| New Reply |
Windmill with Funnel/Cone |
Share Thread |
| Feb21-12, 10:06 PM | #1 |
[I have been searching for an answer to this puzzling question for the past two hours. (To no avail.) A few search results lead me hear, but nobody had raised the question that is in my mind]
Would building a funnel/cone improve the power output of a given windmill? Let us say, for example, that we have a windmill with a 3 meter diameter. The windmill would only capture the energy from the wind within the area [approx. 7 square meters] of its rotation (give or take), correct? So, if you were to build a cone (or a pyramidal funnel) with an area of 28 square meters, wouldn't the energy from the entire area (the 28 square meters) be exerted on the windmill? (I understand the increase wouldn't be perfect, as there are many variables to consider.) Also, does the change in angle (thus altering the length) have any effect on the efficiency of the process? (More efficient compression?) I do apologize if my terminology (and general understanding of fluid dynamics) is not up to snuff. I am only in 12th grade physics - no college craziness :P |
| Feb22-12, 12:48 AM | #2 |
Yes, you will get more power but if you make one big enough to justify adding it you lose the ability to turn the wind turbine.
Many ancient cultures used vertical windmills mounted on the ground or hill with a built structure to funnel the wind into them. These areas also tend to have months of wind from the same direction also. Just look up ancient wind turbines or wind mills and you will get all kinds of examples. |
| Feb22-12, 03:01 AM | #3 |
![]() It acts similar to the fan shrouding below, but it's not quite the same thing: |
| Feb22-12, 05:26 PM | #4 |
@Fleebell: Why would I loose the ability to turn the turbine with a large cone?
@A.T.: Thanks for the suggestion :) Do you happen to know how much more energy a shaped "shroud" will capture in comparison to the cone? [estimate?] Also, the Dyson fan video is interesting (and I looked up some more information about them online), but what are you specifically suggesting? Are you referring to only its shape, or the way that it functions as well? |
| Feb22-12, 07:05 PM | #5 |
Recognitions:
I'm thinking that just increasing windmill diameter somewhat will have more benefit than using a large funnel (cone). |
| Feb22-12, 08:03 PM | #6 |
![]() Anyways, thanks for helping me with this idea. Shame it wouldn't work (as well) as I had hoped, however I am not terribly surprised. |
| Feb23-12, 03:12 AM | #7 |
| New Reply |
Similar discussions for: Windmill with Funnel/Cone
| Thread | Forum | Replies | ||
| coin in funnel | Advanced Physics Homework | 15 | ||
| a coin in a funnel | Introductory Physics Homework | 5 | ||
| Funnel in a vacuum | General Physics | 14 | ||
| Funnel vs. Cylinder | Introductory Physics Homework | 5 | ||
| Why does water spin in funnel? | Classical Physics | 34 | ||
