New Reply
spring with two objects
Share Thread
Nov19-11, 08:57 AM   #1
1. The problem statement, all variables and given/known data
Object A (1 kg) and B (3 kg) are forced together,
initially compressing a spring S between them by 6 cm;
then the system is released from rest. The spring with
k=1250 N/m is not fastened to either block and drops to
the surface after it has expanded to its unstretched position.
a) By assuming frictionless surface, what are the speeds of objects after the spring has expanded
to its unstretched position?
b) Assume that the surface is frictional with s=k=0.1. If object B has speed of 0.2 m/s at 0.5 s
after the system is released from rest, what should the speed of object A be at this time instant?
(Hint: Consider “center of mass of a system” concep
2. Relevant equations
W=1/2kx^2
F=k.x
K=1/2mV^2
3. The attempt at a solution
i'm having trouble with this energy thing. i tried 1/2kx^2=1/2mv1^2+1/2mv2^2
i found 37,5=1/2v1^2 + 1/2v2^2
and i tried F=k.x=75 .
then used f=m.a formula both objects and found V1=3V2. so i solved equation but it seems all wrong.
can you help?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Nov19-11, 08:57 AM   #2
and i have no idea what to do in part b :)
Nov23-11, 06:18 PM   #3
can anyone help ? :(
New Reply
Similar discussions for: spring with two objects
Thread Forum Replies
What would happen if a spring was between two moving objects? Classical Physics 3
Length contraction (objects & space or objects only) Special & General Relativity 10
During a tornado, softer objects are driven through apparently harder objects... Introductory Physics Homework 1
Given 2n objects, number of ways to select n objects Calculus & Beyond Homework 1
Why the black objects absorb more light and heat from the other color objects? General Physics 27
