Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #9,661
Jorge Stolfi said:
My understanding is based on an analogy with optics. A white material such as milk, chalk, white paint, or clouds looks white because all the light that falls on it is scattered back to the open space on the illuminated side, in a random direction --- instead of being absorbed or transmitted to the other side. However, at a microscopic scale, most white materials consist of transparent particles in a transparent medium with a different index of refraction. So, a large part of the incident light is not scattered off the material 's surface; instead it enters the material, and is then refracted or reflected by its particles many times, random-walk style. The internal scattering has no preferred direction; but if there is no absorption and the material is thick enough, most of the photons will eventually come out of it *towards the same side they entered*. In other words, their U-turn is not deterministic but only a statistical event --- due to the fact that there is no scattering on one side of the surface.
By the same token, if one were to suspend a light bulb by a thin wire in the middle a thick fog bank, much of the light emitted by it will eventually come back to it --- simply because the wandering photons cannot end their trip in any other way. This is more obvious if the lamp is suspended in milk; but it should seem reasonable also for fog, when one considers that a thick enough cloud bank at noon will look black from below.
The same should happen to neutrons that escape a fuel mass completely surrounded by a large body of water, or any other moderating material: as long as we can ignore absorption and spontaneous decay in the water, most of them will eventually come back to the fuel, with thermal energies.
However, if there is some absorption in the surrounding material, not all neutrons will come back. This is analog to what happens to photons in materials like smoke or cappuccino, that contain light-absorbing substances together with light-scattering grains: the material will look gray or colored, instead of white. Also, if there are other absorbing objects (such as a concrete floor) immersed in the same medium and not far from the fuel, part of the neutrons will end up there before coming back to the source.
In the case of Fukushima, I believe that they are using borated water to cool the corium, instead of plain water; which in the optical analogy should be equivalent of suspending a lamp in china ink instead of milk, or in tire smoke instead of fog. However the uranium in the molten mass may be covered by some other material (iron and zirconium oxides?) whose "neutron color" I cannot guess.
As I said, my understanding is all based on this optical analogy. It may not apply at all to the situation.
I note your tremendous artistic talent in replying. Thank you.
I have always thought of is as ping pong balls and bowling balls. Ping pong balls (neutrons) will bounce off of heavier atoms (bowling balls) without losing energy, but will bounce off of Hydrogen atoms and impart some of their energy to the Hydrogen. I guess eventually they can be turned around.
  • #9,662
Yesterday, March 12th, past noon JST, there appears to have been further clearing of trees to the southwest of the plant, see attachment of photos of the plant looking in from the south (from 12:00, 13:00 and 14:00)
  • #9,663
For whatever it is worth, I have updated my plots of reactor variables for Fukushima Daiichi #1--#3:
http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/plots/cur/Main.html
I added markers to the plots showing the core meltdown times, as guessed in
the June 2011 report by the Japanese Government to IAEA
http://fukushima.grs.de/sites/default/files/NISA-IAEA-Fukushima_2011-06-08.pdf
They seem to coincide with sudden and definitive depressurizations of the RPV, as expected.
Reading the report, I was disappointed at the lack of any mention to the hiccup in #3's RPV pressure, on march 21 02:00, which is conspicuous in TEPCO's spreadsheets but apparently was not reported to NISA.
For over a month, the pressure readings for #1's RPV had been rising, and on june 3 they were over 600 kPa ("A") and 1600 kPa ("B"). On june 4 the "A" reading dropped suddenly to 128 kPa (27 kPa more than atmospheric) and the "B" sensor went dead dead. Presumably the sensors were recalibrated between june 3 and june 4.
The CAMS readings for the drywells are about 250 Sv/h (#1), 15 SV/h (#2), and 4 Sv/h (#3). That is sieverts, not microsieverts or millisieverts. Presumably all three reactors are leaking steam from the containment to the atmosphere. Are the "steam" plumes above the reactors made of this stuff?
  • #9,664
The test run of the water purifying facility starts tomorrow (June 14th) (instead of today as I previously read in the news), the launching of the facility is expected on June 17th or later according to nuclear department acting general director Jun'ichi Matsumoto : http://www.bloomberg.co.jp/apps/news?pid=90920019&sid=alOpyQW842bg ; Around June 18th according to http://www.chunichi.co.jp/s/article/2011061390141100.html
Low concentrations of curium were found in soil samplings in Okuma town 2 or 3 km away from the plant. This is the first time curium is found outside of the plant. It is a by-product of plutonium. The Education and Science ministry says it is a concern for internal exposure. Americium was also found, but it is a low and old deposit from nuclear weapon tests : http://www.tokyo-np.co.jp/s/article/2011061301000491.html
Strontium was found in ground water near unit 1 and unit 2, and in sea water at the intake of unit 3 where it amounted to 240 times the allowed concentration : http://www.fnn-news.com/news/headlines/articles/CONN00201327.html . 7,300 Bq/l (240 times the 30 Bq/l limit) for Sr 90 according to http://www.meti.go.jp/press/2011/06/20110612001/20110612001-7.pdf (Japanese)
The Japanese food and drug administration approved on June 6th two drugs used to cure ingestion of transuranic elements such as plutonium, but insists that it is not connected with the present accident as the approval had been requested before the earthquake. These medicines, which have already been approved in the US, France or Germany use a chemical property called chelation : http://www.yakuji.co.jp/entry23266.html
  • #9,665
I don't think we get far with qualitative pictures. The whole thing is a race between different processes. To make the high energy neutrons thermal collisions are required. Neutrons will on the average travel their mean free path between these collisions and they will be scattered in all directions and some of them will get absorbed, some of them will never come back to the corium. Surely, some of them come back to the corium as thermal neutrons and have a high probability of causing a fission reaction. Is the fraction of these lucky neutrons high enough for a chain reaction? I am not an expert but I doubt you can say anything without a quantitative calculation.
  • #9,666
I somewhere read that the tsunami at Onagawa NPP reached the footing of the plant, but not more.
I don't think that there would've been troubles as big as in Fukushima if the plant would indeed have been inundated.
First it's newer - from the early nineties. It's highly probable that it has more fancy security systems than Fukushima AND better tsunami protections.
But second you need more than a tsunami to kill a NPP. It's often overseen, but Fukushima Daiichi didn't lose cooling capability because of the tsunami. The station blackout happened because offsite power was lost due to collapsing electricity lines which were damaged by the earthquake.
If those towers would've withstood the earthquake, perhaps emergency cooling could've been sustained.
Did something similar happen in Onagawa? I'm not sure. But they provided shelter for tsunami refuges, so I don't think that they had no electricity.
  • #9,667
Fascinating. If we saw what happened at 11:00 and later on at 15:00 it might be even more insightful. How many trees have been removed? 10? 100? What does it matter?
  • #9,668
Bioengineer01 said:
This discussion reflects on the poor credibility record laid out by TEPCO, any apparent inconsistency needs to be explored to the limit to be sure we understand what is happening and the thermal images of Unit 4 have shown the inconsistency of higher temperatures at the site of the RPV/PCV for a long time.
TEPCO's inconsistency needs to be explored to the limit. What is the limit?
Bioengineer01 said:
I could point to lots of conspiracy theories created around that inconsistency.
Please don't.
  • #9,669
Exactly. Or rather - why did TEPCO cut them down? There must be a reason connected to the status of the plant, to contamination or something similar.
You just don't cut off trees to beautify the environment when you're threatened by four crashed nuclear reactors. Recent sat images of the perimeter would be helpful.
  • #9,671
If they need more space for water tanks, the wooded area uphill from units 1-4 would be a prime candidate.
  • #9,672
The newly created waste storing areas are shown on the map at the bottom of http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110609e8.pdf
  • #9,674
Excessive levels of strontium detected in seawater, NHK, June 13, 2011:
[...] TEPCO announced that strontium-90 was also detected for the first time in ground water near the reactors’ buildings.
A ground water sample taken on May 18, around reactor number 2, measured 6,300 becquerels per liter. And for reactor number one, the sample showed 22 becquerels.
TEPCO explained it usually takes about 3 weeks to analyze the samples.
Why exactly does it take so long to analyse water samples for strontium? Can't really think of an analyzing process that lasts three weeks.
  • #9,675
If the activity is very low, the counting must be increased to obtain reliable statistics, and usually one allows the shorter-lived radionuclides to decay away.
  • #9,676
unless, of course, there is a reasonable way of chemically isolating a
particular isotope from the rest of the sample.
  • #9,677
Quim said:
Let's not jump too fast here.
Forget the steam explosion for a moment, let's try and figure what vectored energy upwards.
I see only two possibilities:
1. a shaped charge sort of effect which I see as very unlikely because it would have had to have formed such a perfect 360 degree containment (in 3 dimensions)
or
2. the blast was contained by the walls of the fuel pond.
I can think of nothing except the two I mentioned above.
As regards the vectoring I think we could make a distinction between the vectoring of the ejected large objects, and the vectoring of the rising column and mushroom cloud.
Some of the ejected large objects do appear to have been vectored close to vertically upwards, however most of the ejected objects seem to have been vectored in a more southerly direction, some landing as far away as the 4-piped exhaust stack south of unit 4. Few if any objects were vectored significantly to the north of unit 3. So if there was a shaped charge effect or anything of that kind, the vectoring was not vertically up, but rather tilted to the south.
Otoh, it is clear from the video that the cloud _itself_ was vectored strongly vertically upwards. However I think this is just what one would expect from an expulsion of a mixture of hot water vapor and dust. For a start water vapor has -- other things being equal -- a much lower density than air, and this produces buoyancy, direction up. With hot water vapor this buoyancy is only further enhanced. Adding to this, in a rising and cooling column of water vapor filled with dust, water vapor will have easy access to the condensation nuclei, which are necessary for its condensation. Condensation of the water vapor will lead to intermixing of more air into the rising column, and the intermixed air will be heated by the release of the latent heat of condensation, again this produces more buoyancy for the rising cloud.
  • #9,678
I find it difficult to even believe that anyone with knowledge of physics looks at the blast and believes it was simply hydrogen burning. Or that it didn't damage the reactor, the fuel ponds, and almost everything else.
I mean, most of the building is simply gone. Not damaged, it's gone. The blast was so loud it was heard 40km away.
It should be possible to calculate exactly how much TNT it would take to create a blast like that. If Hydrogen alone can do that kind of damage, it might be time to change the physics books.
  • #9,679
robinson said:
It should be possible to calculate exactly how much TNT it would take to create a blast like [#3's]. If Hydrogen alone can do that kind of damage, it might be time to change the physics books.
This has been discussed before in this thread, and the amount of H2 needed was estimated. There were also photos of other industrial insallations wrecked by gas leaks.
Gas explosions are powerful indeed. In São Paulo (> 10 million hab) practically all kitchen stoves run on propane from portable tanks. There used to be ~1 explosion per day due to leaks from cracks in old hoses, worn-out valves, or improperly fitted connections. Typically the explosion would wreck the house or apartment. Now scale up from the volume of an average kitchen to that of the reactor's service space...
  • #9,680
I'm afraid it could be even simpler. The geometry of the blob may be such that it provides its own neutron reflection. In enriched Uranium, you can do fission with fast neutrons if you have enough of them.
  • #9,681
Large amounts of the building remain intact.
I am no expert in explosions, but I see plenty of impressive hydrogen blasts on youtube, and I know that one of the issues with using hydrogen as a fuel is safety.
People can talk up the explosion at 3 all they like, and attempt to discredit thy physics knowledge of others, it does not prove anything or help their case.
Science is being done a disservice via a disproportionate amount of focus on visual evidence. Estimated total radiation release into the environment, as per the calculations used to come up with an INES level, suggests that the vast majority of contamination came from reactor 2. Yet this is hardly discussed, perhaps because there is too much judging of reactors by their cover.
  • #9,682
You guys do realize that there's a thread which deals specifically with the Unit 3 explosion? How about you talk about that topic over there?
  • #9,683
clancy688 said:
Thanks. So they are cutting wood down to get space for their planned water processing plants and storage tanks.
Yes. It had been announced in late April in the Japanese media that the "Forest of Wild Birds" (1) was considered for cutting down to allow tank storage, calculating that a 30,000 ton facility requires a 15,000 m² area of land : https://www.physicsforums.com/showthread.php?p=3262303&highlight=forest#post3262303
(1) as translated into English on the soil sampling map: http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110422e16.pdf
  • #9,684
I'm afraid to ask this question, having not assiduously followed previous threads, but will try to phrase the question in the most learned and scientific way I can think of:
Why is Reactor #4 smoking?
http://www.tepco.co.jp/en/nu/f1-np/camera/index-e.html
(LARGE amounts of steam, possible smoke, with possible tongues of flame (unverified)).
  • #9,685
Would anybody care to join me in thinking about reactor 2 more this week?
Looking at most of the documents & attachments of the report to IAEA, there are a few things which suggest that reactor 2 was responsible for a very large percentage of the radioactive release into the environment.
OK we already knew the water was very bad at reactor 2, and that it leaked into the sea, and that we could estimate that something in the approximate region of 40,000-50,000TBq INES-converted release got out that way.
But on April 12th when the INES 7 rating was announced, it was also suggested that reactor 2 was responsible for most of this, and for this rating we are talking about air rather than sea. See for example the following news story:
http://english.kyodonews.jp/news/2011/04/84888.html
A considerable amount of the radioactive materials emitted is believed to originate from the plant's No. 2 reactor, whose containment vessel's pressure suppression chamber was damaged by an explosion on March 15, said Kenkichi Hirose, a Cabinet Office adviser serving for the safety commission, at a news conference.
''Our estimates suggest the amount of radioactive materials released into the air sharply rose on March 15 and 16 after abnormalities were detected at the No. 2 reactor,'' Hirose said. ''The cumulative amount of leaked radiation has been gradually on the rise, but we believe the current emission level is significantly low.''
Having checked back to this time period on this thread, and looked at various other discussions and news articles on the net, I do not feel that this detail received sufficient attention. For sure the sombre way in which reactor 2 suspected suppression chamber damage was announced, and the highly contaminated water found there, already indicated to people that reactor 2 was causing great harm, but it still feels to me like focus on this is frequently lost, often in favour of reactors where the visual is more alarming.
Some of the issues surrounding reactor 2 and its environmental consequences probably belongs in a different thread, but as INES ratings stuff has often been discussed in this thread I would like to at least draw attention to one aspect here.
Report to IAEA, attachment IV-2 http://www.kantei.go.jp/foreign/kan/topics/201106/pdf/attach_04_2.pdf
This is where the NISA 370000 TBq got upgraded to 840000 TBq.
On page 7 we see Table 5, which shows possible release to environment of a variety of substances, with values for each reactor. Substances such as Cs-137 and I-131 are orders of magnitude higher for reactor 2.
Now these numbers are based on analysis, and there are multiple analysis cases for reactor 2 which could have been chosen to use in this table, many of which would have given much lower numbers (see a little earlier in that doc for some detail). But I guess they picked this case for a reason, I imagine they swayed towards it because scenario used for this case seems likely, as well as actual radiation data from around the time period that reactor 2 was failing badly.
So, worthy of more attention?
  • #9,686
Conditions in the night are such that it looks steaming every day. My bet is that is mostly a matter of local weather - humidity and temperature changes. Fog clouds are moving in and out of the light, which makes the picture dramatic.
I have looked at the live feed at several occasions, never longer than just a few minutes, usually after someone raises alarm - and each time it looks the same to me.
Edit: it occurred to me that compression artifacts look like a dynamic smoke/steam cloud as well. Thats typical in low light conditions - dark, large spots with slight color gradient look like moving even if the image is still. It can look as a dynamic steam motion, even if the real situation is quite stable.
  • #9,688
before becoming alarmed by clouds coming out of the plant, one should google terms
'dewpoint fukushima'.
every time temperature and dewpoint get real close, 'net boards light up with reports of fires.
other night it happened even though temp and dewpoint were both 19C, humidity 100%, and local weather channel reported dense ocean fog.
old jim
  • #9,689
As the SPF for reactor 5 is above 80*C, it will steam copiously under most conditions.
Until the structural reinforcements under the pool are completed, that temperature will get higher still, as it is unreasonable to expect structural work to get done while radioactive water overflows from above.
  • #9,690
Certainly I am game, just wondering which aspects you want there to be thought more about :-). It appears to me that you are particularly interested in the air release from unit 2, which you think might account for the majority of the total air release, so perhaps that could be the first aspect to think about.
<..> on April 12th when the INES 7 rating was announced, it was also suggested that reactor 2 was responsible for most of this, and for this rating we are talking about air rather than sea. See for example the following news story:
The argument made there by the cabinet secretary seems pitifully inadequate, and indeed has a form that makes it look like a 'post hoc ergo propter hoc' fallacy. Very _much_ had been going on before those high levels were measured on the 15th and the 16th of March, and during this period smoke and steam were reported billowing out from several sources within the plant, not only, and not even mainly, from unit 2.
Report to IAEA <..>
There must be more than guessing and imagining that they picked this scenario for sound reasons.Taking things from this particular report on trust alone is for me quite out of bounds.
Perhaps. By which route/medium/mechanism should the majority of total air releases from the plant have escaped from unit2?
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
469K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
16K
12K
