Thread Closed
Impulse/force in pounds for the time frame
Share Thread Thread Tools
Jan20-12, 08:13 PM   #35
Hi all, and thank you for the replies, “no” time to read any of the posts, but this one came up on my mail.
---Quote (Originally by Zula110100100)---
Would you also agree that if however, you apply a sharp upward force and then ALSO a force WITH gravity, the net impulse applied to the weight is still 0, consisting of +your force against gravity, and -gravity and -your force with gravity, thus, the overall force you are applying is greater than gravity.
---End Quote---
Zula...we have discussed this case before in another of dozens Wayne's same threads.
You're referring to the case where you also use the antagonists muscles in order to stop th weight and you don't rely only on gravity for the deceleration.
Of course you're right...in that case the overall force is greater than gravity and probably that's what he's doing in his experiments.
However....Wayne denies that case.
NO I do not, why would I ??? I have been training for about 40 years, and it’s well known that you have to use antagonist’s muscles in order to slow, stop and very slightly reverse the weight
He insists(without any reasonable argument) that without any "help" from the antagonist muscles(muscles apply only upward force)
I never said this ???
the overall force is greater with fast lifting ignoring the fact that the net impulse is zero.
Please,if you have the patience(cause I don't) explain to him that he's totally wrong.
He insistswithout any reasonable argument.
I have more than a reasonable debate, see above posts and below. Please remember, I am doing 6 more repetitions in the same time frame, and moving the weight 6 times as far.
I “proved” in my opinion I was right in my last post. Or could anyone here please try to explain that when you fail {and you do this is fact} in the faster repetitions, too which that means you have no force/strength left, but the person doing the slower repetitions does have force/strength left, how can I have not used all my force/strength up faster when I have used my force/strength up 50% faster ??? Proof, evidence and facts, I have used my force/strength up first, thus if we both had 1000N of force/strength, I have used it up faster, to say other would be a full English and physics contradiction, it would be like say the Man who ran the 100m the slowest was the fastest.
Meaning the physics calculations need to add in the other branch of physics, Kinology kinology/physics which treats of the laws of motion, of moving bodies to the calculations. And Biomechanics the study of the structure and function of biological systems. These with the fact that you use more energy the instant you use more force/strength, also that you move the weight further in the same time frame, and that you fail faster.
I repeat, the physics calculation cannot be right, as the situation cannot exist, as the faster repetitions do indeed finish way before the slow, this is why my EMG readings in the same time frame, put the fast repetitions higher, because on the tests I did not go to failure, as we needed the results of the same time frame. Please take a look at the videos, the weight here was too light.
http://www.youtube.com/watch?v=B8gtp...ofilepage#t=3s
http://www.youtube.com/watch?v=pd0ZA...ofilepage#t=1s
Wayne
Jan21-12, 04:53 AM   #36
Quote by waynexk8 View Post
The case,for example,that you do a bicep curl and you decelerate with your triceps was not a part of the discussion.
I “proved” in my opinion I was right in my last post. Or could anyone here please try to explain that when you fail {and you do this is fact} in the faster repetitions,..... Proof, evidence and facts, I have used my force/strength up first, thus if we both had 1000N of force/strength, I have used it up faster,
Wayne
I don't know what you think you prove with this example.
The fact that you fail faster with fast lifting just proves that you use energy faster(greater rate of energy expenditure) and not that you "use force/strength faster".
Greater rate of energy expenditure doesn't equate greater overall force.
Practically means that the fluctuations of force in fast lifting require more energy than the equal constant force of slow lifting.
Jan21-12, 10:07 AM   #37
Best I answer this one again.
Quote by douglis View Post
The length of the acceleration phase is of little importance.
It makes all the importance. As the accelerations, are where the higher forces are, thus accelerations and higher accelerations thus higher forces. Yes you may say, but then there are the decelerations, however in my opinion, that medium force of the slow can “not” make up or balance out the high accelerates/forces of the fast, as the force impulse is higher.
As long as the terminal velocity is zero the acceleration is always balanced by the deceleration.Or...with your own words...the forces "make up".
You “need” to show “how” you “think” the force make up or balance out. As I keep repeating myself, but you do not cannot answer, so here again, “if” as you think the forces make up, why do I instantly use more energy when force goes up, and you “never” make the energy up, so “why” do you “think” you make the force up ???, then there is the more distance I move the weight, and I fail faster, you “never” can explain this.
However experimantally was found the acceleration phase lasts for about the half distance with the 80% of your maximum weight and much less with less weight when you try to lift as fast as possible.
NO, this was when bench pressing and the total repetition took 1.5 seconds, mine took .5 of a second.
In general,the faster the lifting the less the acceleration phase and the grerater the deceleration phase.
Why do you think this ??? Please could we have explanations for the things you say, as this is a physicist site, and all needs proof and evidence.
BTW at the study you're referring the lifting lasts ~1sec which is perfectly normal with such weight.Check it again.
Sorry it was 1 seconds, “however” we are “not” on about any normal, we are on about one 3 second concentric to six .5 of a second concentric.
Wayne
Jan21-12, 10:25 AM   #38
Recognitions:
Gold Membership Gold Member
Well, at least you admit this is a Physics site. Having admitted as much, why do you refuse to talk Physics? The explanations you have been given make good sense in Physics and the only reason they don't make sense to you is that you refuse to talk the same language. This could be construed as simple arrogance by anyone less charitable than me!.
Jan21-12, 10:47 AM   #39
Wayne
The exact same questions from the last page again ignoring all the answers you've been given!If that's not obsession I don't know what else to call it.
I'm out of here...you got all the answers even graphically in a mail.Can't do anything more.
Jan21-12, 10:49 AM   #40
Recognitions:
"He only does it to annoy." Lewis Carol
Jan21-12, 11:08 AM   #41
Quote by sophiecentaur View Post
The equations are 'gong wrong' because you can't expect them to apply in a situation like this (as in all of your questions). You confuse the terms you use and seem to think that 'work done on' is necessarily related to 'energy transferred from muscles'.
Sophiecentaur, I am sincere and not a crank, I honestly want to learn, and have paid good money out for an EMG, so I do thank you for coming back into this debate and offering your knowledge.
Maybe I have in the pass I have confused the terms, but learning physics at my age is not that easy, if you or anyone started in my firm {wrought iron} it would not be easy for the first several years, but I am trying my best.
When I say work, and as you know there a many words for work, I mean physical work, work is the product of a force times the distance. So if I move a weight from a to b as fast as I can, I have used as much force as I can, moving a weight so and so distance, and if I move it less distance in the same time frame I have used less force, that’s remember my opinion. However why I am here is that I do not know how to work out how much more force is used. Please see the video stating that more force was used, but this time the more force was used in less.
http://www.youtube.com/watch?v=6clCe76uD-Q
Fast
P = 695
F = 579
V = 192
Slow
P = 649
F = 546
V = 161
I really don't know why you want to include Physics in your training if you won't learn Physics to an appropriate level.
I am leaning a little. However the main/big point here, is that in the training World, this debate is huge; it’s been going on, on about 25 forums, by 10000 or more people for over ten years. However the majority, say 99% train fast, and results are spectacular to slow. Give the fat I trained 15 years trying slow, with not much results, that at the age of 45, added 30 pounds of muscle and 10 pounds of fat in just under 3 years doing faster repetitions.
And then again it’s just human to want to know debate and learn, like on this forums the debates have been so many, and some very long and complicated.
If you continue to talk in the wrong language, how can you expect to have a proper conversation . Quote "I have used up all my force" - this is a meaningless statement in terms of Physics. Your posts are full of such statements but you refuse to modify them or learn the appropriate way of putting things.
Ok I see you point there. But “how” else can I say this ??? As if I use up all my force/strength, as I do in training, how else can I say this ???
If someone can only play the Piano with one finger then it's no surprise that a Piano Concerto gives them a problem.
Very true. But basically when training in this instance of both of the slow and fast person doing the two different velocities, we do use up our force/strength for a moment, or the moment of muscular failure, not sure how else to say it.
Like I have often said, you can't bend Physics to your will. You just have to follow where it takes you. You don't seem to want to, though.
I don’t want too, however all points the faster using more or more total force.
1,
My EMG reading states this.
2,
You use more energy when doing the fast, thus in my opinion as soon as you use more energy you use more force, what else can it be ???
3,
When the fast is on its deceleration, the slow cannot make up or balance out the higher force that the fast made when on its accelerations, as of more energy used, hitting muscular failure faster, moving the weight more distance, EMG readings, and all in the same time frame.
4,
As I have also said, If as you do, you fail faster doing the faster repetitions, you “must” have used up your momentary muscular force/strength faster than doing then slow.
5,
Then the video above.
I could say more, but “everything” points to you have to use more force. It’s like if you lift a heaver weight, you have to use more force, or if you lift the same weight faster you have to use more force, and in the end in my opinion more overall or total force.
Wayne
Jan21-12, 11:29 AM   #42
Recognitions:
Wayne:
You are NOT sincere in wanting to learn about the Physics of this. You demonstrate this in nearly every one of your posts. Merely having forked out a load of your money on an "EMG" says nothing about your attitude to Physics or your sincerity.
Whilst you make statements like "When I say work, and as you know there a many words for work. . . ." then you are clearly never going to take in the Physics. There is just ONE definition of Work, in Physics but you seem to want to use the word to describe many things. You also use the word Force in any way you fancy but there is only one meaning for it (in Physics).
You haven't actually asked a question yet that 'parses' correctly in Physics nor have you accepted any of the totally straight answers you have been given. Are we all out of step but you?
It is a matter of GIGO, i'm afraid. You just succeed in pissing people off, here. Stick to your mates down at the Gym - they are more likely to speak your language. Alternatively, learn some actual Physics - and I don't mean Waynephysics.
Jan21-12, 11:40 AM   #43
I never said it was part of the debate, you brought it up.
Just look at what you said and the contradiction. When you can “not” lift anymore, it means you do “not” have the force/strength to lift the weight true or false ??? We all know that’s true, if not state why ??? So why try and say you use energy faster, we all know you do, “too which is contradiction of sorts again” as “why” do you use more energy faster ??? Exactly the same time you move faster, it’s because you “are” using up force/strength faster.
Ok please tell me why I fail faster and cannot pick up the weight ??? I will say its because of several reasons, but it’s basically you force/strength supply has ran out temporary ??? Yes or no ??? And also your energy supply has ran out temporary ??? Yes or no. You can “not” just blame it on energy, you “have” to add in the force, as the force is what the energy is powering.
If you say yes, then its force and energy has ran out together, and that’s because you using up your force sulphide with energy faster, if not why ??? You can’t have one without the other.
Yes this is what I am saying also, [b]the higher force “must” use more of the force that the muscles have. The fluctuations of force in fast lifting must also require “more” force out of the available force the muscles than the constant force of slow lifting, how can it be any other way ???
Now please answer this.
When you fail {and you do this is fact} in the faster repetitions, too which that means you have no force/strength left, but the person doing the slower repetitions does have force/strength left, how can I have not used all my force/strength up faster when I have used my force/strength up 50% faster ??? Proof, evidence and facts, I have used my force/strength up first, thus if we both had 1000N of force/strength, I have used it up faster, to say other would be a full English and physics contradiction, it would be like say the Man who ran the 100m the slowest was the fastest.
Wayne
Jan21-12, 11:55 AM   #44
Recognitions:
Wayne. That is just a rant. what do you want (one sentence please) out of all this?
Jan21-12, 12:04 PM   #45
The fluctuations of force in fast lifting must also require “more” energy out of the available energy than the constant force of slow lifting
Wayne
When you fail in the faster repetitions means you have no energy left.
Wayne...are you able to understand the difference between force and energy?
Jan21-12, 12:17 PM   #46
Wayne:
I am or will try to learn as much as I can, but I have a firm, family and many other things in life, I just do not have the time to do a full physics course, will will try to learn what I need for this debate.
Please say the odd thing I say wrong, then I can either explain or put it right.
In this instance it must mean physical work, as that’s what we are doing, if not what do I call it ??? But is not work the product of a force times the distance add in time ??? If so then it’s the same.
Force is basically a push or pull, it makes an object move, that’s roughly the same as strength. Not sure what you say I got wrong there ??? Please say.
I think I have, if not please say how I should ask this question from this example.
I use muscle strength to make force, so I use force to move a weight. I only have so much temporary force in my muscles, like everything else. So if I lift 80% of my 1RM, at a velocity of .5/.5 and 3/3 you will fail roughly 50% faster moving on the faster, this means I have gone to momentary muscular failure, and used up my temporary force faster than the slow. This must in my opinion mean I have used more total or overall force faster. The debate was, which uses the most total or overall force on the temporary force the muscles have, thus put more tension on the muscles in the same time frame. 1 repetition at 3/3 = 6 seconds, or 6 repetitions at .5/.5 = 6 seconds, or/and 4 repetitions at 3/3 = 24 seconds or 24 repetitions at .5/.5 = 24 seconds. Not sure how else to say it.
1,
2,
3,
4,
5,
Fast
P = 695
F = 579
V = 192
Slow
P = 649
F = 546
V = 161
[QUOTE=sophiecentaur;3720693]nor have you accepted any of the totally straight answers you have been given. Are we all out of step but you?
See 1 to 5, all point to more force/strength being used by the faster repetitions.
Sorry, I did/do not mean that, I am only trying to get an answer, but when I put practical answer, or what actually happens, some people think/seem they can ignore this and in turn do not, or cannot answer, and I don’t understand this. Let me say it short again, if I hit muscular failure faster, have not I used up my temporary force/strength, than the person who is still doing the repetitions but slower ??? If not what answer would you give ???
I have been polite all along, I came here to learn, and will try to learn more.
Just take 1, if an EMG machine says I have more muscle activity, I would have thought people would want to understand this, or find out more. I don’t call an EMG Waynephysics, its World physics.
Please sophiecentaur, I do thank you for your time and help, but I do not want to turn this into anything else except a nice friendly debate, and would rather just talk physics and practical World equations/tests.
Wayne
Jan21-12, 12:28 PM   #47
Recognitions:
Wayne
An EMG may not be Waynephysics but, without reading about what it claims to do, I have to assume it is EMGPhysics which may not be real Physics at all. It wouldn't be the only thing that's been sold on dodgy Science now, would it? Do you have a link about it?
You say you would "rather talk Physics" but you seldom actually do. That's my point. You talk your own home-brewed version which is not compatible with the real stuff.
Jan21-12, 12:58 PM   #48
You contradict and repeat.
The fluctuations of force in fast lifting, as in the higher fluctuations of force must also require “more” energy, as they are using “more” force and “more” of the temporarily force/strength that is available, how else can you use more energy if it’s not used up by more of the fluctuations of force in fast lifting, as in the higher fluctuations of force. And as both lifting slow and fast have the same temporary force/strength, why is it not used up in slow so fast ??? As it must be using less of its available temporary force/strength.
We all know this, and is it not because when you use a higher force out of the temporary available force/strength you “have” to be using more of the temporary available force/strength ??? How else can you use more energy ??? I repeat, Its because you “have” to be using more of the temporary available force/strength, “if” you did not use more of the temporary available force/strength, like you in the slow, you will and do have more force/strength left, as you do.
Please could you or anyone else just try and answer the above ???
You contradict and repeat again.
Force/strength is what the energy is powering, so when the temporary force/strength is used up, the energy is used up, or when the energy is used up, the temporary force/strength is used up, and you can’t have one used up without the other in this instance. I repeat as above, the higher.
Odd question to ask, the energy, is the energy that in this case is the energy for the muscular force/strength, to which the muscles force/strength moves the weight. And you as you know only have so much energy and force for a certain time frame of lifting. You are trying to say the energy is used up because of nothing ??? But it’s the force/work that the muscles are doing that uses up this energy, and if you use “more” force/strength faster, the energy gets used up faster.
Wayne
Jan21-12, 01:35 PM   #49
Wayne
That's NONSENSE.
You don't use more "force" from the "temporary available force".You use more energy from the available energy to be able to apply force.
That doesn't mean you use more overall force...it means you use energy at a higher rate.Apples and oranges.
Look...that's enough.You created your own physics and terms to feed your obsession and you want us somehow to understand your nonsense and agree with you.That's too crazy even for you.
Jan22-12, 03:15 PM   #50
Recognitions:
Wayne.
Would you expect to conversation about tennis if you insisted on using the language of football? This is effectively what you are trying to do with your arrogant misuse of the vocabulary. Learn the right terms or go to a less rigorous forum. You may get a (wrong) answer that will make you happy.
Jan22-12, 04:26 PM   #51
douglas wrote;That's Waynesphysics.Greater energy expenditure doesn't equate greater force.
Yes it does, we covered this in another debatehere on this forum. I thought everyone knows and agrees on this, you only have to go to any nutritional site of book to find this out. You “can not” move faster without “more” force, you “can not” use more force without using more energy, to say other trying to alter physics. WHY are we going here again.
Now for another contradiction.
douglas wrote;You spend more energy in fast lifting because it takes more energy to generate force than to maintain it.
You just said, I quote; Greater energy expenditure doesn't equate greater force you then say and contradict yourself, I quote; You spend more energy in fast lifting because it takes more energy to generate force
Yes yes yes, this is what I am and have been saying all along, bingo, yes it “does” take more energy to produce and generate more {more as in the longer you try and use force} and higher force than to maintain it, as in holding the weight half way up, or moving the weight up slow like in the slow repititions.
douglas wrote;It's a purely biological matter.
On a physics site, this is not an answer; it seems a way of getting round, you don’t seem to know. Or do you mean to move faster takes more force and higher force, and thus energy. In the fast you use more power, power is the rate at which energy is transferred, power is the rate at which this work is performed, thus I use more force doing more work and need more energy to do this.
You seem to be thinking energy is the force, it’s not, energy is the energy powering the force/strength of the muscles, and basically the muscles fuel is adenosine triphosphate or simply ATP, Creatine, phosphagen, glycolysis, and oxidative. I repeat, if you only have a certain amount of force/strength, when say lifting 80% {and we all do only have a limited force/strength to use} the faster, or the more of this limited force/strength you use, the faster the total or overall force/strength is used. So use low force/strength slower like you, and it “will” last longer, as it does, as you hit muscular failure about 50% slower doing the repetitions slower.
Wayne
Thread Closed
Thread Tools
Similar Threads for: Impulse/force in pounds for the time frame
Thread Forum Replies
most force/strength used in the same time frame General Physics 69
Impulse question about Force and time Introductory Physics Homework 2
Force vs. time graph (Impulse) Introductory Physics Homework 16
Impulse and Force-Time Graph Introductory Physics Homework 2
Velocity as a function of force/impulse/time. Introductory Physics Homework 2
