How Do Oily Fingers Affect Hydrated Salt Mass Measurement?
  • Thread starter Thread starter disneychannel
The discussion centers on the impact of oily fingerprints on the mass measurement of a crucible containing hydrated salt. Handling the crucible with oily fingers introduces contamination, leading to an inaccurate measurement of the hydrated salt's mass. This contamination results in an apparent increase in mass, which skews the calculation of the percentage of water in the hydrated salt after the oil is burned off. The conclusion is that the oily residue affects the reported water content by artificially inflating the mass of the sample.
  • Understanding of mass measurement techniques
  • Familiarity with the concept of contamination in laboratory settings
  • Knowledge of hydrated salts and their properties
  • Basic principles of error analysis in experimental chemistry
  • Research methods to prevent contamination in laboratory measurements
  • Learn about the principles of accurate mass measurement in analytical chemistry
  • Explore techniques for calculating percentage composition in hydrated salts
  • Investigate the effects of different types of contaminants on mass measurements
Chemistry students, laboratory technicians, and anyone involved in experimental design and analysis who seeks to understand the implications of contamination on measurement accuracy.
disneychannel
The crucible is handled with oily fingers after its mass measurement but before the ~3 gram sample of the hydrated salt is measured. Subsequently(after measuring the hydrated salt,the oil is burned off. How does this technique error affect the reported % water in the hydrated salt. Explain
The measurement of the crucible will be accurate, but after touching the crucible with the oily fingers, it will contaminate the surface of the crucible. After weighing the hydrated surface and then burning the crucible, it will seem that more water was lost because the oily fingers would have increased the mass of the hydrated salt.
I'm kind of having second thoughts on my answer...part of my mind thinks it will no be affected? HELP!
Your initial response is correct, now convince yourself of it to make sure you understand. Take it one step at a time to determine where the error is. If it helps, make up a number for the mass of the oily fingerprint so you can track its effect quantitatively.
9K
  • · Replies 21 ·
26K
  • · Replies 27 ·
27K
29K
