| New Reply |
Solar Panel testing |
Share Thread |
| May30-06, 09:18 PM | #1 |
Solar Panel testing
I have an interesting question:
Could we simulate the solar array operating under sunlight, by covering the solar panel with dark paper and using a constant current source to pass rated current INTO the solar panel (e.g. using a bench power supply on constant current mode with a DC link inductor if necessary). I will probably need a fan to cool the solar panel. I am not sure if this would damage the solar panel however. I could vary sunlight "intensity" by changing the value of the current passed into the solar panel. Regards |
| May30-06, 09:26 PM | #2 |
That just doesn't sound right to me, but I'm not an expert in electricity by any means. As far as I know, though, a solar cell won't pass electricity from an outside source. That would be similar to expecting an LED to produce current when exposed to its emission frequency.
| May30-06, 10:38 PM | #3 |
| May30-06, 11:24 PM | #4 |
Solar Panel testing ..
| May31-06, 10:24 AM | #5 |
Mentor
| May31-06, 08:35 PM | #6 |
Are you maybe thinking that solar panels work like Peltier Heaters/Coolers?
| Aug17-11, 07:14 AM | #7 |
I have done that and that worked. Actually it is called Dark I-V test. However I did not use for that purpose. I used to test my inverter under lab conditions without the sun. This does not damage the PV panel it even does not get hot. However you need a big power supply for that. Set the current exactly Isc from the data sheet of the PV module and set the voltage 10-20 percent higher than Voc.
| New Reply |
Similar discussions for: Solar Panel testing
| Thread | Forum | Replies | ||
| Solar Panel Deployment | Mechanical Engineering | 17 | ||
| Solar Panel to Recharge Hybrid batteries??? | General Physics | 1 | ||
| 45 W solar panel | Engineering Systems & Design | 1 | ||
| Collector Size of solar panel | Introductory Physics Homework | 4 | ||
| Solar Panel question | Electrical Engineering | 6 | ||
