Rotation about a fixed axis problem
  • Thread starter Thread starter Rob K
    Axis Rotation
The discussion revolves around a physics problem involving rotation about a fixed axis, specifically analyzing a hoisting mechanism with two pulleys. The problem states that a constant force of 1.5 kN is applied to a system with pulleys of radii 0.4 m and 0.8 m, and a block A with a mass of 300 kg is attached. The participants calculated the moment of inertia (I) as 25 kg·m² and attempted to derive the angular acceleration (α) and tension (T) in the system. The final answers provided were α = 0.312 rad/s² (CW), T = 2980.5 N, and a vertical acceleration (a) of 0.125 m/s².
  • Understanding of rotational dynamics and moment of inertia (I = mk²)
  • Knowledge of Newton's second law for rotation and linear motion
  • Familiarity with trigonometric functions, particularly sine for force components
  • Ability to interpret and manipulate equations of motion in a mechanical system
  • Study the principles of rotational dynamics, focusing on torque and angular acceleration
  • Learn how to resolve forces into components, especially in inclined systems
  • Explore the concept of radius of gyration and its application in calculating moment of inertia
  • Investigate the effects of different pulley configurations on mechanical advantage and acceleration
Students in physics or engineering courses, particularly those studying mechanics, as well as professionals involved in mechanical design and analysis of pulley systems.
Rob K
Hi guys I was trying not to post this as it is difficult to understand without the diagram, but I will try and give you a visual. Basically there are 2 pulleys attached together on the one pivot, the larger one is driven by a belt that is driven by a motor. The inner pulley is used to hoist the weight.
Figure 3 shows a block A attached to a hoisting mechanism which consists of two
drums of radii r1 = 0:4 m, r2 = 0:8 m, ¯xed at O and which have a combined mass
of m1 = 100 kg and a radius of gyration about O of kO = 0:5 m. If a constant force
P = 1:5 kN is applied by the power unit, which consists of a pulley of radius r3
attached to a motor, determine the vertical acceleration of block A. The cord from
the motor to the drum is at an angle 40± to the horizontal. Block A has a mass
m2 = 300kg.
I = mk2
+CCW [itex]\Sigma[/itex]Mo = Io[itex]\alpha[/itex]
+[itex]\uparrow[/itex][itex]\Sigma[/itex]Fy = m(ag)x
+CCW a = [itex]\alpha[/itex]r
I = 100kg * (0.5m)[itex]^{2}[/itex] = 25kg.m2
T(0.4m) = (25 kg.m2[itex]\alpha[/itex]
-300(9.81)N + 1500sin40N + T = - 300a
a = [itex]\alpha[/itex]0.4
I worked out [itex]\alpha[/itex] to be 5.56, or 24. something. Basically after 20 odd hours, I have given up, there is something clearly very wrong and missing, and between me and 2 other people we don't know where to go from here.
The answers are as follows
[[itex]\alpha[/itex] = 0:312 rads/s2CW, T = 2980:5 N, a = 0:125 m/s2.]
Please help.
Kind Regards
Rob K
Can anyone help with this?
Do I need to provide some more information?
Try to attach a picture. And explain your notations. What do you mean by ":"? Is it for decimal point? ehild
10K
13K
