New Reply
additionl field proportional to magnetisation?
Share Thread Thread Tools
Feb23-12, 10:58 AM   #1
Magnetisation of a sample is net dipole moment per unit volume i.e. M = m(net) / V
It turns out that magnetic field due to the material is proportional to magnetisation
i.e. B(magnetic field due to material) = μM
Any explanation to this? It should be proportional but any proof for this or is it just experimental
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Feb23-12, 04:14 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi jd12345!
Quote by jd12345 View Post
isn't it B = µo(M + H) = µH ?
M and H are measured in electric units, as electric current/distance (Am-1),
(magnetic dipole moment is charge times distance/time, = distance times charge/time = distance times electric current, in A.m)
but B is measured in magnetic units, as magnetic flux/area (Wb.m-2)
there's no fundamental reason for this … they're all the same thing! … it's just more convenient in practice!
so to convert between these different species of units, we must have a universal conversion factor, and that's µo (in Wb.A-1m-1 or T.m.A-1)
µ (as opposed to µo) is just a trick to make it look as if B is proportional to H on its own
New Reply
Thread Tools
Similar Threads for: additionl field proportional to magnetisation?
Thread Forum Replies
Magnetisation for S=1/2 Atomic, Solid State, Comp. Physics 3
Why is the magnitude of the magnetic field proportional to the permeability of free s Classical Physics 5
Magnetic field strength diminishes proportional to inverse cube or inverse square? General Physics 5
Flux of vector field proportional to 1/r^3 through sphere Calculus & Beyond Homework 1
Finding E field inside a sphere with charge proportional to radius Introductory Physics Homework 1
