How can I easily derive the kinematic equations for constant acceleration?
  • Context: High School
  • Thread starter Thread starter Arijun
    Derive Kinematic
The discussion focuses on deriving the kinematic equations for constant acceleration, specifically the five key equations: x = x0 + v0t + (1/2)at², x = (1/2)(u + v)t, v = u + at, and v² = u² + 2as. The first approach emphasizes using basic definitions of displacement and acceleration, while the second approach utilizes a linear velocity-time graph to visualize the relationships. The participant suggests that frequent use of these equations aids in memorization, particularly for tutoring purposes.
  • Understanding of basic physics concepts such as displacement, velocity, and acceleration.
  • Familiarity with integration and its application in deriving equations.
  • Knowledge of linear graphs and their interpretation in physics.
  • Ability to manipulate algebraic equations for solving variables.
  • Study the derivation of the kinematic equations in detail using calculus.
  • Explore the application of linear velocity-time graphs in physics.
  • Learn about vector quantities and their significance in kinematics.
  • Practice problems involving the kinematic equations to reinforce understanding.
Students, tutors, and educators in physics, particularly those teaching or learning about kinematics and constant acceleration concepts.
Arijun
I'm tired of having to look up the kinematic equations every time I need to use them (I tutor lower devision students a lot). Is there an intuitive and memorable way to derive them?
As in, it's easy to derive x=x0+v0t+at2 just by integrating a constant force. Can I get the others without relying on some other equations I will inevitably forget?
The equations you refer to are, I take it, for constant acceleration.
For a start, put x0 = 0. You can always add it back in if you need it.
First approach
One basic equation is: x = (1/2)(u + v)/t [u = initial vel, v = final vel]
This embodies displacement = mean velocity [itex]\times[/itex] time.
The other basic one is v = u + at
This is a re-arrangement of the definition of acceleration a (if acceleration constant).
There are 5 equations in all. Each involves 4 of the 5 variables: v, u, x, t, a.
The other 3 equation are found by eliminating u, v, t in turn. If you've done it once or twice it should be quick and easy.
Second approach
Use a linear velocity-time graph running between (0, u) and (t, v). The slope (gradient) gives the acceleration, the area under the graph gives the displacement. This area is a rectangle plus a triangle. Hence the first two equations as mentioned above. Re-express the triangle area using a, and the other 3 equations will emerge.
If you use the equations often enough, you'll remember them! I do, and my memory is pretty terrible...
Note
4 of these equations relate vector quantities (or, to be fussy, components of vector quantities). The fifth equation, v2 = u2 + 2as, is different. It relates scalars (dot products). Not that you'd want to raise this with students meeting the equations for the first time!
  • · Replies 49 ·
  • · Replies 21 ·
  • · Replies 20 ·
