Spanwise Lift force distribution?
The discussion focuses on the distribution of lift force along the span of different wing plan forms, specifically comparing constant chord wings and elliptical wings. Participants explore the implications of lift coefficient distribution and induced incidence, as well as the relationship between wing taper and lift force distribution.
  • Ken suggests that for constant chord wings, the lift coefficient distribution is elliptical, leading to greater induced incidence towards the tip and a corresponding elliptical lift force distribution.
  • For elliptical wings, Ken notes that the lift coefficient is nearly constant across the span, which he argues results in a similar elliptical lift force distribution.
  • Some participants mention that the most efficient lift distribution is elliptical, but acknowledge that real wings often have complexities that complicate calculations.
  • Ken expresses uncertainty about the accuracy of his interpretation of the graphs and seeks clarification on how close the conclusions are to reality, asking for a variance estimate.
  • Anecdotal evidence is provided by a participant recalling an observation of lift distribution during an air show, noting a semi-elliptical pattern formed by water droplets on the wing.
  • Another participant explains the concept of spanwise lift coefficient and provides mathematical functions for different taper ratios, emphasizing that real-life coefficients do not drop below a certain threshold.
Participants do not reach a consensus on the implications of wing taper on lift force distribution, and there are multiple competing views regarding the accuracy of the conclusions drawn from the graphs.
Participants acknowledge that real wings may have variations due to factors like wing twist and chord length changes, which complicate the lift distribution calculations. There is also mention of the need for computational fluid dynamics (CFD) software for accurate analysis.
ken
Hi
I wanted to get clear on this conclusion of lift distribution along the span of a wing.
Graphs in texts show that for constant chord wings, Cl distribution along the span is eliptical.
Conclusions:
1.Induced incidence is greater towards the tip.
2.Lift force at the root is PI/4 greater than mean and as local chord is a constant, lift force falls away in the same eliptical relationship as Cl toward the tip.
Now take an eliptical wing plan form. Texts show that CL is constant almost to the tip. Conclusions, except right near the tip:
1. Induced incidence is constant across the span.
2. As local lift force is a product of Cl and local chord and Cl is constant, the lift force distribution follows the same eliptical relationship as the chord.
The two plan forms result in the same eliptical lift force distribution along the span. Now logic would seem to dictate what defies common sense and seems to be way too easy but could it be that wing taper does not effect the distribution of lift force along the span. Is this conclusion correct or are the texts incorrect?
I can so only these 2 possabilities.
Regards,
Ken
The most efficient lift distribution is elliptical. (unfortunately, doing space track work, I don't remember why or exactly what the efficiency is a scaling of)
For real wings, there is typically a fudge factor thrown in for non-optimal sections of the wing (Due to wing twist, chord length variations, etc). Calculating the actual lift distribution is nasty to the upteenth degree without some sort of CFD software (and even then...)
Hi Enigma
Your reply, is really not exactly what I am after here.
I am not trying to determine this to a high accuracy. Rather the graphs for various wing plan forms all strongly suggest that the distribution of lift force along the span is eliptical or at least as near as can be determined from the graphs.
That seems way too convenient to trust my interpretation.
What I am after is an idea of how correct this conclusion is.
Is it completely wrong or close?
If close, then how close for say a constant chord and an eliptical wing?
Is the variance within say, 30%, 10%, 5% etc.
I really just want to check if I am understanding this correctly or not.
Regards,
Ken
Anecdotal observation.
In 1958 I attended the British air show at Alderburgh. It was a moist day and as a new RAF light bomber came toward us, head on, a beautiful elliptical pattern formed from one wingtip to the other, formed of water droplets that had condensed out in the lower air pressure over the wing. It was a SEMI-ellipse, of course!
That's due to the wing vortex, which is a result of the lift distribution. Often the tip vortices are more noticeable than the wing vortex.
http://home.flash.net/~lauras34/sav15a.jpg
Ken,
Spanwise lift coefficient is what you multiply the local CL by. An elliptical wing is 1 across the entire semi-span (root end to tip). Most wings have taper and are defined by a taper ratio (tip end cord length/root end cord length).
For most straight wings the spanwise lift coefficient is given as a function of the fractional semi-span distance (x):
1. Taper Ratio = 1
From x= 0 to 0.86
= -1.3474x3 + 0.8774x2 - 0.2469x + 1.1736
From x=0.86 to 1
= -36.7776x2 + 63.5583x - 26.7419
2. Taper Ratio = 0.5
From x= 0 to 0.65
= -0.43567x2 + 0.39804x + 0.97582
From x=0.65 to 1
= -5.51768x3 + 7.29061x2 - 2.31958x + 0.97582
Please note for both of these the real life spanwise lift coefficient does not really ever drop below 0.6. You will have to make that adjustment when x gets high (for an approx sol you can ignore this)
This thread is 7 years old...
16K
9K
  • · Replies 55 ·
12K
  • · Replies 27 ·
10K
