New Reply
0 divided by 0
Share Thread Thread Tools
Nov26-11, 10:37 PM   #1
0 divided by 0
[tex]\frac{0}{0}[/tex]
Is it 0 or undefined? I thought this was interesting, it seems a paradox in its own.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov27-11, 01:16 AM   #2
Well, assuming you are working with the field of real numbers, 0 doesn't have an inverse multiplicative element. There is no real number x such that 0*x=1. So the expression 0/0 which really means 0 times the multiplicative inverse of 0 has no meaning, since the multiplicative inverse of 0 isn't in the field of reals and doesn't actually exist. Thus 0/0 is undefined.
Intuitively, dividing zero by zero makes no sense because you are asking 0=0*x for what number x? Well, x could be any real number and it would satisfy that equation. In other words, the expression 0/0 isn't defined to be a particular number, whereas when we define division as a/b for real numbers a and nonzero real numbers b, we mean a/b=x where x is the unique solution to the equation x*b=a. The expression a/b is supposed to spit out a single real number. In our 0/0 case, it sort of gives us literally every real number as an output, which means it is useless if we are trying to describe a specific number with it.
You might want to hide your post before the mathematicians see this and die of shock and mad rage! lol
Nov27-11, 01:23 AM   #3
Thank you nucl, for reminding me of the proof that 0/0 has a good reason for being undefined.
Nov27-11, 01:48 AM   #4
0 divided by 0
Quote by nucl34rgg View Post
That was a beautiful explanation nucl, I never thought about division just being the inverse of multiplication (duh!). Your explanation makes complete sense.
And why would the mathematicians see this and die of shock and mad rage? loll
Nov27-11, 02:36 AM   #5
That's just how they are! :P
Nov27-11, 04:16 AM   #6
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Also see the FAQ on this topic: http://www.physicsforums.com/showthread.php?t=530207
Nov27-11, 02:32 PM   #7
Actually, in complex analysis, it's common to say that the function 1/z maps 0 to infinity when infinity is considered as the point at infinity on the Riemann sphere. So, in that sense, you could say 1/0 = infinity (when it's done naively by calculus students, this is wrong because they don't have a mapping in mind). You could restrict this to get 1/x when x is a real variable. The trick here is that you have to identify negative infinity with positive infinity. This isn't to say that 0 has an inverse. It is just that it is now included in the domain of the function 1/x and the point at infinity is added to the range.
But, still, 0/0 wouldn't have a good interpretation because that would correspond to the function 0/x, which is zero everywhere. I guess you could send 0 to 0, so that the function is continuous. So, you could define 0/0 to be zero. But it would be very confusing and bad notation that wouldn't accomplish anything, since there's no need to describe the constant function equal to 0 by such a convoluted means. And again, you would need to be careful to point out that it's a mapping, rather than taking an inverse, but that's a moot point. Better not to discuss it at all than to cause all this confusion. So, yes, 0/0 is undefined.
Nov27-11, 03:03 PM   #8
Recognitions:
We might note that many text refer to "0/0" as "undetermined" rather than "undefined" because if you have a limit of a fraction where the numerator and denominator both go to 0, the actual limit itself can exist and can be anything.
Nov27-11, 03:23 PM   #9
Recognitions:
Quote by HallsofIvy View Post
There is a distinction between (1) lim f/g, where f -> 0 and g -> 0 and (2) 0/0. Case (1) is undetermined, case (2) is undefined.
Nov27-11, 04:43 PM   #10
What about looking at:
[itex]\frac{lim}{x -> 0}[/itex][itex]\frac{x}{x}[/itex]
and apply l'Hôpital's rule to obtain:
[itex]\frac{1}{1}[/itex] = 1
Nov27-11, 04:52 PM   #11
Recognitions:
Quote by edgepflow View Post
That are limits. Limits have nothing to do with our discussion here. Whether 0/0 is defined or not is independent from whether the limit is defined or not.
Nov28-11, 01:07 AM   #12
Quote by micromass View Post
That was interesting, thank you. You said that [itex] \frac{1}{0}[/itex] isn't ∞ because as you approach 0 in a rational function then it can either be positive or negative infinity. So then would you be able to state:
[itex]\frac{0}{0}= -∞ < x < +∞ [/itex], where x exists anywhere on the extended real number line. Then the probability of x being a particular value on the one of the real numbers would be [itex]\frac{1}{∞}[/itex] would be undefined. Therefore, that might imply that [itex]\frac{1}{0}[/itex] is undefined.
But that is a very weak and inconclusive argument, I'm speaking gibberish haha.
Anyways, if you had to describe Peano axiom [of multiplication] in one or two sentences, what would it be?
Nov28-11, 12:45 PM   #13
Recognitions:
Or what about looking at
[itex]\frac{\lim}{x\to 0}\frac{2x}{x}[/itex] which has limit 2.
Or
[itex]\frac{\lim}{x\to 0}\frac{ax}{x}[/itex] which has limit a, for any number a.
Nov28-11, 04:01 PM   #14
Quote by Nano-Passion View Post
Not quite. In the real numbers or the extended real numbers, the expression 1/0 is left undefined. In the real number system, this is done since R contains no infinite elements. In the extended real numbers, this is done for precisely the reason you stated above; in particular, the left-hand limit of 1/x as x → 0 is -∞ while the right-hand limit is +∞.
However, in the projective real number system, we define 1/0 = ∞. In the projective reals, there is only one infinite element and this element does not have sign. This is what makes this definition work.
The point is that the answer to some of these questions depends entirely on the context. In some number systems, 1/0 is undefined while in others it has a perfectly reasonable definition.
So what you are suggesting here is that we define 0/0 as a collection of numbers. There is nothing inherently wrong with this, but there is also no real motivation to do so either. In my opinion, there are (aesthetic) reasons not to define 0/0 in this manner. In particular,
  • If we adopt the convention that 0/0 = R, then expressions like 1/2 are numbers while 0/0 is a set. There is nothing wrong with this, but it is inconvenient that some ways of stringing together numbers give numbers while other ways give sets.
  • While expressions like 1/2 can be interpreted as 2-1, we are forced to interpret 0/0 as an expression in it's entirety. In particular, things like 0 * 0-1 still make no sense, since the distributivity axiom for rings guarantees that 0 is not a unit in any ring.
So, while there is technically no issue with defining 0/0 = R, I still think there is sufficient reason not to. Also, I do not think you gain any utility from defining 0/0 = R, so why do it in the first place?
If you want 0/0 to denote a value of R then you need to choose a value when you define it. Otherwise, when we write 0/0, it could literally mean any real number; there would be no way of actually picking out which value of 0/0 we want. This way of defining 0/0 is problematic.
As a slightly unrelated note on probability, consider the following problem: If you select an integer at random from Z, what is the probability that the integer you chose is 0? It turns out the probability is zero. Therefore, there are events with probability 0 that can still occur. Likewise, there are events with probability 1 that do not occur. These are just some neat things that happen when you consider probability on infinite sample spaces.
Nov28-11, 09:42 PM   #15
Quote by jgens View Post
Okay I agree with your post. Something with probability one does not have to occur. But how can something with probability 0 occur? It could be an infinitesimal and not occur that much I agree, [itex]lim_{Δx\ to 0}[/itex] isn't necessarily 0. But 0 is a bit of a different number.
What do you think? I'm still new to math so I might be wrong..
Nov28-11, 10:11 PM   #16
In the real number system, there are no infinitesimal elements. The same is true in the extended reals and projective reals as well. In fact, most mathematicians rarely (if ever) do any work that uses formal infinitesimals. There are number systems that have infinitesimal elements (like the hyperreal numbers), but most of these have roots in model theory and are fairly difficult to define formally. If you are interested, non-standard analysis is the subject that deals with the calculus of these infinitesimal numbers, but non-standard analysis is far from one of the more active areas of research in analysis.
Therefore, it is often best not to resort with reasoning using infinitesimals. Without using their formal properties, it is easy for your intuition to deceive you. It turns out most people have terrible intuition when it comes to infinitesimals.
Now, it is important to note that [itex]lim_{h \to 0} h = 0[/itex]; that is, the value of the limit is 0. The limit is not infinitesimally close to 0, but actually is 0. This is an extremely important point to understand.
Finally, keeping what I've said above in mind, something with probability 0 can occur in just the same manner as something with probability 1 not occurring.
Nov28-11, 10:27 PM   #17
Hey, thanks for your patience. You haven't really argued on how something with probability 0 can occur. I'm not completely convinced at the moment. I'll try to put it in words for the sake of argument; to me 0 is absolutely nothing, so for absolutely nothing to happen is a paradox. Can you throw in a bit of mathematics, I'm interested.
New Reply
Thread Tools
Similar Threads for: 0 divided by 0
Thread Forum Replies
1 Divided by 3 General Math 60
One Divided by Zero General Math 5
zero divided by zero General Math 6
1 divided by zero General Math 33
Can x/0 be divided out General Math 8
