| New Reply |
Question about polarized capacitors |
Share Thread | Thread Tools |
| Feb21-12, 03:20 AM | #1 |
There are two types of capacitor, non-polarized and polarized. The non-polarized capacitor holds equal amounts of charge in each of its two plates so that a difference in charge is only achieved when electrical current from a power supply transfers electrons from one plate to another to cause a potential difference, storing electrical energy in the process. When the power supply is cut off and a load is connected to the non-polarized capacitor, the electrons flow from the charged plate, to the load, and back to the other plate until both plates hold an equal amount of charge and the capacitor once again becomes neutral. But in the case of polarized capacitors where one plate has excess amounts of charge compared to the other plate, will the plate with excess amounts of charge not spontaneously transfer electrons to the other plate if connected to a load or shorted, even without the aid of a power supply because there is already an imbalance of electric charge? And will this transfer of electrons not balance out the charges on the two plates and cause the polarized capacitor to become non-polarized?
| Feb21-12, 03:24 AM | #2 |
Recognitions:
Polarized just means the capacitor has to be connected a certain way.
It does not already carry a charge when you buy it from the store. If you charge it, it has a charge which you may then discharge if you wish. |
| Feb21-12, 03:30 AM | #3 |
So why does the polarized capacitor have to have a positive and negative terminal designation if the capacitor uses two plates that both have the same capacity to store electric charge? Is there something in the structure of this type of capacitor that will destroy it if the polarity of the supply current is reversed?
| Feb21-12, 03:47 AM | #4 |
| Feb21-12, 03:54 AM | #5 |
Why does the dielectric film breakdown when the current travels in the wrong direction?
| Feb21-12, 04:17 AM | #6 |
The film is built up by electrolysis and by use of a suitable electrolyte and a d.c. current.If the power supply is connected the wrong way round the electro/chemical reaction reverses and the film breaks down.
| Feb21-12, 05:01 AM | #7 |
So, does the supply current used to build up charge go into the metal plate or into the electrolyte plate?
| Feb21-12, 07:27 AM | #8 |
There is an electrolyte between metal plates and the thin film makes the dielectric.The plate with the film deposited on it can be considered as the anode and the plate plus the unreacted electrolyte can be considered as the cathode.The charge is numerically equal on both electrodes one side being positive and the other side negative.Try googling for constructional and other details
| Feb21-12, 08:33 AM | #9 |
So that means that sending the supply current into the plate with the film will reverse the electrochemical reaction, causing the film insulation to breakdown and short the capacitor.
| Feb21-12, 08:51 AM | #10 |
| Feb21-12, 08:55 AM | #11 |
Exactly, the current must flow from the anode to the cathode and not in the reverse direction. Otherwise the film will break down.
| Feb21-12, 09:02 AM | #12 |
That's right.Take care when you use them.
| Feb21-12, 09:46 AM | #13 |
So when the electrolytic capacitor is manufactured, there is a designated side with the cathode plate and beside this plate is the microscopic metal oxide layer, followed by the absorbent spacer material soaked in electrolytes, then the dielectric insulator and lastly the anode plate.
| Feb21-12, 02:04 PM | #14 |
The dielectric is the oxide layer.I'm assuming that the easiest manufacturing process would be to form the oxide layer by means of a current after everything else has been constructed.The direction of the current chosen determines what side would be the anode.
| Feb21-12, 10:34 PM | #15 |
There is a diagram specifically stating that there are two dielectric layers on each side of the electrolyte, one is an aluminum oxide compound placed beside the anode and the other is an air oxide compound placed beside the cathode. At the very center of these layers of material is the absorbent material soaked in electrolyte. The diagram is shown below, courtesy of
http://rpmedia.ask.com/ts?u=/wikiped...au-english.png
| Feb22-12, 03:26 AM | #16 |
There are two layers but only one of these,the aluminium oxide,is labelled as the dielectric.
| Feb22-12, 05:52 AM | #17 |
Is this, from the PF Library, wrong … Polarised capacitor (or polar capacitor): |
| New Reply |
| Thread Tools | |
Similar Threads for: Question about polarized capacitors
| Thread | Forum | Replies | ||
| Question on AC Capacitors used in place of DC Capacitors | Electrical Engineering | 3 | ||
| question on current flow through polarized capacitors | Electrical Engineering | 6 | ||
| Polarized light filtering question. | General Physics | 4 | ||
| simple question about polarized materials | Introductory Physics Homework | 0 | ||
| Question concerning polarized entangled beams | General Physics | 0 | ||
