Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #7,201
MadderDoc said:
No, and that's what strikes me as odd. It is as if this RPV is suspended in empty space at absolute zero- Otherwise I cannot see how one can avoid involving a term representing the temperature of the environment. A blackbody is something that would absorb all radiation incident on it, if I understand that term? It would seem to have to emit that amount of energy again plus the internally produced heat in order to reach an equilibrium temperature. I think.
Yes ,but :
- considering that the environment is a heatsink and therefore in equilibrium it contributes to an equivalent constant inward flux of 419 W/m^2 (at 20 degrees celsius) , therefore this is a negligable amount considering the uncertainties of the whole.
We can extrapolate likewise for higher temperatures in the surrounding containment :
100 degrees Celsius containment would amount to an additional 1100 W/m^2 above the 15100 W/m^2 for reactor 2 and 3 , thereby increasing the temperature line to 475 degrees from 445 degrees calculated before , so that would be +30 degrees celsius
  • #7,202
swl said:
Does it look to any of you like the ignition point might have been outside the upper southwest corner?
I think no one can claim to have actually seen the ignition. It would seem to me to be an extraordinary claim that the ignition point was outside the building. I would like to hear about the supposed mechanism for such occurrence before even considering it.
  • #7,203
Jorge Stolfi said:
I have fallen behing with my plots due to other work. But now I wonder whether it is worth keeping them updated.
For one thing, TEPCO has been releasing a lot more readings and more often, including plots; and other people have been doing it too.
More seriously, the latest news about #1 mean that *both* its water level readings, for the past two months, were garbage --- not inaccurate, not biased, not noisy, but just total garbage. Since the readings for #2 and #3 have similar values and behavior, it is very likely that they are garbage too. (Indeed the black smoke event for #3 sems to coincide with some major event in the RPV emperatures and other variables --- a core breach perhaps?)
Now what trust can we put in the other measurements? I have this mental image of a room somewhere in the reactor building, half-full with water, with a big chunk of fallen concrete in the middle and all the pressure and water level gauge pipes disappearing under it. Or of the "RPV bottom" termocouple inside the drywell, hanging in mid-air by its wires, gently swaying under a drizzle of warm borated water from a ruptured pipe pipe above.
Anyway, I will think about it over the next weekend, when I have more time. Sorry... and all the best.
Thank you for all the work in maintaining your graphs. They've helped me to try to think about what's been happening. Even if I am 20 pages behind on reading this forum.
  • #7,204
NUCENG said:
The different photon energy possibilities are listed in the nuclide table. Other types of decays are also listed in the nuclide table with a description of the energy levels. just click on the decay type and it will give you the decay energy diagrams.
http://atom.kaeri.re.kr/index.html
Thanks again... I have some reading to do after Saturday chores!
  • #7,205
GJBRKS said:
Yes ,but :
Yes, I can understand that, and I agree this is a negligible amount.
Yes, I see, however now we are getting close to my pain threshold for negligible terms. In conclusion, if I understand this now :-), the calculation does strictly yield the maximum surface temperature of a RPV suspended in empty space at absolute zero -- but this is with good approximation the same as the maximum surface temperature in an environment (I assume, to be able to neglect other heat transfer, a low density environment, e.g. air), at up to about 100oC.
  • #7,206
turi said:
Does anyone here know how those water level sensors work? What could cause them to give erronous info (instead of simply appear offscale or stuck)?
My understanding is that when water gets low and the going gets tough in a reactor, there _is_ no well-defined water level anymore to measure. When the water level starts jumping up and down, its time for duck and cover.
  • #7,207
TCups said:
Or, might it simply imply that the pressure relief valves were bypassed, as by damage and subsequent rupture of one of the connecting feed lines, especially the high pressure steam lines near the top of the RPV? Would that not produce the same observations?
I had to think a bit before figuring out what you are saying and I may have misunderstood. I think you are arresting my statement that multiple relief valves would have to have failed too, and you are right. Funny thing though, to have relief valves that do not open before some 'blow-panel' in the high pressure steam lines gives in.
  • #7,208
TEPCO concealed radiation data before explosion at No. 3 reactor
Tokyo Electric Power Co. concealed data showing spikes in radiation levels at the Fukushima No. 1 nuclear power plant in March, one day before a hydrogen explosion injured seven workers.
The Asahi Shimbun obtained a 100-page internal TEPCO report containing minute-to-minute data on radiation levels at the plant as well as pressure and water levels inside the No. 3 reactor from March 11 to April 30.
The data has never been released by the company that operates the stricken plant.
The unpublished information shows that at 1:17 p.m. on March 13, 300 millisieverts of radiation per hour was detected inside a double-entry door at the No. 3 reactor building. At 2:31 p.m., the radiation level was measured at 300 millisieverts or higher per hour to the north of the door.
Both levels were well above the upper limit of 250 millisieverts for an entire year under the plant's safety standards for workers. But the workers who were trying to bring the situation under control at the plant were not informed of the levels.
http://www.asahi.com/english/TKY201105130370.html
  • #7,209
rowmag said:
English version says 3000 tons of water missing, Japanese version says 3000 tons of water found in basement.
So what now? Fill the basement with cement?
This NYT article makes passing reference to NISA announcing that 12 feet of water have been found in the basement:
http://www.nytimes.com/2011/05/15/world/asia/15japan.html?_r=1&hp
On Saturday, the Nuclear and Industrial Safety Agency said that it had found more than 12 feet of water in the basement of Reactor No. 1.
  • #7,210
I've always wondered about this "x or higher". Remember the first weeks when they often measured "999mSv/h or higher"? Is this made by limited personal counters?
Naive press people. Ahh.
I find it interesting that Tepco apparently covers some things up. There's no point in doing so, this series of events will likely undergo more investigative efforts than anything similar before. Not many hiding places except /dev/null. Unless this is just a lapse and not deliberate.
  • #7,211
Jorge Stolfi said:
You seem to be referring to a layer of ribbed sheet metal (aluminum?) strips that sits over the steel framework. Those strips look like bits of white fettucini in the aerial photos (some 8 meters long and less than 1 meter wide), and are scattered all over the place. a few of them are still attached to the steel frame of #4.
Above that sheet metal layer there seems to be a dark grey layer of concrete and/or tarmac. In the best photos of #4 one can see some ribbing on it too, possibly a negative cast of the ribbing on the metal sheets. That layer presumably is reinforced with rebar or wire mesh, because in #4 a chunk some 15-20 meters across was thrown up in the air, then sliced though the steel beams next to the north wall, and is still hanging there in one piece.
In #4 the entire concrete/tamac layer and almost all the metal sheets of the roof were blasted away. Part of the explosion indeed appears to have occurred in the 4th floor (below the service floor), but the only communications between those floors are the elevator shaft and four narrow stairwells at the corners. That is quite enough for the H2 to flow between floors, but hardly enough to transmit the explosion with such a force. Moreover the service floor slab of #4 does not appear to have been breached or even cracked (unlike that of #3).
I still cannot quite understand what hapened to the top of the north wall of #4. Its exterior paint seems to have been scraped down, and its top edge was pushed southwards (i.e. inwards) by several meters. I thought about the middle parts of the pillars being pushed out by the explosion and causing the tops to pivot inwards; but there does not seem to be anything in that location that could have served as the pivot, and I cannot see how the explosion could have pushed the middle of the pillars out without also pushing the top...
I use Nero 8 for video viewing which has a 'digital zoom' feature to outline an area to enlarge it (to the point of over pixelization). When I do that on the parapet wall closest to the camera of Unit 3 and include part of the roof before the explosion, I see the building breathing in and out. Since it hasn't exploded as of yet, I considered it to be steam releasing inside and condensing along with the pre-loading of other gases. Over pressure finally causes separation of the roof followed by a chain reaction.
Unit 4 doesn't seem to be afforded the pre-loading whereas the blast(s?) came first then the pressure, leaving everything just bent in one position with a kinda random destruction about the building. I don't think the remaining roof section ever got airborne as pointed out by a onetime poster/engineer/architect, just was moved by the wall pushing in.
I really doubt the use of aluminum for the roof panel sections, more like galvanized steel (zinc plating). I always thought Units 2,3 and 4 had a bit of over designed skinning but it is hard to reach a happy medium between earthquake and wind loads while engineering to release an internal explosion.
And while I'm thinking about it, the Unit 3 SFP video where just before the camera goes underwater, it shows the outside of the tank. The tank appears heavily painted or has a coating of some sort that appears to have bubbled due to heat.
Let me qualify all this with... what the hell do I know?
  • #7,212
Sorry for interrupting, but I have just one question. If the water leaks outside the structure, why they just stop putting tons of water inside ? Would the situation become really worst if they stop ? Thanks in advance for reply.
  • #7,213
Nobody knows for sure, but the reactors have not melted into piles of slag as far as we can tell.
Left entirely without cooling, they would. So the water injection is continued, because it may be helping.
This is why the US NRC head described the situation as 'static' rather than 'stable'.
It may be that the situation is at the threshold of a greater disaster if some incorrect action is taken or if something else in the site breaks, perhaps because of an aftershock.
TEPCO is certainly using a kid gloves approach, touching as little as possible and planning for a year long campaign to get to a cold shutdown, before a decades long cleanup.
Others, notably Michio Ishikawa, the former head of the Japan Nuclear Technology Institute, vehemently disagree with this approach and propose much more vigorous efforts, because the situation is worsening on the current course. See: http://www.gengikyo.jp/english/shokai/Tohoku_Jishin/article_20110413.htm
  • #7,214
#Fukushima I Nuke Plant Reactor 1 Bldg: 2,000 Millisieverts/Hr at Southeast Double Door, 3,000 Tons of Water in the Basement
1,000 millisieverts/hour on the 2nd floor was bad enough. And this was supposed to be the reactor that was well on its way to stable cold shutdown.
http://ex-skf.blogspot.com/
  • #7,215
New photo (taken May 13th) released by Tepco
http://www.tepco.co.jp/en/news/110311/images/110514_5.jpg
  • #7,216
Worker dies at #1 -- the cause is not clear
- At about 6:50 AM on May14th, 2011, a worker of a sub-contractor became a
bad health during a carrying work for drainage treatment system in the
Centralized Environment Facility. He was carried to hospital.
Radioactive substances were not attached to the worker.
http://www.tepco.co.jp/en/press/corp-com/release/11051410-e.html
Opinion about that photo from MadderDoc -- hard to believe that any part of #4 looks like that. Might it be #5 or #6?
Also from the same release above:
- From 1:00 pm to 2:37 pm on May 14th, we sprayed water into the spent fuel
pool of Unit 2 using the temporary motor driven pump. (from 1:08 pm to
2:02 pm, hydrazine was also injected).
Also radioactive density counts on the way up at #1 sub-drain:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110514e10.pdf
2 Sv/hr readings in #1 are not encouraging imo.
  • #7,217
7000 tons ?:smile:
  • #7,218
May 13th.
Please refer to "[Reference] Emergency Response Training at Fukushima Daini Nuclear Power Station" for the explanation of each picture.
http://www.tepco.co.jp/en/news/110311/index-e.html
  • #7,219
Note that this is from emergency training exercises being carried out at the Daini plant, as detailed here:
http://www.tepco.co.jp/en/news/110311/images/110514_11e.pdf
edit - Oops sorry triumph61 beat me to it.
  • #7,220
Why on Earth are they aerosolising the water with that shower head?
  • #7,221
That's a nifty feature of Nero 8. Can you using this same method check whether you can see the same phenomenon looking at unit 2 and/or unit 4?
I would very much like to see what it is you are looking at. There appears to be some metal structures or edges hanging out in the pool at shallow depth (They stand out by being large generally frame-spanningly,, blocking the view to the bottom and being rather less green than the rest we see, rather they are white/grey patched and reddish at the edges. There is a peculiar hook like shape of one of them, it looks like we see on its edge that it is concrete lined with thick metal My best idea so far is that we are looking at parts of the steel liner of the pool. If so, it looks rather more twisted and bent than I had imagined it to be, but curiously it does do not seem to have been hit by anything mechanical, no scratch marks or bumps.
But you know that you have fun doing this, eh? :-)
  • #7,222
It's just a joke. That is not real!
  • #7,223
Everything for the camera: the bunny suits, the gas masks, and the photographer wants to see some water please.
  • #7,224
I was hoping for someone to say something like this, frankly the photo had me quite confused, I had overlooked the footnote. Thanks.
  • #7,225
It's a paddling pool for their children filled by a garden hose.
Sorry for that not really technical response.
  • #7,226
They have to find ways to transfer water from the basement of the reactor buildings to storage facilities. It's difficult but perhaps not impossible? And even if it's not going to succeed they still have the sub-drain systems.
Regarding the ground water: we have to separate two things, the sub-drain system and the water below the sub-drain system.
The water in the sub-drain system is collected to the sub-drain pits and from there it is pumped to a storage facility and from there it is transferred to the sea (in normal operation mode, because the water is clean, no harm done here). This is a way to control the movements/levels of the ground water underneath the reactors.
So the sub-drain system to some extent takes care of the polluted water underneath the plants. This is what they have already done in units #5 and #6, they pumped the water up from the pits and transferred it to the sea. The water was low-level contaminated so TEPCO thought it was safe to transfer it to the sea.
As for the units #1 - #4, the groundwater is more polluted. So the problem arises: How much water has accumulated in the sub-drain pits? What is TEPCO going to do with that water? As long as the sub-drain system is still working OK, we can assume that the contamination of the ground water is still "under control".
In one of the papers TEPCO gave us a small hint what they are going to do with the sub-drain water underneath #1 - #4:
Treatment of sub-drainage water after being pumped up
http://www.tepco.co.jp/en/nu/fukushima-np/f1/images/f12np-gaiyou_e.pdf
(page 22)
But they have not given us any schedule, have they? This is one answer I am waiting from TEPCO, to give more detailed report of the sub-drains #1 - #4, their thoughts about where the polluted water has been coming and when they are going to empty the pits.
But there is also a more severe problem if some polluted water goes underneath the sub-drain systems. Some reasons leading to this might be: 1) The sub-drain systems do not cover the whole area of the plant. 2) The sub-drain systems might not work everywhere as supposed because of the tsunami/quake.
Underneath the sub-drain systems there is only the moving ground water, it's not under control. But even this situation is not necessarily a catastrophe. Because the inland deep well is not contaminated it gives us a hint that the ground water is moving towards the sea. This is also how it is usually supposed to work nea the sea, and the findings from the deep well support this scenario.
What would happen? The pollution in the ground water would dilute little by little into the sea probably not causing any dramatic rise in the radiation levels of the sea water. This is also what the overall trend has been after they were able to stop the mega-leak from the unit #2 pit to the sea: the radiation levels have been decreasing.
So what would actually happen, is this: the nature would take care of some of the cleaning processes of the Fukushima plant - even without TEPCO asking for it. :cool:
  • #7,227
(page 22)
Perceptive assessment, provided people realize that nature's cleanup cycle might be a lot slower than we would like. Seems the Fukushima Wildlife Refuge is well on its way to being realized, albeit contaminated both above and below ground.
  • #7,228
From P418, sorry to be so far behind!
RealWing said:
I agree that the industry has generally been underestimating the hazards from spent fuel pools, although at least the US appears to have taken some action to ensure means are readily available to add water. You can be sure that there will be industry wide changes to spent fuel pools and emergency cooling etc. The addition of simple spray headers above the pools has been discussed.
However, none of this matters if plants are not adequately designed for Beyond Design Basis Events (BDBE). All of this destruction and pool overheating was caused by all emergency power being lost to the units by a BDB tsunami event that flooded the emergency generators and switchgear that was located in the lower floor of the non-watertight turbine building.
The provision of readily available "ultimate" emergency power equipment will be the most significant change for the industry. One simply cannot tolerate (or afford) having no power to cool a nuclear reactor.
The industry is responding behind the scenes all around the world and addressing current emergency readiness and addressing the initial lessons-learned from Dai-ichi. Many more lessons-learned to come - just like what happened after TMI and Chernobyl.
I am a little less concerned with the plants being designed for Beyond Design Basis Events because of the amount of time it will take to deal with that. The planned response to Beyond Design Basis Events can be modified in a much shorter time period. As this thread basically discusses the results of an inadequate response to Beyond Design Basis Events does anyone have any information on changes to planned response to such events?
In order not to derail his thread you may respond here.
liam https://www.physicsforums.com/showthread.php?t=487336
  • #7,229
Using http://www.youtube.com/watch?v=UPQv7DF4q94" press pause or the space bar then put the mouse on the slider button to look at single frames (can't go step by step). Loading 'Download Helper' (a FireFox add-on) works well as it lists all the possible video media formats when available for download ex. flv, mp4 (found in Tools>DownloadHelper>Media).
If you just press and hold the 'Ctrl' and move the wheel button on your mouse, you can enlarge or reduce the screen. Good for a text reading or a quick pic enlargement.
Attached is a still .jpg along with an enlarged section captured of the roof corner of Unit 4 and Unit 3 closeup capture from the SFP video showing whatever it is: metal debris with paint or coating. Good high quality pics or video, gets you better quality captures or enlargements.
  • #7,230
New Kimono design to cover Fukushima embarrassment.
For Reactor Unit 1 - hopefully by end May 2011
[PLAIN]http://img263.imageshack.us/img263/5262/11051302.jpg
Report
https://www.youtube.com/watch?v=9Xi8c_UgB58
http://www3.nhk.or.jp/daily/english/14_02.html"
From what I remember of the details (which I can't find now) it was a heavy duty polyester rip stop fabric over a lightweight steel frame.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
469K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
16K
12K
