| Thread Closed |
Harvesting energy from the earth rotation |
Share Thread | Thread Tools |
| Feb23-12, 06:03 PM | #18 |
| Feb24-12, 08:47 AM | #19 |
| Feb24-12, 01:51 PM | #20 |
I think it is going to be worse than that. There is something about the physics of such an arrangement that will always mean the energy in is greater than the energy out, I'm afraid. You have to keep turning the flywheel to generate the rotation - it's a perpetual motion machine by another definition, and like all perpetual motion machines, you have to put energy in in a manner more efficient that taking it out.
| Feb24-12, 03:40 PM | #21 |
| Feb24-12, 04:19 PM | #22 |
So the physics says that you have to put [at least] the same energy in as you'd get out. |
| Feb24-12, 04:25 PM | #23 |
| Feb24-12, 04:44 PM | #24 |
OK.... so to what was the angular momentum transferred, or does this defeat conservation of angular momentum? |
| Feb24-12, 04:50 PM | #25 |
| Feb24-12, 04:59 PM | #26 |
| Feb24-12, 05:40 PM | #27 |
I don't believe so. If it did, then someone should have pointed it out immediately. I recently tried out an example at the local Sci-Port where that had a wheel on an axle that you spun up with your hand. Then you sat in a chair that could turn and rotated the wheel and axle around perpendicular to it's rotational axis. This caused the chair and myself to turn one way. As the wheel spun down I did not return to my original direction.
| Feb25-12, 02:51 AM | #28 |
| Feb25-12, 04:02 AM | #29 |
| Feb25-12, 06:14 AM | #30 |
Gyroscopes' behaviour tends to defeat human's intuition (hence a load of 'anti-gravity' devices try to exploit gyroscopes, due to misconceptions on how they work). I suspect that this is, in part, because we have evolved with the 'lizard' parts of our brain never needing to intuitively comprehend gyroscopic motions, as nothing in the natural world behaves in such a way to need that intuitive comprehension. |
| May27-12, 09:48 AM | #31 |
Recognitions:
I'm guessing Low-Q is thinking of one of these:
http://www.lhup.edu/~dsimanek/museum/advanced.htm BTW: I'm with LURCH. |
| May27-12, 10:42 AM | #32 |
Recognitions:
Angular momentum is still a conserved quantity. Meaning you cannot slow Earth's rotation down without either a) drastically altering it's moment of inertia or b) expelling mass.
In particular, you cannot use a gyro to extract energy from Earth's rotation, because the torque would cause the gyro to tip, until its axis of rotation is aligned with Earth's. |
| May27-12, 11:16 AM | #33 |
Mentor
Using a gyro or a flywheel as an energy storage device is okay. One of the many problems with renewable energy is that it is not available. Solar power needs to be stored during the daytime for use at nighttime, wind power needs to be stored when the wind blows for use when the winds aren't so strong. This isn't perpetual motion; it's just a storage device. And it's lossy, as are all real energy storage devices. There is a way to harvest energy from the Earth's rotation without a) drastically altering it's moment of inertia or b) expelling mass. That way is to piggyback of an existing external torque on the Earth. This tidal station, for example, generates 254 MW of power. |
| May27-12, 12:56 PM | #34 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Harvesting energy from the earth rotation
| Thread | Forum | Replies | ||
| from where does earth get energy for rotation? | General Physics | 5 | ||
| Electromagnetic induction for energy harvesting | Advanced Physics Homework | 0 | ||
| WiFi Energy Harvesting? | Electrical Engineering | 5 | ||
| wind turbine energy harvesting | Mechanical Engineering | 10 | ||
| Source of Energy for the Rotation of Earth | General Astronomy | 11 | ||
