Electric Field in a Conductor: Is the Image Misleading?
The discussion revolves around the nature of the electric field within a conductor, particularly in the context of electrostatics. Participants examine whether an image depicting an electric field inside a conductor is misleading, considering the behavior of charges and fields in static conditions.
  • Some participants assert that there is an electric field inside the conductor, suggesting that a positive test charge would move towards the outer surface.
  • Others argue that in electrostatics, there is no electric field inside the conductor, as charges redistribute to eliminate any internal field when in equilibrium.
  • One participant emphasizes the importance of considering the static nature of electrostatics, stating that a test charge placed inside would not move due to the absence of an electric field.
  • Another participant describes the behavior of charges in response to an applied electric field, explaining that they rearrange to create an opposing field, leading to no net field inside the conductor.
  • Participants discuss the directionality of electric fields created by induced charges, noting that these fields oppose the applied field.
Participants express conflicting views regarding the existence of an electric field within the conductor. Some maintain that an electric field is present, while others contend that it is absent in electrostatic conditions. The discussion remains unresolved with multiple competing perspectives.
The discussion highlights the dependence on definitions of electrostatics and the behavior of charges in conductors, as well as the implications of static versus dynamic conditions. There are unresolved aspects regarding the interpretation of the image and the conditions under which the electric field is analyzed.
yellowbus
The image below is from giancoli. There is clearly an electric field inside the conductor, going from the + charge on the outside surface of the wheel to the - charge on the inside surface of the wheel. There is an electric field inside this conductor because if I drop a + test charge in the middle of the wheel (between the outer and inner surfaces), the electric field would take the test charge to the outside surface of the wheel. Is this image just misleading?
You are forgetting that you are dealing with electrostatics. Electrostatics concerns the study of electric fields when all the charges are static. If you placed a test charge inside the conductor, it would not move as there is no electric field. If you dump a real charge on the inside, it would spread out to the edges until the system came into equilibrium and returned to a static situation. You would again find yourself with no electric field on the inside.
okay, I drew the E-field vectors in blue arrows going from the positive charges to the negative charges along the surface of the wheel. Are you saying this doesn't exist?
Yes, there is no electric field inside the conductor. The charges in a conductor are free to move about. So anytime that you have an applied electric field, the charges will move throughout the conductor so long as a net electric field inside the conductor exists. However, the charges move in such a way that they create a second electric field that opposes the applied field. Thus, eventually the charges will move and configure themselves in such a way that there no longer exists any net field inside the conductor. Pengwuino stated that you need to keep in mind that this is electrostatics, so we can assume that the field was applied an infinite amount of time ago. So regardless of how slow the charges take to configure themselves (which in actuality is rather quick), they will eventually arrange themselves to expel the applied field.
In your example, take note of the directions of the electric fields. The applied field points radially outward and induces a negative charge on the inside wall and a positive charge on the outside wall. Inside the conductor, these negative charges create an electric field that will point radially inward. The positive charges likewise create an electric field that points inward. So you can see that the induced charges create fields that oppose the applied field.
  • · Replies 21 ·
