Alternating Outputs with 555 Timing Chips
  • Thread starter Thread starter gboff21
To achieve alternating outputs with 555 timing chips, two 555s in monostable mode can be used effectively. The first chip is triggered to output high for three minutes, which then triggers the second chip when it goes low. The cycle completes when the second output times out, ensuring no outputs are active after six minutes. A small capacitor between the first output and the second trigger input is crucial for proper operation. Using a 1 meg resistor and a 100 uF capacitor in the timing circuit will yield the desired 180 seconds for each output.
gboff21
Using an array of 555 timing chips I want to turn one output on for 3 minutes then turn it off, then turn another output on for three minutes then turn it off. I understand how to alternate each output but it is having no outputs after 6 minutes that is the problem.
It would seem that two 555's, operated in monostable mode, would do the trick. The first is triggered and its output goes high. This output is tapped, and also drives a second, so when the output goes low it trips the second and its output goes high. When the 2nd times out the cycle is done. Check this website:
http://www.dummies.com/how-to/content/electronics-components-double-up-with-the-556-dual.html
Here is a short video of the circuit operating as you wish:
The key is the small cap between the output of the first 555 (or first half of 556) and the trigger input of the second.
Also, it looks like a 1 meg resistor and 100 uF cap in the timing circuit should give you 180 seconds. You probably already knew that. Hope that helps!
