Fluid mechanics, why does the air flow faster over the wing?
The discussion centers around the question of why air flows faster over a wing, exploring concepts from fluid mechanics, including the Kutta Joukowski theorem, Bernoulli's principle, and circulation. Participants examine the implications of these concepts for understanding lift and airflow dynamics around wings, particularly in the context of different flow conditions such as laminar and turbulent flow.
  • Some participants reference the Kutta Joukowski condition, suggesting it relates to the parallel and equal velocity of streamlines above and below the wing, which influences circulation.
  • Others argue that the Kutta condition does not dictate the relative velocities of the airflow over the wing, emphasizing that the faster airflow does not directly explain lift.
  • A participant mentions that lift is caused by pressure differences at the boundary, with the airspeed at the boundary being zero, complicating the use of airflow speed as a direct explanation for lift.
  • There is a discussion about the role of circulation in creating different velocities above and below the wing, with some asserting that higher velocity contributes to lift as indicated by Bernoulli's principle.
  • Concerns are raised about the implications of separation layers and turbulence affecting the flow dynamics and circulation after the wing.
  • One participant notes that the Kutta condition requires bounded velocity rather than continuous velocity, suggesting complexities in the relationship between velocity and flow stability.
Participants express differing views on the relationship between airflow speed and lift, with no consensus reached. Some support the idea that faster airflow contributes to lift, while others challenge this notion, emphasizing the role of pressure and circulation instead.
Limitations include unresolved assumptions about flow conditions, the effects of viscosity, and the applicability of Bernoulli's principle in various scenarios. The discussion also touches on the complexities of vortex dynamics and the implications of different flow regimes.
  • #91
Listen, the potential flow around a cylinder shows that the the velocity can be described by the potential function of a doublet and a free stream, which give you
[tex]\phi(r,\theta) = U_{\infty}\left(r+\frac{R^2}{r}\right)\cos\theta[/tex]
Differentiating to get velocities
[tex]v_{r} = U_{\infty}\left(1 - \frac{R^2}{r^2}\right)\cos\theta[/tex]
[tex]v_{\theta} = -U_{\infty}\left(1 + \frac{R^2}{r^2}\right)\sin\theta[/tex]
At the surface where [itex]r = R[/itex],
[itex]v_r = 0[/itex]
[tex]v_{\theta} = -2U_{\infty}\sin\theta[/tex]
Clearly, that is not uniform for all [itex]\theta[/itex]. The velocity is symmetric about the [itex]x[/itex]-axis, but it is not uniform along the surface. This is in the frame of reference of the cylinder, by the way. If you look at it, that means at the stagnation points, the velocity in this frame is zero and at the top and bottom, it is [itex]2U_{\infty}\hat{\imath}[/itex] in Cartesian coordinates. Between these points along the surface the velocity varies smoothly. It is not a constant on the surface. You can find that canonical example in any aerodynamics book or other fluids book that includes potential flow.
  • #92
Absolutly right! However, I have been trying to get across the velocity relative to the remote field. The reason was to show that the Bernoulli Principle did not apply tangent to the surface. Converting the flow relative to the surface to relative to the field is a pretty simple process.
(As a uneducated tech designer, I configurated missles and tactical aircraft using the most basic equations. I never had time for real "rocket science".)
  • #93
I have absolutely no idea what you are trying to get at then. Based on this quote
Stan Butchart said:
While it is an instantaneous picture, all of the surface intercepts are at 1V.
It leads me to believe you are saying the velocity is 1V everywhere on the surface. It isn't.
  • #94
Right, relative to the surface it is not. However, while it moves along the surface it is moving thru space at 1V because the cylinder is moving.
My reason to continue to pursue this is to try to understand better how to convey concepts. (Which I am failing!)
You might give http://svbutchart.com a shot
  • #95
I am having trouble seeing what the point you are trying to make with all of this. What do you mean Bernoulli does not apply tangent to the surface?
In a real fluid the particles directly in contact with the surface moves with the surface because of viscosity. Is this what you are talking about? But the velocity of the fluid above the surface is certainly not moving at a constant velocity.
  • #96
But this just isn't true. In the frame where the object is moving, the only places where the flow is moving with speed [itex]U_{\infty}[/itex] are the two stagnation points and the points on top and bottom where [itex]\theta = \pm 90^{\circ}[/itex].
Keep in mind I said speed. If you look at it, at the stagnation points, [itex]V = -U_{\infty}\hat{\imath}[/itex], but at the top and bottom points, [itex]V = U_{\infty}\hat{\imath}[/itex]. These are not the same quantities. Also note that in between these points along the circumference, the velocity varies between these two, meaning there are points where [itex]V = 0[/itex], points where [itex]V = \frac{1}{2}U_{\infty}\hat{\imath}[/itex] and any other concoction [itex]V = nU_{\infty}\hat{\imath}[/itex] where [itex]-1\le n\le1[/itex]
Velocity is absolutely not constant along the circumference in any frame or reference.
Expanding on this, Stan originally specified an ideal fluid, meaning zero viscosity.
  • #97
The point is to present an understanding to the hundreds that search these pages.
Bernoulli is based upon differences in the speed at different points in the inertial flow. Speed calculated related to different points on the surface does not reflect the actuual inertial flow. Bernoulli Princple does not fit.
However, the Bernoulli Equation with velocity relative to the curved surface does fit when paired with the normal acceleration of turning flow.
If we take the accepted tangential velocity and reconcile it with the cylinder velocity, the inertial velocity will be 1V at all points.
  • #98
No it won't. This is an objective fact.
  • #99
boneh3ad said:
at the top and bottom points, [itex]V = U_{\infty}\hat{\imath}[/itex]. These are not the same quantities. QUOTE]
Could you expand on that statement?
Another way using the accepted equation for velocity relative to the surface. v=2sinA*V
i run a radius line from the center out past the surface at angle A.
At the intercept I place a 1V vector running fwd.
I reflect the 1V vector across the radius line. It defines 2 A from horizontal.
The base of the 2A triangle is the velocity, tangent and relative to the cylinder.
The reflected vector is the inertial vector of the flow relative to far field. It is always 1V.
I am not sure why I am finding this concept so difficult!
  • #100
Because your concept is wrong. There is no frame of reference where the speed is 1V along the entire surface.
And to expand on what you referenced, the speed at those points I mentioned is the same but the velocity is not. I was noting the difference.
  • #101
One last shot.
we have a fluid that is moving relative to the remote air. We have a body that is moving relative to the remote air. The body and moving air are moving relative to each other.
I mark the lip of a glass and place it upside down on the table and rotate it. (I should accelerate and decclerate it but that is a detaile.) Now as i rotate it as I move it across the table. What has the mark traced on the table?
I have resolved it from the source/sink pattern. I have resolved it from the tangental velocity relative tothe surface and i have resolved it from the cylinder surface velocity equation.
I have graphed its path as described in http://svbutchart.com
I have never ever suggested that the constant 1V was relative to the cylinder.
  • #102
Stan Butchart said:
One last shot.
You have to be careful with your choice of words. Velocity and speed are not the same thing. Going through the math, in the frame you are describing, the speed of a parcel of fluid is, in fact, going to be [itex]U_{\infty}[/itex] along the circumference. The velocity isn't, and is a vector quantity. Additionally, your site is quote difficult to follow. For anyone else on here that has been reading along and thought Stan's explanations were somewhat opaque, I go through the math showing this below.
Earlier, I talked about potentials. The equation Stan keeps quoting is the same equation as mine for [itex]v_{\theta}[/itex], only you have the angle defined differently. My angle was defined in a typical coordinate system with 0 being on the right at the x-axis and increasing counter-clockwise. Otherwise, the two are identical. I am starting from my equation since it will make things easier to change to a Cartesian coordinate system and change frames.
Now, if we want to switch into a Cartesian system, we take my results for [itex]v_{\theta}[/itex] and [itex]v_{r}[/itex] and plug them into
[tex]u = v_r\cos\theta - v_{\theta}\sin\theta[/tex]
[tex]u = v_r\sin\theta + v_{\theta}\cos\theta[/tex]
Since we already determined that on the surface, [itex]v_{r}=0[/itex], this simplifies to
[tex]u = 2U_{\infty}\sin^2\theta[/tex]
[tex]v = -2U_{\infty}\sin\theta\cos\theta[/tex]
This defines the vector field on the surface of the cylinder in Cartesian coordinates in the frame where we are riding along with the moving cylinder (so it has no velocity and the free stream is moving). Now to change reference frames such that we are viewing the cylinder moving through the stagnant fluid, we just have to add the following:
[tex](-U_{\infty},0)[/tex]
Leaving us with
[tex]u = 2U_{\infty}\sin^2\theta-U_{\infty}[/tex]
This is the velocity vector along the surface in a Cartesian coordinate system in the inertial frame. The cylinder is moving through stagnant air. We can transform this back into cylindrical coordinates for simplicity using
[tex]v_r = u\cos\theta + v\sin\theta[/tex]
[tex]v_{\theta} = -u\sin\theta + v\cos\theta[/tex]
This leaves us with (and you can do the algebra if you want)
[tex]v_r = -U_{\infty}\cos\theta[/tex]
[tex]v_{\theta} = -U_{\infty}\sin\theta[/tex]
Taking the magnitude of this, it is easy to then show that
[tex]|\bar{V}|=U_{\infty}[/tex]
So yes, indeed, the fluid parcel is moving with a constant speed of [itex]U_{\infty}[/itex] in an inertial frame. The problem is, this doesn't tell us a lot about the forces on the cylinder. The important quantity is the speed with respect to the cylinder.
  • #103
The only point here was that the Bernoulli Principle was not at work along the surface but that the Bernoulli Equation was, based on normal acceleration.
  • #104
That doesn't make any sense. Bernoulli's equation makes perfect sense in this situation, especially since we are doing this ideally. Just because the result of something is zero in a certain frame or reference doesn't mean it doesn't apply. Regardless, the important frame is that which follows the body.
  • #105
In the long run you might be right.If we only want numbers the Bernoulli Equation dos just fine. However, most of the thousands that search the web and books are only looking to uderstand the lifting process.
The largest percentage of the hundreds of articles and sites firmly define the concept that pressure changes are created by linear variations in the flow tangent and relative to the surface. (in the sense of the venturi)
There is additional group that explains that the velocity changes are in response to the pressure variations.
The primary flow is from displacement. The source/sink pattern describes the motion effects throughout the entire flowfield. These instantaneous velocity vectors are relative to the remote (still) fluid. When we add the fwd motion of the cylinder we can find the tangent velocity relative to the surface. This tangent velocity, in combination with the surface radius produces the normal acceleration, v^2/R, creating a pressure gradient that must be integrated across the entire flowfield. It is almost luck that all of this can be reduced again to the Bernoulli Equation.
We find that we can still apply the Bernoulli Equation to the tangent velocity, relative to the surface. But is this the Bernoulli Principle??
  • #106
boneh3ad --It appeares that I have a real problem here. If you (or anyone else) have any suggestions my "e" address is on the site. http://svbutchart.com
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 48 ·
  • · Replies 52 ·
