Dice probabilities on opposed sets of 10-sided dice
The discussion revolves around calculating the probabilities of winning in a dice game involving two pools of 10-sided dice, where the number of dice in each pool can vary. Participants explore the mechanics of comparing dice rolls, particularly focusing on scenarios where the number of dice in each pool is unequal. The conversation includes both theoretical approaches and computational methods to derive these probabilities.
  • One participant seeks help in calculating the probabilities of winning for unequal pools of 10-sided dice, outlining specific scenarios and rules for comparison.
  • Another participant suggests using computer programming to solve the problem, mentioning the concept of "order statistics" and how it could be applied to determine winning probabilities.
  • A later reply discusses the possibility of using a Monte-Carlo simulation to generate data through numerous test rolls, emphasizing the need for a large number of trials to achieve accuracy.
  • Another participant proposes generating all possible vectors of order statistics and calculating their probabilities, detailing a method for comparing the outcomes of different dice pools.
Participants express various approaches to the problem, with no consensus on a single method for calculating the probabilities. Some favor computational methods, while others consider theoretical formulations. The discussion remains unresolved regarding the best approach to take.
Participants mention specific rules, such as the automatic discarding of rolls showing a 1, which may affect the calculations. There is also uncertainty about the appropriate formulas and methods for calculating probabilities in this context.
Sociopath
Hi,
I was wondering if anyone might want to help me with some less common dice probability. The dice mechanic is similar to the board game Risk (two sets of dice being compared), but the dice pools are varying numbers of 10-sided dice on either side (2 pools compared of a varying number).
I'm having a little trouble wrapping my head around how to get statistical probabilities of who wins on either side of the dice roll.
My needs involve finding the probabilities of the chances of winning on either side of the equation. To win, a die must be higher than it's counterpart from the other dice pool, and dice are compared highest to highest down the line.
For instance, if I roll one pool of 3 10-sided dice against a pool of 4 10-sided dice, I receive 8, 7, and 6 from pool one and 8, 5, 6 in the second pool. The highest are compared to the highest (8 = 8, 7 > 6, 6 > 5). Equal pairs cancel each other out, so pool one wins with 2 hits (2 of his dice exceeded the remaining two of the opponent).
If I recall correctly, opposing pools of equal dice have about a 50% probability of winning and a 50% probability of losing (the chances for any result on either side are the same across the board). What I don't know how to calculate is the probability of unequal dice pools in win/lose terms.
Values for the following is what I'm trying to figure out:
Probability of 1 die pool vs. 5 dice pool, probability of the 1 die at least cancelling out a hit from 5 dice (the 1 die exceeding all 5 dice, at least negating one hit).
Probability of uneven pairs...
- 1d vs 2d
- 1d vs 3d
- 1d vs 4d
- 1d vs 5d
- 2d vs 3d
- 2d vs 4d
- 2d vs 5d
- 3d vs 4d
- 3d vs 5d
- 4d vs 5d
...with win chances vs. bigger and smaller dice pools.
Some special rules (if anyone takes this up), a roll of 1 in any pool is discarded automatically; they don't exceed any die, and, being the poorest result possible, is discarded even if it does not have a matching die. So, any roll of 1 is automatically thrown out and not considered - except for the purposes of losing a die in your pool if it shows up.
I was thinking of doing probability of a theoretical 9-sided die, but I quickly threw that idea out because it would skew the results; using a 9-sided die would result in probability for the dice always returning higher than 1, which would not be the case.
I'd really appreciate help on this matter. I'm decent at math, but probability and statistics is a bit beyond my normal day-to-day.
Sociopath said:
I'm decent at math,
How are you at computer programming? This looks like the type of problem that can be solved that way.
When the results of N realizations of a random variable are sorted by their values from smallest to largest, this vector of outcomes is called the vector of "order statistics". If you roll five 10-sided dies then the probability of ( 9,8,5) being the "high three" of your roll is the probability of the event ( 10th order statistic = 9, 9th order statistic = 8, 8th order statistic = 5). If you look up "order statistics" on the web, you can find formulae for them.
The problem of computing who wins, attacked in a straightforward manner, involves looking at each possible vector of the top K order statistics from the smaller die pool versus each possible vector of the top K order statistics from the larger die pool and noting who wins and what the probability of this pair of vectors is.
I don't know if there is an elegant way to solve this problem with hand-calculations. If you want to try that approach, I suggest you look at some iteration scheme. For example, if we assume we know the answer for the case of M dies vs N dies, can we find it for M dies vs N+1 dies?
You bring up an interesting possibility with a computer program. I suppose I was searching for a formula and an elegant way to predict probability so hard that I overlooked the obvious possibility: simply generating large numbers of test rolls to provide data, making the amount of data so large that it could accurately predict outcomes in percentage chance values.
Would you have any recommendations for a number of rolls that could be considered enough to generate accurate results? I was thinking at least 10,000, but the more sets rolled, the more accurate the data would become.
Thank you for your reply, that really helped.
I wasn't thinking of a Monte-Carlo program, although that's always an option in probability problems. I was thinking of a program that would generate all possible vectors of order statistics and apply the appropriate formula to calculate their probability. If we can't figure out the appropriate formula, that could also be found by exhaustive enumeration.
For example, take 3 dice agains two.
Generate the 1000 possible vectors representing 3 dice rolls, find the order statistics that give the "high two" of each vector:
Roll | High Two
10 10 10| 10 10
10 10 9 | 10 10
10 9 8 | 10 9
... etc.
Then generate each possible vector that reprsents the "high two" and count up how many times it appears in this list of 1000. Each vector in list of 1000 has a probabiltiy of ( 1/ 10^3) so this allows us to compute the probability of each vector representing the "high two".
Do a similar process to find the probability of each possible "high two" from rolling two dice.
To find the probability that 3 dice beat 2 dice, go through the list of the possible "high two" for 3 dice. Compute the probability that the 3 dice produce that "high two" and the two dice produce a "high two" that loses. For eample, the probability that the 3 dice produce (8,7) and the two dice produce ( (8,6) or (8,5) or ... or (7,6) or (7,5)... )
Add up all those probabilities to get the answer for the probability that the 3 dice win.
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 41 ·
