Circuit completion : is it necessary?
  • Context: Undergrad
  • Thread starter Thread starter AlchemistK
    Circuit
The discussion revolves around the necessity of completing a circuit for current to flow, particularly in the context of a light bulb connected to a battery. Participants explore concepts related to voltage, charge, and potential difference, as well as scenarios involving static electricity and grounding.
  • Some participants assert that a closed circuit is necessary for current to flow and that a bulb will not glow if only one terminal is connected to a battery.
  • Others challenge the notion that a battery has a "higher charge" relative to a bulb, emphasizing the importance of potential difference instead.
  • A participant suggests that a negatively charged body might cause a bulb to light, raising questions about static electricity and current flow.
  • There are discussions about whether a battery can drain if one terminal is connected to the Earth, with conflicting views on the necessity of a complete circuit for current to flow.
  • Some participants propose that if a battery is buried in the ground, it might drain due to the conductivity of the earth, while others argue that a complete circuit is still required.
  • Concerns are raised about the speed of electron movement and whether any visible effect, such as a bulb glowing, could occur under certain conditions.
Participants express differing views on the necessity of a complete circuit for current flow, with some insisting it is essential while others propose scenarios where current might flow without a complete circuit. The discussion remains unresolved, with multiple competing perspectives present.
Participants reference various assumptions about charge, potential difference, and the behavior of electrons in circuits, but these assumptions are not universally accepted or clarified, leading to ongoing debate.
  • #91
AlchemistK said:
So the only problem is that a battery requires electrons to return back to the other terminal to show any significant movement of charges.
Any voltage source that does not show this property?
No. All voltage sources require a return.
  • #92
voltage sources
Have a care with the use of this term.
I think you mean a general device which supplies electrical energy.
However the term voltage source has a much narrower and more precisely defined meaning in circuit theory.
Incidentally much confusion arises when special definitions from circuit theory are introduced into a discussion about physics and vice versa.
Circuit theory is much more specialised and limited than Physics and in particular makes certain assumptions for ease of analysis and calculation, that are not realisable in the real world .
  • #93
Ahh, and to actually answer the question.
Evil Bunny said:
Here is a question that I think is related to this discussion... Let's ignore static electricity and talk about only the voltage potential from the battery:
Did you ever understand how 'battery electricity' relates to 'static electricity' ?
If we connected a copper rod (let's say 3cm diameter and 1 meter long) on it's end to the negative pole of a 12 V battery that was sitting on a well insulated platform and we encapsulated the positive pole of the battery (in an effort to rid ourselves of any stray capacitance), would electrons "rush" up to the tip of that rod to "equalize" the charges of the negative pole and the copper rod?
that is depend to which potential the negative pole was at, what potential the rod was at, and what stray capacitance both the positive and the negative pole have vs the rod and the ground. The charge that would flow equals to capacitance between the rod and both of the battery poles, multiplied by the difference in potentials. If the capacitance is zero, the charge will be zero.
The OP is clearly trying to find a relation between his knowledge of 'static electricity' and 'battery electricity', into some sort of unified understanding. Assuming that parasitic capacitances are zero does not permit unified understanding.
The situation is such that e.g. 2 A*h battery has a charge of 7 200 Coulomb stored chemically inside.
The stray capacitance of, say, 1pF at potential difference of 12v stores 0.00 000 000 012 Coulombs.
That is why it is very common to neglect stray capacitances when discussing batteries.
edit: whoops mixed up mAh vs Ah
  • #94
with respect to what?
You keep talking about potential as if you can have it at one point. You can't. Potential at one point is with respect to another point... In this case we're talking about the potential between the rod and the negative pole. This potential is ZERO VOLTS in this case. No current flowed. No light bulb lit.
The ground is irrelevant. we're on an insulated platform. The positive pole of the battery is irrelevant. we encapsulated it.
You're trying to invent capacitance where it doesn't exist.
The answer to the question in post #1 is the bulb absolutely will not light. No way it can. This stray capacitance that may or may not exist will in no way provide enough current for any glow to occur.
  • #95
Potential is taken at one point, its the potential difference which is relative.
The electric potential at a point in an electric field is defined as the work done in moving a unit charge from infinity to that point.
  • #96
This thread has bi-polar disorder, I think. On the one hand we have the transformer / live/ neutral discussion and, on the other hand, we have the connect a battery and what happens discussion. Whilst it's all 'Electricity', they two ideas are interfering with each other. It's OK for someone who knows about these things but, for someone fresh, it makes things much harder than necessary.
The power engineering discussion is made complicated by the fact that the neutral we all know and love in the UK is fairly different from the Neutral that goes into many US homes. Essentially, the Neutral which a three phase distribution system takes very little current, when the three phases are loaded equally. This keeps the Neutral volts pretty near Earth all the time. The Neutral that goes into the US home, as I understand, comes from a local transformer which is centre tapped to give both a 110V and 220V supply. It is, inherently, not balanced and, depending on the lopsidedness of a typical domestic load during the day, you could expect some much higher volts on a Neutral. You really don't want lots of Earth currents sloshing around your domestic pipes and steel frames as it can cause embarrassing Hum, for a start. Current in the Neutral cable runs right next to the Live current and there is much less magnetic field generated. So - using the Neutral for return makes sense - else, why not have a single line supply to the home and rely on Earth as a return? Think of the copper you'd save!
  • #97
1: Check electric potential on wiki.
http://en.wikipedia.org/wiki/Electric_potential
2: I was speaking of difference of potentials. Not a single result depended on the absolute potential (which i suppose is defined as energy of unit charge brought in from far outer space)
how do you encapsulate something to totally eliminate the capacitance?
I'd really love to know, because i am building some electronic circuit where I have to calculate capacitance of every piece of wire.
I told already that an incandescent lightbulb won't light up, but if the voltage is, say, 200v, and if it is a neon lamp, and if capacitances are realistic, it will lit up briefly and visibly (in a dark room).
  • #98
Dmytry said:
1:
Exactly. And every piece of wire you hang on the battery will acquire a small charge. It's hard to reduce stray capacitance to less than one or two pF.
I find it bizarre that we are discussing picoCoulombs on the one hand and Mains supply currents on the other.
  • #99
Evil Bunny said:
If we didn't ground anything, then you could touch the neutral all day without danger. You caould also touch the "hot" or "live wire" all day without any danger. You aren't completing the circuit. As I explained above... the only danger we have messing around with power lines at our house is due to the fact that we intentionally "ground" the neutral wire at just about every power pole (in the US anyway) in the country and again at every service entrance to every house. There is a good reason for this that could take up an entire new thread, but for the sake of this conversation, the ground is completing the circuit (EDIT FOR CLARIFICATION: when you touch a powerline at your house, not under normal operating conditions) because the power company intentionally designed the distribution system that way.
I'm not sure about this. If the neutral wire weren't grounded, I think you would still get shocked if you simultaneously touched the neutral wire (or the hot wire) and a piece of metal plumbing that goes to the ground. But because the neutral wire is grounded, you can touch the neutral wire and a piece of plumbing and be fine. You seem to be saying that if the neutral wire weren't grounded, then the only way to get shocked is to touch the hot wire and the neutral wire at the same time (you could touch the hot or neutral wire [but not both] and the plumbing at the same time and have no fear), which is consistent with your one-terminal battery connection position, but I don't think that's right.
Also when you say you can't get shocked by touching just the hot wire, I'm doubtful about that too. I understand there is a lot of resistance between you and the ground, but I hear a lot of warnings about not sticking your finger in the socket. The current would have to travel through you, through the floor, and through metal piping which sounds like a lot of resistance, but it only takes a little current to kill you.
  • #100
rcgldr said:
Apparently some of the current flows back through the neutral and its Earth ground points (in addition to the breaker panel, also in transmission transformers). What I don't get is if current is flowing back through the neutral and Earth ground, and if the ground wires are also tapped into the earth, then why is there a neutral to ground voltage of up to 10 volts when measured at an outlet, and also why are the "neutral" wires insulated, while the ground wires are bare copper wires?
I have no idea why neutral wires are insulated. If anything only the hot wires need to be insulated.
The fact there is 10 volts between the neutral and ground suggests that maybe you are right and neutral only connects to the center tap, where it has been reduced to 10V with respect to the ground by previous transformers. But according to hyperphysics, the neutral and ground wire are physically tied together at a location and driven into the ground before the center-tap location.
I don't understand why a third prong is needed for ground. Can't you just plug the chassis of an appliance directly to neutral? Or is that what is done? Because I notice some appliances only have two prongs. Does this mean the chassis of the appliance shares the same connection to neutral as the appliance itself, i.e. two wires connect to the neutral prong?
  • #101
This, as I have already said, is because the neutral is a three phase invention. Letting it float is good for keeping the transmissions on each of the three phases balanced. Anybody disagree with that?
Three phase generation is a great invention but it does generate a lot of conceptual problems.
  • #102
Ok... let's simplify the circuit.
You have a battery and a resistor. You connect one end of the resistor to one terminal of the battery. Does anything happen? No. No complete circuit. No current flow.
Now replace the battery with an AC source. No grounds, no plumbing, nothing but an AC source with two terminals. Now... connect one end of that same resistor to only one terminal of the AC source. Does anything happen? No. No complete circuit. No current flow.
Now replace the resistor with yourself... see my point now?
Introducing "ground" into the conversation complicates things and confuses people...
They carry just as much current as the hot wires in the branch circuits of your house under normal operating conditions.
The neutral is connected to the center tap. It's also connected to a ground rod at your service entrance and at the utility pole. Again... the reason you measure a small voltage between the "ground wire" and the neutral in your house is because of voltage drop. You are only allowed to connect the neutral and the "ground wire" together at the service entrance. You are not allowed to connect them together anywhere else in your house (per the NEC in the US). The further away from the service entrance you get, the greater the voltage reading will be between neutral and the "ground wire".
RedX said:
I don't understand why a third prong is needed for ground...
For safety reasons.. In the US there never used to be a 3rd prong and everything worked just fine, except that under fault conditions metal appliances had voltage present with respect to ground and it was potentially dangerous.
They added a "ground wire" (third prong) that bonded all the metal things in your house together and tied it together with the neutral (at the service entrance) to create a parallel path back to the source. The reason they did this was in case of a fault, this current would travel back along the low resistance "ground wire" back to the source instead of through your body. If you simply tied everything to the neutral, then under "normal conditions" you would have current flowing through the neutral AND through all of the metal things in your house. This is not a desirable situation.
  • #103
Yes I do... I will try to explain further later... no time right now... I just touched on it a little bit in my previous post
  • #104
If the neutral were allowed to float anywhere and a low resistance load applied to one of the phases then the volts on the other two phases could end up as 400V instead of 240V. That would not be good. Why does no one else consider the three phase thing in this discussion? There is no major system of electricity generation that does not use three phases so it is a major consideration.
  • #105
Most houses (if not all) in the US are wired with single phase. Yes, it originates as three phase (upstream) but we're only using one of the phases. This third prong on the plug receptacles that people are calling the "ground wire" (whose technical term is an "equipment grounding conductor") has absolutely nothing to do with the neutral whatsoever. It is used for bonding the metal parts in your house.
  • #106
I know that you're only using one of the phases but other users are using the other two phases and the neutral is common to all users and the system has to work as a whole. This neutral conductor is sure to be near Earth potential, for symmetry reasons. If you look at massive electrical distribution lines there is one tiny 'fourth conductor' which is strung from pylon to pylon.
As you say, the reason for a local ground / Earth is to give you something to hang all exposed metal onto. This means that you can never get many volts between yourself, your feet and anything you are likely to touch as long as you are not actually poking about inside some equipment.
  • #107
Could a moderator split up this thread into two threads then?
  • #108
A lobotomy?
  • #109
Evil Bunny said:
They [the neutral wire] carry just as much current as the hot wires in the branch circuits of your house under normal operating conditions.
If you touch the neutral wire and plumbing, nothing happens, so there should be no need for insulation.
If you touch the hot wire and plumbing, you'll get shocked. So the hot wire ought to be insulated.
If you touch the hot wire and the neutral wire, you'll get shocked, so at least one of them should be insulated.
So if you're only going to insulate one, wouldn't it make more sense to insulate the hot wire?
Or is the insulation for fire reasons? Wouldn't the hot wire and the neutral wire get to the same temperature?
  • #110
neutral wire insulated
For one thing it allows a person to keep track of which wire is the neutral (black insulator) and which one is used for grounding (bare wire). And I assume the voltage difference you see between ground and neutral at an outlet is due to the resistance in the path from outlet netrual wire to panel ground, back to outlet on ground wire, and what ever capacitance effect all those grounded appliances have.
  • #111
@evilbunny
The neutral will take no current for the 220v equipment.
  • #112
Correct. When I said branch circuits I meant 120V circuits. Important point and careless on my part.
  • #113
You're insulating both. The hot and the neutral. Sometimes you're even insulating the "ground wire". The hot is black insulation. The neutral is white insulation. If the "ground wire" is insulated at all, it will be green insulation (In the US)
The reason, again, is that the neutral carries current just like the hot. You don't want bare wires with current on them strung through your house. If there's a fault, everything metal is a potential danger. Arcing could be a problem as well... I would say that, yes, risk of fire is probably at the very top of the list as to why they insulate.
In the US, the black insulator is the "hot" or "live" wire. The neutral is white. The ground is either green or bare wire.
This part of the conversation has been jumping all over the place. We were talking about grounding and bonding, now we're talking about the reason for a neutral in a 3-phase wye power distribution system.
I didn't realize this is the angle you were coming from because when you first said this it was in response to a question about the third prong (the grounding prong) in an outlet at someone's house.
Here, you seem to be discussing the reasons for grounding the neutral on the distribution side of a massive power system supplying neighborhoods. I would agree that this is probably one of the major reasons they ground the neutral in such a system.
On the other hand, I don't really think it's relevant to why we ground the center tap on the secondary (user) side of the transformer.
  • #114
So why do you think this is grounded?
  • #115
I am not familiar with US practice but if both legs are feeding loads there will still be less neutral current. The neutral would only carry the. 'difference current'.
  • #116
The neutral conductor between the service entrance and the transformer will only carry the "difference current". But in each branch circuit that is 120V (between the loads and the service panel) the hot conductor and the neutral conductor will carry the same current. These are the majority of circuits in a typical house and these circuits constitute most of the wires running through the structure of your house.
As for the reasons for grounding... there have been many books written on the subject. One of the most popular books on the subject seems to be https://www.amazon.com/dp/1890659363/?tag=pfamazon01-20.
The 2011 National Electric Code paragraph 250.1(A)(1) states:
"Electrical System Grounding. Electrical systems that
are grounded shall be connected to Earth in a manner that
will limit the voltage imposed by lightning, line surges, or
unintentional contact with higher-voltage lines and that will
stabilize the voltage to earth
during normal operation."
(emphasis mine)
So, I would offer that as the reason for grounding...
  • #117
I reckon that sums it up quite well.
  • #118
stabilize the voltage to Earth during normal operation."
Well thank you for the reply.
However my understanding of the above wording is that it does not constitute a reason.
Nor does it require grounding.
It merely states a manner of grounding if the electrical system is grounded.
So that is not the answer to my question.
  • #119
This is a transatlantic problem. We (UK) don't have this centre-tapped system because we use 230V only. The neutral in the UK is part of the three phase distribution system - right up to the end of the street - from which houses are fed in groups of three, all the way up, with one phase each. Hence my comments about protecting the other two phases from over-volts (to Earth, that is) under a fault condition by grounding the neutral somewhere.. 'Your' 110V system seems to have many disadvantages compared with using twice the voltage, as is done in Europe and many other places. I guess it's historical and too late to change now.
  • #120
I think it is grounded to limit the voltage imposed by lightning, line surges, or
stabilize the voltage to earth.
by this I mean that we want unintended high voltages and lightning to be routed AROUND the wiring in the house and not to go THROUGHOUT the house and destroy property and cause injury.
You are welcome.
I have reworded it to make it sound more like an answer. Hope that helps.
Nor does what require grounding? In the US, our entire distribution system is grounded. Our houses are grounded. This is a requirement by law in this country. So... depending on what your definition of "require" is, this may or may not be a true statement.
As every dwelling in the United States is grounded.
I hope I have clarified it a little better for you.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 35 ·
12K
  • · Replies 16 ·
