the displacement field, but also a rotation field. Assume we had a perfectly (linearly) elastic, isotropic body, obeying Hooke's law. If we stretched it in one direction, the usual laws of elasticity would determine the displacements in the transverse directions as being equal (depending on the Poisson ratio). If, in addition, the medium were such that at each point a local moment were present (as opposed to just a non-zero force density) then we'd clearly need to describe the response of the body to an external moment. So we'd need further constitutive relations in addition to Hooke's law for determining the complete state, which now contains both the displacement field and the rotation field (rotation at each point)[/itex]
  • · Replies 19 ·
  • · Replies 21 ·
