Electronic circuit with Op-Amp, Switch and Diodes
This thread discusses an electronic circuit involving operational amplifiers (op-amps), switches, diodes, and lightbulbs. Participants explore the circuit's functionality, analyze voltage and current calculations under different switch conditions, and clarify the behavior of the op-amp in the circuit.
  • Homework-related
  • Some participants identify the op-amp configuration as a non-inverting op-amp, while others argue it is an inverting op-amp, leading to confusion about the output voltage signs.
  • There is a discussion about the output voltage (Vout) being -8V when the switch is in position 1 and +8V when in position 2, although some participants question the accuracy of these values.
  • Participants express uncertainty about the voltage at point C, with claims that it will not be zero, contradicting earlier assertions.
  • There are differing views on how the circuit operates based on the switch position, with some participants explaining the current flow and others questioning the implications of the battery's orientation.
  • One participant suggests that the action of the circuit should be explained in terms of inputs and outputs, while another expresses frustration about how to approach the open-ended question regarding circuit action.
Participants do not reach a consensus on the op-amp configuration or the output voltage values, indicating multiple competing views and unresolved questions regarding the circuit's behavior.
There are unresolved mathematical steps and assumptions regarding the circuit's operation, particularly concerning the voltage calculations and the interpretation of the op-amp's behavior in different switch positions.
This discussion may be useful for students studying electronic circuits, particularly those working with op-amps and seeking to understand circuit behavior under varying conditions.
Femme_physics
http://img689.imageshack.us/img689/6668/mycircuit.jpg
Given a circuit that includes Operational Amplifiers, double-switch - S, for two situations, 1 and 2. Type of switch - DPDT - Double pole double throw. Two diodes and two lightbulbs, L1 and L2.
Given:
Voltage of each diode = 0.7V during conductance.
Lightbulb L1 is red, and its resistance is 120 ohms
Lightbulb L2 is green and its resistance is 150 ohms.
The rest of the values are as they appear in the circuit
Answer the following questions:
A) Explain how the circuit works. What is the name of type of Op-Amp connection, in this type of circuit? At which condition of switch S is every lightbulb turns on?
B) Calculate Va, Vb, Vc, at points a, b, c, when S is at condition 1.
C) Calculate Va, Vb, Vc, at points a, b, c, when S is at condition 2.
D) Calculate the current at the red lightbulb when it's turned on. Calculate the current at the green lightbulb when it's turned on. Which lightbulb shines brighter?
A) (I'm really not sure what do they mean by explain the way the circuit works. I'm tempted to answer with "Read and electronics book, *******!")
But, basically, it's about current flowing and depending on the condition of the switch, and the amplification, the lightbulbs either light up or don't.
The Op-Amp in this type of connection is a NON-INVERTER op-amp.
When the switch is at case 1, we see that Vout is negative, so current flows from minus to plus... therefor L1 lights up.
When the switch is at case 2, current still flowing from minus to plus, though this time L2 lights up due to the connections.
B) They're all zero because the current skips the op-amp entirely.
C) Vc is basically Vout.
So, as per the formula I pasted above:
Vout = -R2/R1 x Vin = -40k/10k x 2 = -8V
Vc = -8V
Va = 0 (because there is no current source or anything between V+ and the ground point)
Vb is a bit more complicated
I use KVL to get:
-8 + (40k x It) + (10k x It) -2 = 0
It = 0.2 [mA]
Vb = It x R1 = 0.0002 x 10000 = 2V
Vb = 2V
I'll answer the last question once I see the rest of it is correct :)
Hi FP... good old negativr feedback opamp ! It is an INVERTING opamp
You are correct to recognise how the circuit works and you get Vout = -8V when switch in position 1 and Vout = +8V when in position 2.
Can you see how the diodes + lamp branches will respond to one output being -ve then being +ve?
Part(B) voltage at c will not be zero
Vout is +10V when switch is at position 2.
Well spotted 'I like physics'
Apologies...careless
Sorry 'I like physics' I think Vout =+8V when the switch is in position 2. In both switch position Va and Vb = 0
Why do you think it is +10V?
Sorry, I overlooked the "Earth" connected to non-inv terminal.
Good trick question though.
How come Vout is once positive and once negative?
The way I see it it's always the same formula
Vout = -R2/R1 x Vin
Therefor no matter the switch condition Vout must always be negative!
with the switch in position 1 can you see that the + of the battery is connected to V-
via R1
And with the switch in position 2 the - of the battery is connected to the V- via R1
PS
The - in the equation tells you the amplifier is INVERTING so a + at the input produces a - at the output and a - at the input produces a + at the output
Vout = -R2/R1 x Vin
It has to do with the ground connection or reference potential.
Say for example, you are using a multimeter to measure battery voltage.
One terminal of the multimeter is reference, which you always connect to -ve terminal of the battery, the other connects to +ve terminal and you get 1.5v. What happens if you reverse the connection?
If I reverse, it's -1.5v.
via R1
Agreed.
PS
I see! :)
BTW - is this the way the current flows in the circuit for S1?
http://img828.imageshack.us/img828/5405/tukgn.jpg
No, it goes the other way. Remember Vout is -8V when Vin is +2V
When the switch is in position 2 the 2V battery is the other way round (upside down)
Then the current will have the direction you have shown
I think you have drawn the situation for S2, except that battery is the wrong way around.
This would be correct!
In S1 the battery would be as you drew it, but then the current would flow from the plus pole at +2V to the opamp at 0V.
Wait, but the battery coordinance never changes. If the longer line of the plus side is up, it stays up, unless someone physically changes the circuit, no?
You mean to tell me it's like this? (I drew it just focusing on the +2 and -8) ->
http://img851.imageshack.us/img851/9973/opopu.jpg
In S2 the wires from the battery are crossed, so the plus pole (the longer line) connects to the bottom of the circuit.
Schematically you can indicate this by drawing the longer line on the bottom while not crossing the wires.
Yep! :)
Ah, perfectly understood :) Though, one thing is still confusion to me. When asked "Explain the action of the circuit"-- what the hell do they expect me to write? To start explaining about op-amps and switches?
Hmm... the action of the circuit.
I'd interpret that as saying what "you" can do to the circuit (input), and how "you" would see the result of the circuit (the output).
So what does the circuit do if the switch is in S1 (one possible input)?
And what in S2 (the other possible input)?
Can you light up both LED's simultaneously (possible output)?
Or switch them both off simultaneously?
Furthermore, what voltage is used for the switch (the input) and what voltage is used on the LED's (the output)?
Well, in that case then they should ask this question last, not first! I got to do some calculations first!
Okay, since it's the first question, perhaps you should only say that you can put the switch either in S1 or S2.
Or just make up a nice story, since these type of open questions are not really hard science. ;)
:) Agreed.
In any op-amp, whenever you get that either Va, or Vb = 0, that means the other one is necessarily 0, as well?
I'm referring to the locations of a and b as they are in my current exercises near V- and V+
Edit: For S2, this is the case right? ->
http://img444.imageshack.us/img444/692/feely.jpg
In this diagram the - of the battery is connected to the - input. The amplifier is inverting so Vout will be + which means that current will flow from Vout to the right to go through the diode on the far right... just as you have drawn.
BUT the current goes to the left through the feedback resistor so your current through the battery part of the circuit is the wrong way round
edit
drawing attached
Yes...and no. :rolleyes:
Va and Vb are equal providing the OP-AMP is operating as an amplifier and in the linear region. But sometimes OP-AMPs are used as comparators, where the output sits at either +Vcc or -Vcc and nowhere in-between, in which case it is not operating as a linear amplifier, and it therefore cannot make Va=Vb. (I'm sure you encountered this with an earlier OP-AMP circuit.)
So you have to be confident (or else assume) that it is operating as an amplifier in order to say Va=Vb.
Not there yet! Consider the top sketch. The battery's positive voltage is pushing current into the input resistor, as you show. With the feedback resistor arrangement here, this OP-AMP is inverting.
So what does that tell you should be the polarity of the OP-AMPs output voltage?
Agreed.
I'm not sure I understand what you mean by the polarity of the OP-AMP output voltage. You mean Vout? It shoud be -8 [V] as we agreed.
Simply based on the formula
Vout = -Rf/Rv x VIn
Femme_physics said:
Let me see if I got the full picture right...
http://img19.imageshack.us/img19/4117/fullpic.jpg
You mean that in both cases the rightmost LED lights up?
I thought you had found that in one of those cases the left LED would light up...
So if the OP-AMP's Vout is negative, which of those diodes is going to be conducting? What will be the direction of the current through that diode?
(We are still on the top diagram of your latest sketch.)
That's what I thought so initially, but you guys corrected me in terms of how current flows-- that's the conclusion I came to...
So should it be like this?
http://img864.imageshack.us/img864/262/s2s2.jpg
But that means the op-amp current doesn't split-- how come?
At the top diagram? The furthest one will be conducting.
Now you have them both wrong. :cry:
Let's try again, staying with the top circuit, not jumping to the second yet.
If the OP-AMP's Vout is negative, which of those diodes is going to be conducting? Carefully examine the circuit (ignore all your arrows) and decide, then explain why.
If you are happy that the output of the op amp goes -8V or +8V then you can picture the output to behave like a battery as far as the diodes and lamps are concerned.
I have attached a drawing showing how the op amp appears to the diodes and lamps. Can you see how current flows.
(I emphasise that this battery I have drawn is how the output behaves...it is not a real battery !)
Hope this helps:smile:
I still only see the furthest one conducting :( I don't know what's wrong with my S1 current loop sketch?..
technician-- i haven't read your reply yet. Sec.
  • · Replies 21 ·
  • · Replies 0 ·
