| Thread Closed |
Impulse/force in pounds for the time frame |
Share Thread | Thread Tools |
| Jan12-12, 07:39 PM | #18 |
Impulse/force in pounds for the time frameI still have a like problem with this deceleration. There was a “good” study that a person used 80% and the deceleration was for 48% however the full concentric took 1.5 seconds to go about 22 inch. My repetition speed is 3 times more than that. Here is my problem and questions, or more the way I lift or see both lifts that we are debating. 1, If I was to lift a weight that was 80% {that’s 80% of my 1 repetition maximum} for a ROM {range of motion} of 20 inch, but just push up as hard as I could and not try to slow down, like if I was shooting the putt, or throwing a stone, thus then would have to be using more force than if I needed to decelerate ??? We are doing a little experiment on if I decelerate a lot, a bit or not at all, maybe Zula will fill you in on this. 2, That’s the way I envisage I do lift these weights on my fast repetitions, {will do some new videos if you like ???} I explode up and keep on pushing and pushing; I don’t or did not seem at all I was or had to decelerate, and until me and D. Found that study, we was trying to work this out with me decelerating for only 10 to 20% of the ROM. So could not I fully accelerate up, and then immediately reverse ??? As that’s what it seems I do. As there is no offloading, as we worked out that if you accelerate 80% up, can’t remember the distance, but if you immediately stopped the weight would move 3 inch, however it does not, it does if a machine pushes it, but not the Human body, as of the biomechanical advantages and disadvantages thought the ROM, meaning the body just can’t produce full constant force thought-out the range of motion. Will get back to the rest, been very busy and sleepy. Big thank you for your and the or members help and time. Wayne |
| Jan13-12, 02:55 AM | #19 |
However experimantally was found the acceleration phase lasts for about the half distance with the 80% of your maximum weight and much less with less weight when you try to lift as fast as possible. In general,the faster the lifting the less the acceleration phase and the grerater the deceleration phase. BTW at the study you're referring the lifting lasts ~1sec which is perfectly normal with such weight.Check it again. |
| Jan13-12, 02:09 PM | #20 |
I just did the test Zula told of me. I attached a weight to the bar, and curled 80% up and down as fast as I could, the string and weight stayed basically the same, meaning high tension and little deceleration. I then accelerated up fast again, but stopped very suddenly, the string went slack and weight with was half a pound jumped up. On paper it may look balanced/made up, however how do you know it is ??? As you will agree that a high force for a short time, can produced the force impulse on a low force for a longer time, so why do you think the forces balance out make up ??? If I was to press up into a very thick piece of clay at a high force velocity with an 80% dumb bell in my hand, my hand could go in 2 inch, then there will be an opposite reaction which it called the tension on the muscles, I do this 6 times in 6 seconds and make a 12 inch hole in the clay, very high tensions on the muscles. I then take the same dumb bell and press is up into a very thick piece of clay at a low force velocity with an 80% dumb bell in my hand, I do this one time, the dumbbell would not even go the first 2 inch, but still lots of tension on the muscles. I think you coined the makeup. There is something wrong with this study, or they were not testing for maximum force bench press, as I or most could lift 80% 20 inch in .5 seconds, so the question is why did they take 1.5 seconds, but as they did take 1.5 seconds, I can see why the large deceleration. Page 455. http://www.scribd.com/doc/2528195/El...he-bench-press Wayne |
| Jan13-12, 04:27 PM | #21 |
If you're going to doubt it without any argument you'll just be ignored. |
| Jan13-12, 07:13 PM | #22 |
Yes, but please let us know “your” actual meaning of terminal velocity here, also why you include it, if what you think it is, is zero. As in weightlifting and physics it’s different. Lifting and throwing a weight up in say the bench press, in my form of explosive lifting with 80% is basically the same. As I try to get the weight from a to b as fast as possible, that the same as if I was trying to throw the weight on the bench press. We are not looking for the net force the way you are saying it, and never have been, why do you mention this ??? You are saying if both forces are equal they cancel each other out the net force is zero. The force we are talking about are the forces from the muscle for holding the weight, for moving the weight, for accelerating the weight and for decelerating the weight, then add in the opposite reaction force, as in the more force you produce the more the clay would get squashed, or the more tension on the muscles. Like my EMG reading proved. The strength of the person will work out the acceleration and deceleration. As I said, I lift explosively and it’s basically the same as if I was throwing explosively, I would try to do both as fast as possible. It’s of the greatest impotence, why do you think not ??? If I move the weight 1m in .5/.5 of a second 6 times to your 1m in 3/3 seconds, I have created 6 large force accelerations and peak forces. I will tell you why more, but no time now. Why do you think your lower forces can make up or balance out my higher force ??? You still have not explained this, how can say 80 force make up or balance out a 100 force, if both forces are used for close to the same time frame ??? Did you try the weight on a barbell with string, to show very little deceleration ??? Wayne |
| Jan14-12, 12:51 AM | #23 |
You throw an object when it's leaving your hands with velocity.You lift an object when it doesn't leave your hands so by definition at the end of lifting the velocity is zero and that's called terminal velocity. The forces "make up".....the average applied force is equal with the weight regardless the length of the acceleration/deceleration phases and the distance covered. The ONLY forces available are the muscle force and the weight.There're no additional action-reaction forces to add as you fantasize. Read carefully Phantomjay's last post.He's explaining perfectly that and your irrelevant clay example. I'm out of this thread cause it's obvious you have some kind of obsession and I'm wasting my time.I hope Phantomjay will have the patience to explain it further to you. PM me for further explanation cause that's irrelevant with the thread. |
| Jan14-12, 11:04 AM | #24 |
As even with 80% moving it for 30 inch at 2m/s the bar will not leave your hands, so yes terminal velocity is zero. What you say net force, as I said last time, you are on about the force moving the weight and the weight pushing back, the opposite reaction forces. We are “not” concerned with both forces cancelling each other out, we are concerned with the forces from the pushing force the muscles, which causes tension on the muscles, and the opposite reaction forces from the weight. So in our case they are both creating force from and on the muscles, thus we need to add these forces up, as of the tension on the muscles. You seem to be saying they cancel each other out, thus not force was applied from the muscles or from the weight and not tension on the muscles. You hold a weight half way up, you then move the weight up 20 inch in the time you held it, in say 20 seconds, basically the same forces from your muscles, thus tension on your muscles. However when I am accelerating the weight up and down 20 times in the same time frame, I have {if we say for at least the acceleration is for 60% of the concentric} accelerated the weight 240 inch for just the concentric, how on Earth you can think you have used the same total or overall force in doing this is beyond me. As I asked before, if you claim to use the same total or overall forces, and they make up or balance out in the end, why does not the distance make up or balance out ??? Why do I use far far far more energy, why do I do more work, and work is the product of a force times the distance through which it acts, and it is called the work of the force. Also why do my EMG reading produce higher reading for the faster repetitions done in the same time frame. It’s like a impulse; a small force applied for a long time can produce the same momentum change as a large force applied briefly, because it is the product of the force and the time for which it is applied that is important. So I say the small force would need far far far more longer time to make up or balance out the large force made by the faster accelerations of the faster repetitions. That’s why you “always” fail far far far faster doing faster repetitions to slow, as the high acceleration forces, put far far far more tension on the muscles than the slow in the long run. If I move a weight faster in the same time frame, and then I move the weight far far far faster in the same time frame, the acceleration will be higher “and” longer making for lager force impulse that in my opinion cannot be made up by the slower. Yet again you miss out very many of the main issues of this debate, what about the weight and string test on the weight for deceleration ??? Wayne |
| Jan14-12, 11:47 AM | #25 |
Wayne...let's start it all over again.
Do you understand that the average force that's applied by the muscles is always equal with the weight regardless the repetition speed?Yes or no? |
| Jan15-12, 05:24 PM | #26 |
It’s like a impulse; a small force applied for a long time can produce the same momentum change as a large force applied briefly, because it is the product of the force and the time for which it is applied that is important. So I say the small force would need far far far more longer time to make up or balance out the large force made by the faster accelerations of the faster repetitions. That’s why you “always” fail far far far faster doing faster repetitions to slow, as the high acceleration forces, put far far far more tension on the muscles than the slow in the long run. The average net force is equal to the weight, regardless to duration and time ??? So if I move a weight for an hour, for a 1000m and then for 1 sec, 1mm. And if the net force is the same, the moving of the weight for an 1 hour will put a very lot of force out from and onto the muscles, even thou the average is the same. OK, let's see if I can reproduce this. Let's assume we're doing a bench press with 200 pounds, and our 1RM is 250 pounds (80% 1RM). Furthermore, the ROM is 15 inches. The first thing we must do is convert pounds into the English unit of mass - the "slug". That is - 200 pounds/32 ft/sec^2=6.25 slugs. Now, from F(net)=ma, we have 250-200=6.25 x a, or a=8ft/sec^2. This is the acceleration of the bar during the concentric. Now, let's assume that we will push with our maximal force (250 pounds) up to the 12" point. We next need to find the velocity of the bar at this point from the equation v^2=2ad. Plugging in "a" from above and "d"=1ft, v=4 ft/sec. Note that this is not the top of the lift, but 3" from the top. Next we want to find the time it takes to get to the 12" point, from the equation d=1/2at^2. Plugging in our values of "a" and "d", t=.7 seconds (again not the top). Now, we assume that we stop pushing the bar at the 12" point, and let gravity slow it down, so that it comes to rest at the top. From v^2=2ad, we plug in our value of "v", but here we use a=32 ft/sec^2 (acceleration of gravity). From this we find that d=3", so that the bar comes to a perfect halt right at the top of the ROM - the 15" point. Finally, we want to find out how long it takes gravity to stop the bar, from d=1/2at^2. Plugging in d=3" and a=32 ft/sec^2, t is found to be about .1 seconds. Therefore, the total time for the concentric in this case would be .7 seconds (for the acceleration phase, or "onloading") plus .1 seconds (for the decceleration or "offloading" phase), for a total of .8 seconds. This is a bit faster than 1/1, but the best I could do this late at night. If your ROM were a bit longer then 15", then the speed would be closer to 1/1. So, we see that in this case the offloading relative to the ROM is 3" out of a total of 15", or 20%. The offloading relative to the time is .1 sec out of .8 sec, or about 12%. Note that this is worst case...that is the first rep. As the set progresses, the offloading will reduce with each rep, due to fatigue, and towards the end of the set will be negligible. Therefore, you could state that the "average" offloading of the entire set relative to the ROM would be about 10%. Note that this also assumes we can push with maximal force all the way to the 12" point. If our strength curve is such that our force output diminishes towards the top, then the offloading will be less than given above. “If” the forces averaged out, “why/how” is the EMG readings higher, why/how is power higher why/how do you use more energy, why/how does the fast move the weight 6 times further, why/how do you fail on the fast far faster ??? Play from 5.00 http://www.youtube.com/watch?v=6clCe76uD-Q Note that the differences. Slow, Power 649 Force 546 Velocity 161. Fast, Power 829 Force 579 Velocity 192. Imagine if the person had done 6 repetitions fast and one slow, the force on the fast would/could be far far far higher, as on the video, the speeds were basically quite close. Wayne |
| Jan16-12, 05:42 PM | #27 |
1, This seems to work on paper, but not in practice. 2, However, the following states the force do not balance out or make up. 3, However not on EMG reading, which test the electrical activity of muscles. 4, Not on distance as the weight is moved six times further in the same time frame. 5, I accelerate 600mm to you moving at a constant velocity for only 166mm. 6, You always fail far faster in the faster reps. 7, Why do you use more energy the moment you use more force ??? If as you claim your forces make up or balance out, should not the energies ??? 8, I know we went over this once, but there is still things bugging me, could we go over here on the physics forum, as other members can comment. As you know, if I immediately stopped at any part of the acceleration, the weight would stop immediately, and would not carry on at all, so “HOW” do I as you claim I use less force than the weight ??? As if you less force, does that “NOT” mean that I would be then reversing the direction, not still going forward but backwards ??? As deceleration is negative acceleration or decreasing velocity over time. Why can not the fast repetition, coming off the eccentric portion, hitting the peak forces on the transition from negative to positive. Could it not be like this, maximum force 100 pounds, weight used 80% 130, 100, 100, 100, 100, 100, 95, 90, 85, 80, zero, for the transition from positive to negative. These next numbers mean nothing, and are just my example. .5m/s, 2m/s, 2m/s, 2m/s, 2m/s, 2 m/s, 1.6m/s, 1.2m/s, .8m/s, .6m/s, zero, for the transition from positive to negative. I can’t seem to find any studies of moving 80% at 2m/s for say 20inch, or there about, will look more under weightlifting. 9, What I have said all along, is my higher force impulses, cannot be made up or balanced out by your lower force impulses, and you have no way to prove it, however I do as in all the examples above. 10, Just thought of something, eccentric muscular action for the deceleration, this will take force from the muscles, muscles are able to withstand greater eccentric than concentric loading due to increased fast-twitch muscle fibre and motor unit recruitment. Will have to think about this one. Wayne |
| Jan18-12, 01:13 PM | #28 |
Quite wrong I think, please read this. Seems like it’s the average. http://www.raeng.org.uk/education/di...ring/8_RMS.pdf 1, Fast 409, Slow 349, 2, Fast 437, Slow 346, 3, Fast 0.1, Slow 0.3, 4, Fast 0.6, Slow 0.7, 5, Fast 1104, Slow 1114, 6, Fast 146.0, Slow 193.4, 7, Fast 175.0, Slow 173.0, 1/ WRK This is the work average for the session measured in [µV] AVG microvolts. The average readings will vary from one patient to another. 2/ RST This is the rest average for the session measured in µV - Below AVG 4 µV a muscle is beginning to rest. 3/ AVG This is the average onset of muscle contraction measured in ONST seconds, readings below 1 second can be considered normal. 4/ AVG This is the average muscle release measured in seconds, RLSE readings below 1 second can be considered normal. 5/ W/R This is the average peak value measured in µV - The value will PEAK vary from one patient to another. 6/ WRK This is the average muscle deviation when contracting the AVDV muscle. Readings of below 20% of WRKAVG can be considered adequate, below 12% can be considered good. 7/ RST This is the average muscle deviation when the muscle is at rest. AVDV Below 4 µV a muscle is beginning to rest. Wayne |
| Jan18-12, 01:33 PM | #29 |
Hi D.
Hope we both are both are seeing understanding force/strength in the same way ??? As I do, as do explain things to you, but at times you never acknowledge that you understand or agree. We all agree that when using 80% for the fast at .5/.5 for 15 repetitions = 15 seconds, and the slow at 3/3, that you will be able to go for longer using the 3/3, as you fail faster doing the .5/.5 yes ??? So this means I “HAVE” used up my force and faster, yes ??? Or as I call it strength faster, so if we are Clones, and have a 1000N of force to use up, at using 80% as explosively/dynamically, I “have” used up “all” my force, “but” as you are “STILL” exercising, repping the weight, you “MUST” still have force/strength left, right ??? I have not had many answer yet, waiting for the next reply, but as I know these people are busy. Zula is constructing a force machine. If I fail faster, as told you above, if I also use more energy, more the weight more distance, I fail understand how or why you think you are right ??? Please read chapter 4, just the first 2 pages, it says like I have been trying to say all along, these forces that I talk about cannot be easily equated with physics. One more, If I try and lift as much as I can fast, to you lifting slow, I will lift more, thus I create more force and for longer. http://www.findphysio.com/E-books/Bi...20Exercise.pdf Not sure what you want me to look at here ?? Wayne |
| Jan18-12, 01:45 PM | #30 |
This looks like the same question, yet again Wayne.
Will you keep asking it until you get the answer you want?
| Jan19-12, 05:19 PM | #31 |
Hi sophiecentaur, I am honesty not like that, as I recently bought an EMG machine, {the results are on this thread} it reads the electrical muscle activity, the more average or total force/strength you use it reads out, and I did many tests on it, and everyone came out stating that you use more force when moving faster. Also we all agreed that you use more energy when moving a weight faster, so as soon as the force and average force goes up, the energy does also, this can’t just be a coincidence ??? Then you move the weight 1000mm moving fast, and only a 166mm moving slow, that means “if” I accelerated for only 60% I would have accelerated the weight 600mm to the slow only moving the weight at a constant velocity for 166mm. You also fail far far far faster on the faster reps, you hit muscular failure faster. http://www.youtube.com/user/wayneroc.../0/sbRVQ_nmhpw We as we all agree that when using 80% {of your 1RM repetition maximum} for the fast at .5/.5 {.5 of a second concentric and .5 of a second eccentric} for 15 repetitions = 15 seconds, and the slow at 3/3, that you will be able to go for longer using the 3/3, as you fail faster doing the .5/.5 yes ??? And you fail roughly 50% faster on the fast repetitions. So this means I “HAVE” used up my force and faster, yes ??? Or as I call it strength faster, so if we are Clones, and have a 1000N of force to use up, at using 80% as explosively/dynamically, I “have” used up “all” my force, “but” as you are “STILL” exercising, repping the weight, you “MUST” still have force/strength left, right ??? So, as well as 99% of the Worlds bodybuilders, strongmen, weightlifters, and all sportspeople of every sport train in the faster repping way, and the evidence above, I just don’t see how some here think other ??? It’s basically physic equations have not got all the variables, thus they are adding it up wrong. Bottom line is, the slow constant medium forces cannot balance out or make up the high peak forces of the fast on their accelerations, in the same time frame, it’s like impulse, impulse is defined as the integral of a force with respect to time. When a force is applied to a rigid body it changes the momentum of that body. A small force applied for a long time can produce the same momentum change as a large force applied briefly, because it is the product of the force and the time for which it is applied that is important. We are now constructing a force plate. Thank you for your help on the last thread, and hopefully on this one, as maybe you can spot where the equations are going wrong. Wayne |
| Jan20-12, 06:12 AM | #32 |
The equations are 'gong wrong' because you can't expect them to apply in a situation like this (as in all of your questions). You confuse the terms you use and seem to think that 'work done on' is necessarily related to 'energy transferred from muscles'.
I really don't know why you want to include Physics in your training if you won't learn Physics to an appropriate level. If you continue to talk in the wrong language, how can you expect to have a proper conversation . Quote "I have used up all my force" - this is a meaningless statement in terms of Physics. Your posts are full of such statements but you refuse to modify them or learn the appropriate way of putting things. If someone can only play the Piano with one finger then it's no surprise that a Piano Concerto gives them a problem. Like I have often said, you can't bend Physics to your will. You just have to follow where it takes you. You don't seem to want to, though. |
| Jan20-12, 01:15 PM | #33 |
Would anyone else agree that if you apply only an upward force(against gravity) during the upward rep, then yes, it is exactly equal to gravity once you come to a stop. Would you also agree that if however, you apply a sharp upward force and then ALSO a force WITH gravity, the net impulse applied to the weight is still 0, consisting of +your force against gravity, and -gravity and -your force with gravity, thus, the overall force you are applying is greater than gravity. I saw wayne mentioned the experiment we are throwing together, and I was hoping this made sense to you sophie and douglis. It seems that is where this conversation is hung, in the assumption that you are only working against gravity. With a fast enough rep it is possible that is not the case. I am getting together a cheap accelerometer with which we will be testing this theory out.
| Jan20-12, 02:18 PM | #34 |
You're referring to the case where you also use the antagonists muscles in order to stop the weight and you don't rely only on gravity for the deceleration. Of course you're right...in that case the overall force is greater than gravity and probably that's what he's doing in his experiments. However....Wayne denies that case.He insists(without any reasonable argument) that without any "help" from the antagonist muscles(muscles apply only upward force) the overall force is greater with fast lifting ignoring the fact that the net impulse is always zero. Please,if you have the patience(cause I don't) explain to him that he's totally wrong. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Impulse/force in pounds for the time frame
| Thread | Forum | Replies | ||
| most force/strength used in the same time frame | General Physics | 69 | ||
| Impulse question about Force and time | Introductory Physics Homework | 2 | ||
| Force vs. time graph (Impulse) | Introductory Physics Homework | 16 | ||
| Impulse and Force-Time Graph | Introductory Physics Homework | 2 | ||
| Velocity as a function of force/impulse/time. | Introductory Physics Homework | 2 | ||
