New Reply
Archimedes's principle (Crown)
Share Thread Thread Tools
Nov13-11, 01:08 AM   #1
Hi all, I am so confused by the famous Archimedes's story of telling if the crown is made of pure gold.
As far as I understand from information posted in the internet, such as http://hyperphysics.phy-astr.gsu.edu/hbase/pbuoy.html
Archimedes first determines the volume of the crown by measuring the apparent mass when the crown is immersed into water by a mass spring for example.
Then the difference between the actual mass and the apparent mass will be the buoyant force, which is given by the volume of the crown * density of water.
From this, we know the volume of the crown.
And we can divide the actual mas of the crown by the density of water to get the density of the crown.
But can't one just measure the volume of the water displaced when the crown is immersed into the water, and that should be equal to the volume of the crown?
Can we get the volume of the crown that way?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov13-11, 07:35 AM   #2
Yeah, I can see your confusion.
Wikipedia's article on the word Eureka: http://en.wikipedia.org/wiki/Eureka states
'he reportedly proclaimed "Eureka!" when he stepped into a bath and noticed that the water level rose—he suddenly understood that the volume of water displaced must be equal to the volume of the part of his body he had submerged. This meant that the volume of irregular objects could be measured with precision, a previously intractable problem.'
And that is how he originally determined the density of the crown.
I think that later on he continued researching it and came up with the whole buoyancy force is the difference between the actual weight and apparent weight, which is the weight of the displaced water deal. And that is known as the Archimedes' principle (described in http://en.wikipedia.org/wiki/Archimedes%27_principle)
Hope that clarifies things a bit.
New Reply
Thread Tools
Similar Threads for: Archimedes's principle (Crown)
Thread Forum Replies
Archimedes' Principle Introductory Physics Homework 3
Archimedes' Principle-Gold Crown problem Introductory Physics Homework 4
Archimedes' principle... Introductory Physics Homework 1
Archimedes principle again. Introductory Physics Homework 14
[SOLVED] Archimedes Crown Question Introductory Physics Homework 2
