Loop-the-Loop, work-energy problem
  • Thread starter Thread starter armolinasf
    Work-energy
The discussion focuses on solving the work-energy problem involving a car navigating a loop-the-loop. The minimum height H required for the car to complete the loop without falling off is established as H = (5/2)R, where R is the radius of the loop. For R = 20m and H = 3.5R, the speed at the top of the loop is calculated to be approximately 31.3 m/s, with a radial acceleration of 49 m/s². The tangential acceleration requires further analysis using Newton's laws to determine the net force at the top of the loop.
  • Understanding of gravitational potential energy and kinetic energy principles
  • Familiarity with Newton's laws of motion
  • Knowledge of circular motion dynamics
  • Basic algebra for solving equations
  • Learn about the conservation of mechanical energy in physics
  • Study the concepts of radial and tangential acceleration in circular motion
  • Explore Newton's second law in the context of circular motion
  • Investigate the effects of friction on motion in loops
Physics students, educators, and anyone interested in understanding dynamics and energy conservation in circular motion scenarios.
armolinasf
A car starts at a point A at a height H above the bottom of the loop the loop. It is starting from rest and we ignore friction.
A) what is minimum value of H in terms of R such that the car moves around the loop without falling off at the top point B.
B) If R=20m and H=3.5R calculate the speed, radial and tangential acceleration
A) total energy at A is equal to mgH. total energy at B is equal to mg2R + .5mv^2
Solving for H gives H=2R+v^2/2g. Minimum velocity at B is mg=(mv^2/R) V62=Rg
Substituting gives H=5/2R. Not sure if this is correct...
B) to find speed: mg(3.5R)=mgR+.5mv^2, masses cancel. v=sqrt(5gR)=sqrt(5*9.8*20)=31.3m/s
radial acceleration=5gR/R=5g=49m/s^2
I don't know how to find tangential acceleration...
Thanks for the help
yes, but be sure to right it correctly ... H = (5/2)R = 2.5 R
B) to find speed: mg(3.5R)=mgR ...
whoops, that's 2mgR + ...etc.
correct your error in calculating v
To find the tangential acceleration at the top of the loop, you should first find the tangential net force at the top of the loop, then use Newton's laws. What is the tangential (horizontal) net force at the top of the loop?
13K
