Two subsequential limit questions
  • Thread starter Thread starter hiro
    Limit
The discussion involves two questions related to subsequential limits within the context of sequences. The first question concerns a recursively defined sequence and the convergence of its subsequences, while the second question asks for the construction of a sequence that converges to a specified limit within a given range.
  • Participants discuss the monotonicity and convergence of subsequences derived from a recursively defined sequence. There is an exploration of induction proofs to establish these properties. For the second question, participants consider the application of a theorem regarding subsequential limits and discuss the conditions under which a sequence can be shown to converge to a specific limit.
Some participants have offered insights into the limits of the sequences and suggested potential approaches for proving convergence. There is an ongoing exploration of the structure of the sequences and the implications of their properties, with no explicit consensus reached on the methods to be employed.
Participants are working under the constraints of homework guidelines, which may limit the information they can share. The discussion includes questions about the definitions and properties of subsequences and convergence, as well as the need for clarity in the recursive definitions provided.
hiro
I have two questions involving subsequential limits. One I have started and understand what I need to do, the second I really don't know how to start.
First question
Let 0 ≤ a < b < +∞. Define the sequence a[itex]_{n}[/itex] recursively by setting a[itex]_{1}[/itex] = a, a[itex]_{2}[/itex] = b, and a[itex]_{n+2}[/itex]=(a[itex]_{n}[/itex]+a[itex]_{n+1}[/itex])/2 [itex]\forall[/itex]n.
Show that the sequences a[itex]_{2n}[/itex] and a[itex]_{2n-1}[/itex] are monotonic and convergent. Does a[itex]_{n}[/itex] converge? To what?
Solution attempt
This is the second part of the question. The first part I already proved, and shows that if a[itex]_{2n}[/itex] and a[itex]_{2n-1}[/itex] both converge to the same limit then a[itex]_{n}[/itex] converges to that limit.
I can show that both subsequences are bounded. I can also show that if their limits exists, they are the same (by plugging in a[itex]_{2n}[/itex]→L a[itex]_{2n-1}[/itex]→L and using the recurrence relations). The limit is obviously a+(2/3)b (though I need to prove it).
So all I need to do is show that a[itex]_{2n-1}[/itex] is nondecreasing and a[itex]_{2n}[/itex] is nonincreasing. Unfortunately I can't find the right induction proof to show this. Then I need to find one of the limits (either the full sequence or the even or odd subsequence).
Second question
Let λ[itex]\in[/itex][0,1]. Show that there exists a sequence r[itex]_{n}[/itex] such that r[itex]_{n}[/itex]→λ. r[itex]_{n}[/itex][itex]\in[/itex]{0,1/2[itex]^n[/itex],2/2[itex]^n[/itex],...,(2[itex]^n[/itex]-1)/2[itex]^n[/itex],1}.
Solution attempt
The correct theorem is presumably:
Let S denote the set of subsequential limits of a sequence s[itex]_{n}[/itex]. Suppose t[itex]_{n}[/itex] is a sequence in S[itex]\cap[/itex]ℝ and that t[itex]_{n}[/itex]→t. Then t belongs to S.
However I can't figure out how to apply it.
Thanks for your help.
For the first question, the limit should be a+2(b-a)/3.
Can you write the subsequences in a closed form?
For the second question, let e > 0. What about N such that 1 / 2N < e?
The numerators look like a Fibonacci type sequence (a Horadam Sequence?). The bottom is just 2^(n-2). You're correct about the limit, I mistyped. Unfortunately I can't figure out if this helps. Is the pattern more obvious if you split off the odd/even sequences? I can't seem to find a pattern in each individual subsequence.
I'm starting to see the proof for the second problem. As I recall if [itex]\exists[/itex]N such that [itex]\forall[/itex]n≥N |a[itex]_{n+1}[/itex]-a[itex]_{n}[/itex]|<1/2[itex]^{n}[/itex] then the sequence is Cauchy. Because the sequence would be bounded between 0 and 1 the limit exists and must lie in [0,1]. However, that doesn't prove that any real number in that range can be made the limit of the sequence. Can you help with that bit?
The Fibonacci sequence itself can be lifted into a closed form exponential expression, and the subsequences are exponential, or geometric sums. There might be a way to write the whole sequence in a closed form as an alternating geometric sum, now that I think about it. In any case, you want to have a form such that F(1) = a, F(2) = b, F(3) = (a + b) / 2, F(4) = ((a + b) / 2 + b) / 2...
For #2: You want to have for all e > 0 there is an N such that for all n ≥ N, |an+1-an|< 1/2N < e.
Anyway, given real r, how many dyadic rationals of the form i / 2n are you guaranteed to find in the interval (r - 1/2n, r + 1/2n)?
Edit: Also, it may be easier to think about #1 in the interval [0, 1]. Generalizing to [a, b] is fairly trivial.
