Design & Execute Trace Table for Polling Station Votes
  • Thread starter Thread starter lionely
The discussion revolves around designing and executing a trace table for processing vote data at a polling station. The data includes special votes, general (valid) votes, and spoiled votes for four parties: DAP, WNA, UPM, and PDR. Participants explore the structure of the pseudocode and its functionality, including how to implement a loop for input and the conditions for terminating the process.
  • One participant presents an initial pseudocode attempt to track votes and determine majority outcomes.
  • Another participant questions the clarity of the problem statement, particularly the definitions of special and general votes, and the criteria for identifying spoiled votes.
  • A participant expresses the need for a complete pseudocode and mentions forgetting part of the code in their initial post.
  • One participant provides feedback on the indentation of the pseudocode, suggesting improvements for readability.
  • Concerns are raised about the logic for exiting the while loop, with a suggestion to change the condition from "OR" to "AND" to prevent unintended iterations.
  • A later reply questions the practicality of entering a large number of special votes, suggesting a need for a more efficient input method.
Participants express differing views on the clarity of the problem statement and the effectiveness of the pseudocode. There is no consensus on the correct implementation or understanding of the voting categories and input methods.
Limitations include unclear definitions of vote categories, potential issues with the pseudocode's loop logic, and the practicality of inputting a large number of votes.
lionely
Design and execute a trace table that accepts vote data at a polling station in a constituency. Data should include special votes,general(valid) votes and spoilt votes. Votes should be cast for anyone of four parties,DAP,WNA,UPM or PDR.The table should trace the increment of each vote category and determine which party secured the majority of votes. The table should have at least ten iterations and should end when a specific value is entered.
Attempt:
Code:
START
Declare: Class,: string
Party,D_General,W_General,U_General,P_General,D_Spoil,W_Spoil,U_Spoil, P_Spoil, W_Special, U_Special, P_Special, D_Special:integer
PRINT “Enter JNP for Party or Class to Quit”
PRINT “Enter Party”
Read Party
PRINT “Enter Class of Vote”
Read Class
	WHILE(Party <> “JNP” OR Class <> “JNP”) DO
	If (Class = “Special”) THEN
	IF (Party = “DAP”)THEN
	D_Special =D_Special + 1
	ENDIF
	IF (Party = “WNA”) THEN
	W_Spec ial = W_Special + 1
	ENDIF
	IF(Party = “UPM”)THEN
	U_Special = U_Special + 1
ENDIF
IF(Party= “PDR”)THEN
P_Special = P_Special+1
ENDIF
ENDIF
If (Class = “General”) THEN
		D_ General =D_ General + 1
		ENDIF
		W_ General = W_ General + 1
		ENDIF
		U_ General = U_ General + 1
ENDIF
P_ General = P_ General +1
ENDIF
ENDIF
		If (Class = “Spoil”) THEN
		D_ Spoil =D_ Spoil + 1
		ENDIF
		W_ Spoil = W_ Spoil + 1
		ENDIF
		U_ Spoil = U_ Spoil + 1
ENDIF
P_ Spoil = P_ Spoil +1
ENDIF
ENDIF
ENDwhile
STOp
Please tell me if this is correct.
I don't think this is right, but then again, the problem statement is not clear to me. For example, what is the difference between special votes and general (valid) votes? How can you tell if a vote is spoiled?
What is a trace table? Is that something you use to simulate the execution of the code for a specific input value?
Your pseudocode doesn't give any way for a user to enter a vote.
The problem statement suggests that there should be a loop of some kind, and should do input.
You have an endwhile statement, but there is no while statement.
Oh my gosh I forgot a half of the code...
I'll edit my previous post and post the whole code.
A tracetable is a way of testing a pseudocode. But I don't need help witht he tracetable I need help with the pseudocode.
Attempt:
I can see that you put some effort into indenting the various statement, but your indentation was not as good as it could be. I have taken the liberty of indenting your code as I would do it.
Code:
START
PRINT “Enter Party”
Read Party
Read Class
      ENDIF
      ENDIF
      ENDIF
      ENDIF
   ENDIF
      ENDIF
      ENDIF
      ENDIF
      ENDIF
   ENDIF
      ENDIF
      ENDIF
      ENDIF
      ENDIF
   ENDIF
ENDwhile
STOp
Your logic for exiting the while loop is not correct. The idea is supposed to be that when you enter JNP for party or vote, the loop doesn't run. Suppose you're running this, and are prompted to enter the party, and you type "JNP" and for Class you just press the ENTER key. The expression Party <> "JNP" is false, and the expression Class <> "JNP is true, so the expression Party <> “JNP” OR Class <> “JNP” is (false OR true), which is true, so the loop runs again.
To fix this, change "OR" to "AND".
Also, in this line
Code:
you have an extra comma.
Oh, but the thing is I had a doubt with this pseudocode because if this was a polling station if the special votes were like 200 wouldn't I have to enter somethign 200 times?
